    [Plugin] Archiland Toolbar
    58 Posts 40 Posters 89.5k Views 40 Watching
    • CadFatherC Offline
      CadFather
      make sure the folder cd_icons is in the plugins folder
      • david_hD Offline
        david_h
        Very cool. Thanks.
        • arqpadaoA Offline
          arqpadao
          small detail.
          There are tutorials on how to use the plugins...
          I do not understand the use of Spiral Stairs, Simplify Contours, Make Contourns, Triangulate points, Pontify and Terrain Reshaper...
          fernando padão
          arquiteto
          porto alegre - brasil
          http://arqpadao.blogspot.com
            CadFather
            i'm working on a new set of toolbars and also planning some tutorials - it's just a matter of squeezing it all in 24 hour cycles
            but in short they are easy to start with - try and see
            draw a jagged curve with the freehand tool - simplify contours will reduce the jagginess (and segmentation)
            draw a cone or any 3d shape (not cube), group it - make contours will create new contour lines around the 3d shape
            on the same shape (explode the group) run pointify - the result is c-points on every vertex (corner)
            trangulate points does the reverse - delete the 3d shape, select all c-points - run the script
            you will also find many tutorials in pdf on Didier Bur's site
            http://www.crai.archi.fr/RubyLibraryDepot/Ruby/RUBY_Library_Depot.htm
              AthidhiTM
              thanks
              • arqpadaoA Offline
                arqpadao
                thanks
                this will be very good
                fernando padão
                arquiteto
                • F Offline
                  Frank0503
                  Thanks CADfather, I've already download your ruby in another 4r & it's really really useful. But I wonder why you don't more develop it more, like could I change the style of stair tread like Sketchup?
                    CadFather
                    ..now that we have dynamic components, the stairs might be less important - in any case i'm working on an update..
                    also remember the rubies have been created by the ruby masters - all i did was integrate them into the toolbar with command and icons
                      lorenzo
                      thanks a lot Cadfather!!!
                      that's great!!!
                        CadFather
                        your welcome Lorenzo 😄
                          Ross Macintosh
                          Max - you truly are the CadFather! Your tool bar is a great addition to the neighborhood.
                          I have one little problem relating to the roof tools. On my toolbar the mansard & gable roof buttons are transposed. Clicking the gable produces the mansard etc. -- The tooltips are correct so it seems its just the images are referenced wrong.
                          Regards, Ross
                            bellwells
                            Max, as Ross just pointed out, the icons representing the gable, mansard and hipped roof designs are mixed up. The pyramid roof icon is correct. I have renamed the icon (.png) files appropriately and am attaching a new CD_ICON folder here so others can replace the old folder with this one. I hope this is a permissable act on my part.
                            CD_ICONS.zip
                            EDIT: Ohhh...and thank you very much for a wonderful tool!!
                            Ron
                            • jcdbJ Offline
                              jcdb
                              Thanks CF. What does Pointify do?
                              http://www.acustombuilder.com
                                bellwells
                                I think pointify converts vertexes into construction points. Do a search and you'll find plenty of posts on the subject.
                                Ron
                                  CadFather
                                  Hi, just back from italy where i had little or no connection - can't believe i did live just the same 😲 - i knew there were a couple of icons out of place but they eventually slipped by.. thanks all for your feedback.. and Ron, i will change the package with the updated icons.. (done)
                                  Cheers! 👍
                                  • Z Offline
                                    zeal
                                        :sunglasses:
                                    • Z Offline
                                      zamant
                                      thank's a lot!!!!
                                      antonio 😍
                                        chango70
                                        Cadfather, care to do a guide on how to create Icons and use them with rubies? I like icon interface and would love to help out.
                                          arquilevis06
                                          Very Nice Work!!!! muy buen trabajo Bro!!!!
                                          • F Offline
                                            freakinsomnia
                                            thanks cadfather...but,any tutorial about archiland?
                                            • 2 / 3
