    Fractal Tree Maker for SketchUp - Free add-on
    extensions
    158 Posts 44 Posters 68.2k Views 44 Watching
      Sushij
      Ok, I must be doing something wrong with Podium. When I make a tree, explode it twice, and put a face below it to act as a surface, the shadow doesn't work. The tree is a tree with a black background. So, if anyone has any suggestions about how to fix this, it would be greatly appreciated. Thanks.
      • AnssiA
        Anssi
        When you run TreeEditor.exe in stand alone mode, does it run considerable faster then when you run it from SketchUp?
        No, but it starts faster
        There is a Render button in TreeEditor.exe. Does it render faster when run stand-alone?
        Yes, very much faster (like 10x)
        Also, further down in this posting I explain how to run RpTreeMaker.exe. Does it ruin faster in stand-alone mode?
        No, it didn't ruin anything, and it rendered very fast, even faster than my other machine did within SU.
        Anssi
        • Al HartA
          Al Hart
          Anssi
          Actually that was supposed to say "run" faster, not "ruin" faster.
          Can you look at your performance with Task Manager and make sure that you have not reached your memory limit when you start the TreeMaker process.
          I'll take a look and make sure that SketchUp is idle while the tree maker is running.
          Al
          Al Hart
          IRender nXt from Render Plus
          • N
            nomeradona
            thanks, im downloading it now.
            • Al HartA
              Al Hart
              Let us know what you are able to do.
              We will have a new version Monday, with the ability to rotate the trees, re-render them before saving the image, and with some higher image resolutions.
              Al Hart
              • Alan FraserA
                Alan Fraser
                Fast work, Al. Much appreciated.
                Now all you have to do is build a version for yourself with a batch render process that outputs an image every 1 degree or so of rotation, compile them into a RPC file and you'd have something to rival ArchVision. šŸ˜‰
                3D Figures
                  Stu
                  Thanks Al, looks like this is turning into a great app. And Im looking forward to the higher resolutions šŸ‘
                  Some more free leaves at TurboSquid http://www.turbosquid.com/FullPreview/Index.cfm/ID/287061
                  [You will need to rotate the leaves, otherwise they stick to the branches back to front šŸ˜„]
                  http://www.landesign.com.au
                  • AnssiA
                    Anssi
                    Al
                    I understood about "ruin"-I just didn't want to spoil my little joke with smilies.
                    Actually, I think you might have nailed it. Looking at Task Manager when SU and RPTreeMaker are running shows that they don't use very much memory, but together they use about 100% of the processor, with SU keeping more than 95%, and the RP TreeMaker process somewhere at 2-3%. Of course it might just be the Windows way of displaying things.
                    So it might be that this only occurs with a single-threaded processor, as it works much better on a slightly slower HT computer.
                    Cheers,
                    Anssi
                    • Al HartA
                      Al Hart
                      Cheers,
                      Anssi
                      Oof - you're right. The way we are calling RpTreeMaker from SketchUp causes SketchUp to keep using machine cycles. And since RpTreeMaker runs at a low priority when it is rendering, SketchUp steals all the cycles from a single processor machine.
                      In the display below, on a dual processor machine, SketchUp is using 1/2 and the TreeMaker the other 1/2.
                      Here is how we are calling it now:
                      system($path + "\\TreeEditor.exe")
                      We must have found this in the Ruby manual somewhere, but it obviously is not a good way to call a .exe from SketchUp.
                      If any other ruby programmers are out there, give me some hints on a better way to call a .exe from SketchUp. Meanwhile - I will look around.
                      Al Hart
                      • Al HartA
                        Al Hart
                        We found a way to have SketchUp wait for the tree maker without using up 1/4, 1/2 or almost all of you processing power.
                        Look for a new version Monday.
                        Al Hart
                          matthew.robert
                          Anyone else getting the error...
                          Error Loading File RpTreeMaker_loader.rb
                          126; The specified module could not be found.   - C;/Program Files/Google/Google SketchUp 7/Plugins/Win32API.so
                          after installing the tree maker with the "Click here to install RpTreeMaker 2_HK24tm.exe" file and starting up SketchUp?
                          Any thoughts?
                            Jorgensen
                            I can't figure out how to make it work with VRAY šŸ˜ž
                            Does it export a aplha channel ?
                              Jorgensen
                              Ah. I found a solution.
                              • Al HartA
                                Al Hart
                                @tobobo said:
                                Al,
                                Could you add in standard tree shapes as defaults?
                                One of the reasons we released RpTreeMaker as a free product is that we are hoping some SketchUp users will help us create some standard trees and save them on the 3D warehouse to share with other users.
                                The definition for each tree can be accessed as a .ArPlant file, and then used as the starting point for changes, or for other trees.
                                This doesn't work yet because:
                                1. If you use custom leaves or bark, we need to save them in the .SKP file as well. (We plan to do this, but haven;t done it yet). That way the .SKP file for a tree will have everything it needs to recreate the tree, or save similar trees.
                                2. We need to write a function to save the .ArPlant file, which defines a tree, from the .SKP file.
                                We will get to these things soon. Currently we are trying to get the new version released which allows rotation of the trees and higher resolutions. We should have a new version in the next day or so,
                                Also, we are working on a shadow mask for the tree which will make useful shadows in SketchUp, and work better with renderers like Podium and Vray. (The IRender rendering engine already re-processes the trees creating new fractal trees during the rendering process).
                                Al Hart
                                • Al HartA
                                  Al Hart
                                  Any thoughts?
                                  C:/Program Files/Google/Google SketchUp 7/Plugins/Win32API.so should have been installed as part of RpTreeMaker.
                                  1. Is SketchUp installed on your machine in: C:\Program Files\Google\Google SketchUp 7
                                  2. Did SketchUp put RpTreeMaker_loader.rb into C:\Program Files\Google\Google SketchUp 7\plugins or did you copy it there by hand?
                                  3. Uninstall RpTreeMaker, and reinstall it being careful to select the proper location for SketchUp.
                                  4. After reinstalling it verify that RpTreeMaker_loader.rb and Win32API.so are located in the SketchUp plugins folder.
                                  Al Hart
                                    matthew.robert
                                    Hi Al, tried all those with no luck. For 2, I did not do any manual copying. My SketchUp Pro install is about as clean as it can get BUT I am running it on XP SP3 with Parallels ver. 4 (as a non-bootcamp VM). I have Vista installed via Bootcamp, I will give that a shot.
                                    I will attach the files that got installed in my plugins folder. They are either encrypted, corrupt, or both (maybe?). Should a separate treeeditor.exe file be installed somewhere, I am not seeing that.
                                    Matt
                                    files.zip
                                      matthew.robert
                                      I must be missing some important step... I had the exact same issue on my Bootcamp Vista partition, which for all practical purposes is a different os its own partitioned HD space.
                                      If someone were to send me the necessary files, could I just move them into place manually?
                                      Matt
                                      • Al HartA
                                        Al Hart
                                        Matt
                                        1. Try typing these two lines into the Ruby Console:
                                        require 'Win32API'
                                        RegCloseKey = Win32API.new('advapi32', 'RegCloseKey', 'L', 'L')
                                        (copy and paste them into the ruby console)
                                        1. Are you running on a Mac?
                                        Al Hart
                                          matthew.robert
                                          Ok, tried that. I had to do each line separately, would've that made a difference? Attached is a screen shot of the results.
                                          Yup on running a Mac. I have XP running as a VM and Vista that I occasionally boot into natively. Think that might be causing the issues? Its a unibody MBP.
                                          Matt
                                          • Al HartA
                                            Al Hart
                                            Matt
                                            Hmm.
                                            After "require Win32API",
                                            if you type in just:
                                            Win32API on a Windows machine, it responds with something.
                                            Win32API
                                                Win32API
                                            Win32API.class
                                                Class
                                            Win32API.id
                                                95261808
                                            We'll have to see if there is a version of Win32API.so which works on the Mac partition.
                                            Try running the two executables (.exe) in C:\Program Files\Render Plus Systems\RpTreeMaker (or it s equivalent). TreeEditor.exe and RpTreeMaker.exe. (If they don't run then we have a long way to go to get this to work.
                                            If Win32API is the only problem, we may be able to work around it.
                                            Al Hart
                                            With your input, this post could be even better šŸ’—
                                            • 6 / 8
