    [Plugin] Archiland Toolbar
    58 Posts 40 Posters 78.0k Views 40 Watching
      tulacong
      @cadfather said:
      Hi, this is my tiny (and yet herculean) contribution to this great community.
      it is a toolbar that integrates some architectural and landforming scripts accessible from icons.
      find it under view > toolbars > archiland
      hope you find it useful - the archive contains files like delauney2.rb, parametric.rb and sketchup.rb which you may already have, but here they are included just in case.
      now, most scripts are from various masters which kindly granted the permission for my small tweaks.
      to Didier, TIG, Carlos Fale and to all the others, go all the thanks: Thanks! 👍
      [attachment=0:39dcaamq]<!-- ia0 -->cd archiland.png<!-- ia0 -->[/attachment:39dcaamq]
      thank you
        cyan.archnet
        EXCEPTIONALLY SUPERB plugin!, thanks a lot! 👍 👍
          tomot
          Great addition!
          But whats the point of doing a huge scramble file containing coded Rubies that were formerly not scrambled?
          [my plugins](http://thingsvirtual.blogspot.ca/)
          tomot
          • CadFatherC Offline
            CadFather
            ..because some were scrambled - and thanks for the window/doors 👍
              cyan.archnet
              Dear CadFather,just have a query regarding Archiland Plugin, i did copy it in the plugins but when i open my sketchup this is what appears
              Error Loading File cd_architect.rb
              C:/Program Files/Google/Google SketchUp 6/Plugins/sketchup.rb:99: undefined method get_i18n_datfile_info' for Sketchup:ModuleError Loading File Sketchup.rb undefined method get_i18n_datfile_info' for Sketchup:Module, any help on this?, THANKS A LOT!
                CadFather
                have you unzipped all the contents in plugins?
                  cyan.archnet
                  I did unzip the file, but i still get the same error, don't know what is the problem.
                    CadFather
                    try replacing this
                    Sketchup.rb
                      cyan.archnet
                      Dear CadFather, It's working perfectly well now, THANKS A WHOLE LOT!
                      • arqpadaoA Offline
                        arqpadao
                        Hi CadFather
                        Many thanks, good ideia,
                        But
                        I have a problem. Installed and appeared all the items on the menu but Plugins to open the window of the icons they do not appear. The folder - Archiland Toolbar are in the plugins folder and the 4 files. RB were copied to the plugins folder of Sketchup. It could help me.
                        fernando padão
                        arquiteto
                        porto alegre - brasil
                        http://arqpadao.blogspot.com
                          CadFather
                          make sure the folder cd_icons is in the plugins folder
                          • david_hD Offline
                            david_h
                            Very cool. Thanks.
                            • arqpadaoA Offline
                              arqpadao
                              small detail.
                              There are tutorials on how to use the plugins...
                              I do not understand the use of Spiral Stairs, Simplify Contours, Make Contourns, Triangulate points, Pontify and Terrain Reshaper...
                              fernando padão
                              arquiteto
                                CadFather
                                i'm working on a new set of toolbars and also planning some tutorials - it's just a matter of squeezing it all in 24 hour cycles
                                but in short they are easy to start with - try and see
                                draw a jagged curve with the freehand tool - simplify contours will reduce the jagginess (and segmentation)
                                draw a cone or any 3d shape (not cube), group it - make contours will create new contour lines around the 3d shape
                                on the same shape (explode the group) run pointify - the result is c-points on every vertex (corner)
                                trangulate points does the reverse - delete the 3d shape, select all c-points - run the script
                                you will also find many tutorials in pdf on Didier Bur's site
                                http://www.crai.archi.fr/RubyLibraryDepot/Ruby/RUBY_Library_Depot.htm
                                  AthidhiTM
                                  thanks
                                  • arqpadaoA Offline
                                    arqpadao
                                    thanks
                                    this will be very good
                                    fernando padão
                                    arquiteto
                                    • F Offline
                                      Frank0503
                                      Thanks CADfather, I've already download your ruby in another 4r & it's really really useful. But I wonder why you don't more develop it more, like could I change the style of stair tread like Sketchup?
                                        CadFather
                                        ..now that we have dynamic components, the stairs might be less important - in any case i'm working on an update..
                                        also remember the rubies have been created by the ruby masters - all i did was integrate them into the toolbar with command and icons
                                          lorenzo
                                          thanks a lot Cadfather!!!
                                          that's great!!!
                                            CadFather
                                            your welcome Lorenzo 😄
                                            • 2 / 3
