    Fractal Tree Maker for SketchUp - Free add-on
    extensions
    158 Posts 44 Posters 68.2k Views 44 Watching
      Could be a graphic card issue if the app makes use of the card for the calculations... Just guessing here...
      • AnssiA
        Anssi
        My Nvidia should be running circles around the ATI - in general SU use it is noticeably faster...
        Anssi
        • soloS
          Anssi, try removing it completely and re-installing it after a restart, sometimes it can make a difference.... that's all I got so far.
          • Alan FraserA
            Alan Fraser
            Here's a neat trick. The bark will accept either a jpg or a png. So, if you make, say, a 64x64 completely transparent png and specify that, you get an invisible trunk and branches....just the canopy. The resulting skp and image are already cropped to just the foliage.
            You can make that into an angled 2D Face Me on top of a static, low-poly trunk.
            Here's a quick proof of concept, minus any shadow casting. Of course, you could always make them more sophisticated, with several such layers.
            You could probably also use just the canopy (with the right kind of leaves) as drapery/creepers on walls and balconies.
            test_tree.skp
            3D Figures
              Stu
              Al, just a thought.
              I understand your intention is to keep file sizes down but I wonder if a 'super high rez.' option would be possible?
              Im finding that trees produced using the 'Best' resolution are at the moment fine for the background and maybe the middleground but start to look blurred close up.
              Most of these are coming in at around 1.5-2.0 Mb.
              I currently use a lot Tiffs and Pngs that are around 4-6 Mbs each, in SU models that are, say, 80-100 Mbs, fairly comfortably. So I wouldnt see larger file size as an issue.
              Maybe you could add a warning about the Hi Rez option?....but it would certainly push the output closer to the 'photoreal' mark.
              Or maybe include this option in a 'Pro' version?
              I would certain look at paying good money for it.
              http://www.landesign.com.au
              • Al HartA
                Al Hart
                @anssi said:
                About performance issues:
                Never run into this kind of behaviour before. Usually the performance between the two is indistinguishable, with the first maybe a bit faster.
                Does this inspire any thoughts?
                Anssi
                The TreeMaker threads run at a lower priority. It's possible something is stealing clock cycles.
                Make sure the processor is idle before launching a TreeMaker. You can do this using Task Manager->Performance Tab.
                Al Hart
                IRender nXt from Render Plus
                • GaieusG
                  I also have nVidia (GForce 6800 GO) in my laptop but it seems to perfom "normally" (i.e. at around 4-6 minutes like most reported above depending on resolution).
                    rcossoli
                    tanks!!! very good application, I did well in the machine, I just hang up the SketchUp open the program while, but after work, takes about 2 or 3 minutes in renderings as high or higher.
                    I have an Athlon 64x2 4800 with 2 GB of RAM and a video card GForce 7200 256.
                    THREEDIMENSIONSWEB dot COM
                    • Al HartA
                      Al Hart
                      I am getting the message: "TreeEditor.exe has encountered a problem and needs to close" when I run RpTreeMaker.
                      Any thoughts?
                      No we haven;t seen that before.
                      Does it happen all the time?
                      Try running TreeEditor.exe manually (from Explorer or a DOS Window) it is porbably in this path:
                      C:\Program Files\Render Plus Systems\RpTreeMaker\TreeEditor.exe
                      If it works manually, then there is probably something wrong with the default tree file.
                      This is stored in your temporary folder as RpArPlant.ArPlant. If possible rename RpArPlant.ArPlant to something else. If that fixes the problem, then send us the renamed RpArPlant.ArPlant so we can see if something is wrong with it.
                      Al Hart
                      • AnssiA
                        Anssi
                        Al,
                        I tried running it standalone too, and it was very much faster, the standard tree only took a couple of minutes. Could it be that the once hyped Hyperthreading in this case really makes a difference? What are the machine specs of others that complained of slowness in this thread?
                        Is there a way of saving the PNG from the standalone?
                        Anssi
                        • Al HartA
                          Al Hart
                          Anssi
                          First, let me make sure I have this right.
                          There are two separate programs as part of the RpTreeMaker process.
                          TreeEditor.exe defines the tree parameters.
                          RpTreeMaker.exe creates the image.
                          When you run TreeEditor.exe in stand alone mode, does it run considerable faster then when you run it from SketchUp?
                          There is a Render button in TreeEditor.exe. Does it render faster when run stand-alone?
                          Also, further down in this posting I explain how to run RpTreeMaker.exe. Does it ruin faster in stand-alone mode?
                          If so, I may have to learn something about threading...
                          One difference, though may be the tree parameters. If you run TreeEditor.exe and pass it the name of a .ArPlant file, then it wil start with that .ArPlant file and save it when done. This may be slower than when you run it with no parameters, and use the default tree settings.
                          Try it with: RpTreeMaker %TEMP%\RpArPlant.ArPlant
                          It will load and then resave the RpArPlant.ArPlant plant definition file. One "problem" is that when it saves the file, it will automatically save a thumbnail into it which takes some time.
                          After defining your .ArPlant file, you can create the bitmap image by running:
                          RpTreeMaker.exe %TEMP%\RpTreeMakerArgs.txt
                          This will load the .ArPlant file and save the tree image. The "reverse engineer"s among us can figure out how to modify the args file to create different images, etc.
                          After the image is created, a third file, RpTreeMakerParams.txt is created which has the path of the image, and the size of the tree.
                          Al Hart
                            Sushij
                            Ok, I must be doing something wrong with Podium. When I make a tree, explode it twice, and put a face below it to act as a surface, the shadow doesn't work. The tree is a tree with a black background. So, if anyone has any suggestions about how to fix this, it would be greatly appreciated. Thanks.
                            • AnssiA
                              Anssi
                              No, but it starts faster
                              Yes, very much faster (like 10x)
                              No, it didn't ruin anything, and it rendered very fast, even faster than my other machine did within SU.
                              Anssi
                              • Al HartA
                                Al Hart
                                Anssi
                                Actually that was supposed to say "run" faster, not "ruin" faster.
                                Can you look at your performance with Task Manager and make sure that you have not reached your memory limit when you start the TreeMaker process.
                                I'll take a look and make sure that SketchUp is idle while the tree maker is running.
                                Al
                                Al Hart
                                • N
                                  nomeradona
                                  thanks, im downloading it now.
                                  • Al HartA
                                    Al Hart
                                    Let us know what you are able to do.
                                    We will have a new version Monday, with the ability to rotate the trees, re-render them before saving the image, and with some higher image resolutions.
                                    Al Hart
                                    • Alan FraserA
                                      Alan Fraser
                                      Fast work, Al. Much appreciated.
                                      Now all you have to do is build a version for yourself with a batch render process that outputs an image every 1 degree or so of rotation, compile them into a RPC file and you'd have something to rival ArchVision. 😉
                                      3D Figures
                                        Stu
                                        Thanks Al, looks like this is turning into a great app. And Im looking forward to the higher resolutions 👍
                                        Some more free leaves at TurboSquid http://www.turbosquid.com/FullPreview/Index.cfm/ID/287061
                                        [You will need to rotate the leaves, otherwise they stick to the branches back to front 😄]
                                        • AnssiA
                                          Anssi
                                          Al
                                          I understood about "ruin"-I just didn't want to spoil my little joke with smilies.
                                          Actually, I think you might have nailed it. Looking at Task Manager when SU and RPTreeMaker are running shows that they don't use very much memory, but together they use about 100% of the processor, with SU keeping more than 95%, and the RP TreeMaker process somewhere at 2-3%. Of course it might just be the Windows way of displaying things.
                                          So it might be that this only occurs with a single-threaded processor, as it works much better on a slightly slower HT computer.
                                          Cheers,
                                          Anssi
                                          • Al HartA
                                            Al Hart
                                            Cheers,
                                            Anssi
                                            Oof - you're right. The way we are calling RpTreeMaker from SketchUp causes SketchUp to keep using machine cycles. And since RpTreeMaker runs at a low priority when it is rendering, SketchUp steals all the cycles from a single processor machine.
                                            In the display below, on a dual processor machine, SketchUp is using 1/2 and the TreeMaker the other 1/2.
                                            Here is how we are calling it now:
                                            system($path + "\\TreeEditor.exe")
                                            We must have found this in the Ruby manual somewhere, but it obviously is not a good way to call a .exe from SketchUp.
                                            If any other ruby programmers are out there, give me some hints on a better way to call a .exe from SketchUp. Meanwhile - I will look around.
                                            Al Hart
                                            • 6 / 8
