    [Plugin] Archiland Toolbar
    58 Posts 40 Posters 90.1k Views 40 Watching
    • C
      cyan.archnet
      I did unzip the file, but i still get the same error, don't know what is the problem.
      • CadFatherC
        CadFather
        try replacing this
        Sketchup.rb
        • C
          cyan.archnet
          Dear CadFather, It's working perfectly well now, THANKS A WHOLE LOT!
          • arqpadaoA
            arqpadao
            Hi CadFather
            Many thanks, good ideia,
            But
            I have a problem. Installed and appeared all the items on the menu but Plugins to open the window of the icons they do not appear. The folder - Archiland Toolbar are in the plugins folder and the 4 files. RB were copied to the plugins folder of Sketchup. It could help me.
            fernando padão
            arquiteto
            porto alegre - brasil
            http://arqpadao.blogspot.com
            • CadFatherC
              CadFather
              make sure the folder cd_icons is in the plugins folder
              • david_hD
                david_h
                Very cool. Thanks.
                • arqpadaoA
                  arqpadao
                  small detail.
                  There are tutorials on how to use the plugins...
                  I do not understand the use of Spiral Stairs, Simplify Contours, Make Contourns, Triangulate points, Pontify and Terrain Reshaper...
                  fernando padão
                  arquiteto
                  • CadFatherC
                    CadFather
                    i'm working on a new set of toolbars and also planning some tutorials - it's just a matter of squeezing it all in 24 hour cycles
                    but in short they are easy to start with - try and see
                    draw a jagged curve with the freehand tool - simplify contours will reduce the jagginess (and segmentation)
                    draw a cone or any 3d shape (not cube), group it - make contours will create new contour lines around the 3d shape
                    on the same shape (explode the group) run pointify - the result is c-points on every vertex (corner)
                    trangulate points does the reverse - delete the 3d shape, select all c-points - run the script
                    you will also find many tutorials in pdf on Didier Bur's site
                    http://www.crai.archi.fr/RubyLibraryDepot/Ruby/RUBY_Library_Depot.htm
                      AthidhiTM
                      thanks
                      • arqpadaoA
                        arqpadao
                        thanks
                        this will be very good
                        fernando padão
                        arquiteto
                        • F
                          Frank0503
                          Thanks CADfather, I've already download your ruby in another 4r & it's really really useful. But I wonder why you don't more develop it more, like could I change the style of stair tread like Sketchup?
                          • CadFatherC
                            CadFather
                            ..now that we have dynamic components, the stairs might be less important - in any case i'm working on an update..
                            also remember the rubies have been created by the ruby masters - all i did was integrate them into the toolbar with command and icons
                            • L
                              lorenzo
                              thanks a lot Cadfather!!!
                              that's great!!!
                              • CadFatherC
                                CadFather
                                your welcome Lorenzo 😄
                                  Ross Macintosh
                                  Max - you truly are the CadFather! Your tool bar is a great addition to the neighborhood.
                                  I have one little problem relating to the roof tools. On my toolbar the mansard & gable roof buttons are transposed. Clicking the gable produces the mansard etc. -- The tooltips are correct so it seems its just the images are referenced wrong.
                                  Regards, Ross
                                  • B
                                    bellwells
                                    Max, as Ross just pointed out, the icons representing the gable, mansard and hipped roof designs are mixed up. The pyramid roof icon is correct. I have renamed the icon (.png) files appropriately and am attaching a new CD_ICON folder here so others can replace the old folder with this one. I hope this is a permissable act on my part.
                                    CD_ICONS.zip
                                    EDIT: Ohhh...and thank you very much for a wonderful tool!!
                                    Ron
                                    • jcdbJ
                                      jcdb
                                      Thanks CF. What does Pointify do?
                                      http://www.acustombuilder.com
                                      • B
                                        bellwells
                                        I think pointify converts vertexes into construction points. Do a search and you'll find plenty of posts on the subject.
                                        Ron
                                        • CadFatherC
                                          CadFather
                                          Hi, just back from italy where i had little or no connection - can't believe i did live just the same 😲 - i knew there were a couple of icons out of place but they eventually slipped by.. thanks all for your feedback.. and Ron, i will change the package with the updated icons.. (done)
                                          Cheers! 👍
                                          • Z
                                            zeal
                                                :sunglasses:
                                            • 2 / 3
