    [Plugin] Archiland Toolbar
    58 Posts 40 Posters 89.5k Views 40 Watching
    • MALAISEM Offline
      MALAISE
      Thanks a lot CadFather, you not only write interesting plugins, but you also lead some of us to go further in learning Ruby...
      MALAISE 😄
      • CadFatherC Offline
        CadFather
        MALAISE 😄
        yes.. at least there is hope for all...! 😄 ☀
        Note: Facer found some icons misplaced - will post update soon
        • E Offline
          ehaflett
          Way cool CadFather. Thanks.
            matteo
            many thanks for your efforts - it works very well.
            hire me: http://www.nonsolo3d.it/ !
            • pbacotP Offline
              CADfather,
              Thanks. As I have not used all these yet, this will be a good way to get started. This could be the beginning of a whole architect suite. On the Mac I find that sometimes the icons stay selected after I have moved on to another tool, so many icons can be selected (darkened) at once. Is this OK?
              Peter
                CadFather
                Hi Peter, unfortunately i do not have a mac so i do not know how they work 😞
                on my pc it works fine - perhaps someone else has the same mac problem and can help?
                  tulacong
                  @cadfather said:
                  Hi, this is my tiny (and yet herculean) contribution to this great community.
                  it is a toolbar that integrates some architectural and landforming scripts accessible from icons.
                  find it under view > toolbars > archiland
                  hope you find it useful - the archive contains files like delauney2.rb, parametric.rb and sketchup.rb which you may already have, but here they are included just in case.
                  now, most scripts are from various masters which kindly granted the permission for my small tweaks.
                  to Didier, TIG, Carlos Fale and to all the others, go all the thanks: Thanks! 👍
                  [attachment=0:39dcaamq]<!-- ia0 -->cd archiland.png<!-- ia0 -->[/attachment:39dcaamq]
                  thank you
                    cyan.archnet
                    EXCEPTIONALLY SUPERB plugin!, thanks a lot! 👍 👍
                      tomot
                      Great addition!
                      But whats the point of doing a huge scramble file containing coded Rubies that were formerly not scrambled?
                      my plugins
                      tomot
                        CadFather
                        ..because some were scrambled - and thanks for the window/doors 👍
                          cyan.archnet
                          Dear CadFather,just have a query regarding Archiland Plugin, i did copy it in the plugins but when i open my sketchup this is what appears
                          Error Loading File cd_architect.rb
                          C:/Program Files/Google/Google SketchUp 6/Plugins/sketchup.rb:99: undefined method get_i18n_datfile_info' for Sketchup:ModuleError Loading File Sketchup.rb undefined method get_i18n_datfile_info' for Sketchup:Module, any help on this?, THANKS A LOT!
                            CadFather
                            have you unzipped all the contents in plugins?
                              cyan.archnet
                              I did unzip the file, but i still get the same error, don't know what is the problem.
                                CadFather
                                try replacing this
                                Sketchup.rb
                                  cyan.archnet
                                  Dear CadFather, It's working perfectly well now, THANKS A WHOLE LOT!
                                  • arqpadaoA Offline
                                    arqpadao
                                    Hi CadFather
                                    Many thanks, good ideia,
                                    But
                                    I have a problem. Installed and appeared all the items on the menu but Plugins to open the window of the icons they do not appear. The folder - Archiland Toolbar are in the plugins folder and the 4 files. RB were copied to the plugins folder of Sketchup. It could help me.
                                    fernando padão
                                    arquiteto
                                    porto alegre - brasil
                                    http://arqpadao.blogspot.com
                                      CadFather
                                      make sure the folder cd_icons is in the plugins folder
                                      • david_hD Offline
                                        david_h
                                        Very cool. Thanks.
                                        • arqpadaoA Offline
                                          arqpadao
                                          small detail.
                                          There are tutorials on how to use the plugins...
                                          I do not understand the use of Spiral Stairs, Simplify Contours, Make Contourns, Triangulate points, Pontify and Terrain Reshaper...
                                          fernando padão
                                          arquiteto
                                            CadFather
                                            i'm working on a new set of toolbars and also planning some tutorials - it's just a matter of squeezing it all in 24 hour cycles
                                            but in short they are easy to start with - try and see
                                            draw a jagged curve with the freehand tool - simplify contours will reduce the jagginess (and segmentation)
                                            draw a cone or any 3d shape (not cube), group it - make contours will create new contour lines around the 3d shape
                                            on the same shape (explode the group) run pointify - the result is c-points on every vertex (corner)
                                            trangulate points does the reverse - delete the 3d shape, select all c-points - run the script
                                            you will also find many tutorials in pdf on Didier Bur's site
                                            http://www.crai.archi.fr/RubyLibraryDepot/Ruby/RUBY_Library_Depot.htm
                                            • 1 / 3
