    Fractal Tree Maker for SketchUp - Free add-on
    extensions
    158 Posts 44 Posters 68.2k Views 44 Watching
    • Al HartA
      Al Hart
      @anssi said:
      About performance issues:
      Never run into this kind of behaviour before. Usually the performance between the two is indistinguishable, with the first maybe a bit faster.
      Does this inspire any thoughts?
      Anssi
      The TreeMaker threads run at a lower priority. It's possible something is stealing clock cycles.
      Make sure the processor is idle before launching a TreeMaker. You can do this using Task Manager->Performance Tab.
      Al Hart
      IRender nXt from Render Plus
      • GaieusG
        I also have nVidia (GForce 6800 GO) in my laptop but it seems to perfom "normally" (i.e. at around 4-6 minutes like most reported above depending on resolution).
          rcossoli
          tanks!!! very good application, I did well in the machine, I just hang up the SketchUp open the program while, but after work, takes about 2 or 3 minutes in renderings as high or higher.
          I have an Athlon 64x2 4800 with 2 GB of RAM and a video card GForce 7200 256.
          THREEDIMENSIONSWEB dot COM
          • Al HartA
            Al Hart
            I am getting the message: "TreeEditor.exe has encountered a problem and needs to close" when I run RpTreeMaker.
            Any thoughts?
            No we haven;t seen that before.
            Does it happen all the time?
            Try running TreeEditor.exe manually (from Explorer or a DOS Window) it is porbably in this path:
            C:\Program Files\Render Plus Systems\RpTreeMaker\TreeEditor.exe
            If it works manually, then there is probably something wrong with the default tree file.
            This is stored in your temporary folder as RpArPlant.ArPlant. If possible rename RpArPlant.ArPlant to something else. If that fixes the problem, then send us the renamed RpArPlant.ArPlant so we can see if something is wrong with it.
            Al Hart
            • AnssiA
              Anssi
              Al,
              I tried running it standalone too, and it was very much faster, the standard tree only took a couple of minutes. Could it be that the once hyped Hyperthreading in this case really makes a difference? What are the machine specs of others that complained of slowness in this thread?
              Is there a way of saving the PNG from the standalone?
              Anssi
              • Al HartA
                Al Hart
                Anssi
                First, let me make sure I have this right.
                There are two separate programs as part of the RpTreeMaker process.
                TreeEditor.exe defines the tree parameters.
                RpTreeMaker.exe creates the image.
                When you run TreeEditor.exe in stand alone mode, does it run considerable faster then when you run it from SketchUp?
                There is a Render button in TreeEditor.exe. Does it render faster when run stand-alone?
                Also, further down in this posting I explain how to run RpTreeMaker.exe. Does it ruin faster in stand-alone mode?
                If so, I may have to learn something about threading...
                One difference, though may be the tree parameters. If you run TreeEditor.exe and pass it the name of a .ArPlant file, then it wil start with that .ArPlant file and save it when done. This may be slower than when you run it with no parameters, and use the default tree settings.
                Try it with: RpTreeMaker %TEMP%\RpArPlant.ArPlant
                It will load and then resave the RpArPlant.ArPlant plant definition file. One "problem" is that when it saves the file, it will automatically save a thumbnail into it which takes some time.
                After defining your .ArPlant file, you can create the bitmap image by running:
                RpTreeMaker.exe %TEMP%\RpTreeMakerArgs.txt
                This will load the .ArPlant file and save the tree image. The "reverse engineer"s among us can figure out how to modify the args file to create different images, etc.
                After the image is created, a third file, RpTreeMakerParams.txt is created which has the path of the image, and the size of the tree.
                Al Hart
                  Sushij
                  Ok, I must be doing something wrong with Podium. When I make a tree, explode it twice, and put a face below it to act as a surface, the shadow doesn't work. The tree is a tree with a black background. So, if anyone has any suggestions about how to fix this, it would be greatly appreciated. Thanks.
                  • AnssiA
                    Anssi
                    No, but it starts faster
                    Yes, very much faster (like 10x)
                    No, it didn't ruin anything, and it rendered very fast, even faster than my other machine did within SU.
                    Anssi
                    • Al HartA
                      Al Hart
                      Anssi
                      Actually that was supposed to say "run" faster, not "ruin" faster.
                      Can you look at your performance with Task Manager and make sure that you have not reached your memory limit when you start the TreeMaker process.
                      I'll take a look and make sure that SketchUp is idle while the tree maker is running.
                      Al
                      Al Hart
                      • N
                        nomeradona
                        thanks, im downloading it now.
                        • Al HartA
                          Al Hart
                          Let us know what you are able to do.
                          We will have a new version Monday, with the ability to rotate the trees, re-render them before saving the image, and with some higher image resolutions.
                          Al Hart
                          • Alan FraserA
                            Alan Fraser
                            Fast work, Al. Much appreciated.
                            Now all you have to do is build a version for yourself with a batch render process that outputs an image every 1 degree or so of rotation, compile them into a RPC file and you'd have something to rival ArchVision. 😉
                            3D Figures
                              Stu
                              Thanks Al, looks like this is turning into a great app. And Im looking forward to the higher resolutions 👍
                              Some more free leaves at TurboSquid http://www.turbosquid.com/FullPreview/Index.cfm/ID/287061
                              [You will need to rotate the leaves, otherwise they stick to the branches back to front 😄]
                              http://www.landesign.com.au
                              • AnssiA
                                Anssi
                                Al
                                I understood about "ruin"-I just didn't want to spoil my little joke with smilies.
                                Actually, I think you might have nailed it. Looking at Task Manager when SU and RPTreeMaker are running shows that they don't use very much memory, but together they use about 100% of the processor, with SU keeping more than 95%, and the RP TreeMaker process somewhere at 2-3%. Of course it might just be the Windows way of displaying things.
                                So it might be that this only occurs with a single-threaded processor, as it works much better on a slightly slower HT computer.
                                Cheers,
                                Anssi
                                • Al HartA
                                  Al Hart
                                  Cheers,
                                  Anssi
                                  Oof - you're right. The way we are calling RpTreeMaker from SketchUp causes SketchUp to keep using machine cycles. And since RpTreeMaker runs at a low priority when it is rendering, SketchUp steals all the cycles from a single processor machine.
                                  In the display below, on a dual processor machine, SketchUp is using 1/2 and the TreeMaker the other 1/2.
                                  Here is how we are calling it now:
                                  system($path + "\\TreeEditor.exe")
                                  We must have found this in the Ruby manual somewhere, but it obviously is not a good way to call a .exe from SketchUp.
                                  If any other ruby programmers are out there, give me some hints on a better way to call a .exe from SketchUp. Meanwhile - I will look around.
                                  Al Hart
                                  • Al HartA
                                    Al Hart
                                    We found a way to have SketchUp wait for the tree maker without using up 1/4, 1/2 or almost all of you processing power.
                                    Look for a new version Monday.
                                    Al Hart
                                      matthew.robert
                                      Anyone else getting the error...
                                      Error Loading File RpTreeMaker_loader.rb
                                      126; The specified module could not be found.   - C;/Program Files/Google/Google SketchUp 7/Plugins/Win32API.so
                                      after installing the tree maker with the "Click here to install RpTreeMaker 2_HK24tm.exe" file and starting up SketchUp?
                                      Any thoughts?
                                        Jorgensen
                                        I can't figure out how to make it work with VRAY 😞
                                        Does it export a aplha channel ?
                                          Jorgensen
                                          Ah. I found a solution.
                                          • Al HartA
                                            Al Hart
                                            @tobobo said:
                                            Al,
                                            Could you add in standard tree shapes as defaults?
                                            One of the reasons we released RpTreeMaker as a free product is that we are hoping some SketchUp users will help us create some standard trees and save them on the 3D warehouse to share with other users.
                                            The definition for each tree can be accessed as a .ArPlant file, and then used as the starting point for changes, or for other trees.
                                            This doesn't work yet because:
                                            1. If you use custom leaves or bark, we need to save them in the .SKP file as well. (We plan to do this, but haven;t done it yet). That way the .SKP file for a tree will have everything it needs to recreate the tree, or save similar trees.
                                            2. We need to write a function to save the .ArPlant file, which defines a tree, from the .SKP file.
                                            We will get to these things soon. Currently we are trying to get the new version released which allows rotation of the trees and higher resolutions. We should have a new version in the next day or so,
                                            Also, we are working on a shadow mask for the tree which will make useful shadows in SketchUp, and work better with renderers like Podium and Vray. (The IRender rendering engine already re-processes the trees creating new fractal trees during the rendering process).
                                            Al Hart
                                            • 6 / 8
