    [Plugin] Archiland Toolbar
    58 Posts 40 Posters 90.1k Views 40 Watching
    • arqpadaoA
      arqpadao
      Hi CadFather
      Many thanks, good ideia,
      But
      I have a problem. Installed and appeared all the items on the menu but Plugins to open the window of the icons they do not appear. The folder - Archiland Toolbar are in the plugins folder and the 4 files. RB were copied to the plugins folder of Sketchup. It could help me.
      fernando padão
      arquiteto
      porto alegre - brasil
      http://arqpadao.blogspot.com
      • CadFatherC
        CadFather
        make sure the folder cd_icons is in the plugins folder
        • david_hD
          david_h
          Very cool. Thanks.
          • arqpadaoA
            arqpadao
            small detail.
            There are tutorials on how to use the plugins...
            I do not understand the use of Spiral Stairs, Simplify Contours, Make Contourns, Triangulate points, Pontify and Terrain Reshaper...
            fernando padão
            arquiteto
            • CadFatherC
              CadFather
              i'm working on a new set of toolbars and also planning some tutorials - it's just a matter of squeezing it all in 24 hour cycles
              but in short they are easy to start with - try and see
              draw a jagged curve with the freehand tool - simplify contours will reduce the jagginess (and segmentation)
              draw a cone or any 3d shape (not cube), group it - make contours will create new contour lines around the 3d shape
              on the same shape (explode the group) run pointify - the result is c-points on every vertex (corner)
              trangulate points does the reverse - delete the 3d shape, select all c-points - run the script
              you will also find many tutorials in pdf on Didier Bur's site
              http://www.crai.archi.fr/RubyLibraryDepot/Ruby/RUBY_Library_Depot.htm
                AthidhiTM
                thanks
                • arqpadaoA
                  arqpadao
                  thanks
                  this will be very good
                  fernando padão
                  arquiteto
                  • F
                    Frank0503
                    Thanks CADfather, I've already download your ruby in another 4r & it's really really useful. But I wonder why you don't more develop it more, like could I change the style of stair tread like Sketchup?
                    • CadFatherC
                      CadFather
                      ..now that we have dynamic components, the stairs might be less important - in any case i'm working on an update..
                      also remember the rubies have been created by the ruby masters - all i did was integrate them into the toolbar with command and icons
                      • L
                        lorenzo
                        thanks a lot Cadfather!!!
                        that's great!!!
                        • CadFatherC
                          CadFather
                          your welcome Lorenzo 😄
                            Ross Macintosh
                            Max - you truly are the CadFather! Your tool bar is a great addition to the neighborhood.
                            I have one little problem relating to the roof tools. On my toolbar the mansard & gable roof buttons are transposed. Clicking the gable produces the mansard etc. -- The tooltips are correct so it seems its just the images are referenced wrong.
                            Regards, Ross
                            • B
                              bellwells
                              Max, as Ross just pointed out, the icons representing the gable, mansard and hipped roof designs are mixed up. The pyramid roof icon is correct. I have renamed the icon (.png) files appropriately and am attaching a new CD_ICON folder here so others can replace the old folder with this one. I hope this is a permissable act on my part.
                              CD_ICONS.zip
                              EDIT: Ohhh...and thank you very much for a wonderful tool!!
                              Ron
                              • jcdbJ
                                jcdb
                                Thanks CF. What does Pointify do?
                                http://www.acustombuilder.com
                                • B
                                  bellwells
                                  I think pointify converts vertexes into construction points. Do a search and you'll find plenty of posts on the subject.
                                  Ron
                                  • CadFatherC
                                    CadFather
                                    Hi, just back from italy where i had little or no connection - can't believe i did live just the same 😲 - i knew there were a couple of icons out of place but they eventually slipped by.. thanks all for your feedback.. and Ron, i will change the package with the updated icons.. (done)
                                    Cheers! 👍
                                    • Z
                                      zeal
                                          :sunglasses:
                                      • Z
                                        zamant
                                        thank's a lot!!!!
                                        antonio 😍
                                        • C
                                          chango70
                                          Cadfather, care to do a guide on how to create Icons and use them with rubies? I like icon interface and would love to help out.
                                            arquilevis06
                                            Very Nice Work!!!! muy buen trabajo Bro!!!!
                                            • 2 / 3
