    Fractal Tree Maker for SketchUp - Free add-on
    extensions
    158 Posts 44 Posters 68.2k Views 44 Watching
    • AnssiA
      Anssi
      Thank you very much AL!
      It seems to work as expected. A couple of remarks:
      • For me the installer did not give any "install complete" message. Is it supposed to?
      • What kind of render times do others get? For me it used almost 2 hrs for a "medium" image (yes, I have an old 2.8GHz P IV computer
      Anssi
      • soloS
        Anssi, that's waay too long.
        I did about 6 so far all at high setting, the longest one took abot 3 minutes and this is in a dual core Vaio laptop.
          Stu
          Anssi
          Anssi,I think the time is somewhat dependent on the branch complexity and leaf density......try playing with the sliders and numbers.
          And , no, I dont remember an 'installation compete' notice.
          And Pete...Palm trees? 😄
          http://www.landesign.com.au
          • soloS
            Stu, yup.
            see image.
            http://img385.imageshack.us/img385/7035/treeeditoryy2.jpg
            However even with bend in editor the final image is straight.
            http://img149.imageshack.us/img149/3105/200811231527121m12sve4.jpg
              Stu
              [quote="solo"]Stu, yup.
              see image.
              SLAP!!! .....I missed that option all together 😳
              • Al HartA
                Al Hart
                Oof - (bent trunks) - This must not be being written to the XML file properly. We'll trace it down.
                See what happens the to the next tree you try to make after the bent one fails - does it start out straight or bent. (We reuse the last XML file for the next tree, so it should start with whatever settings you used for the last tree)
                Al Hart
                IRender nXt from Render Plus
                  ScottPara
                  Al,
                  Thanks for this. Really nice of you. Just a couple notes or questions:
                  Can we get this to not only export a PNG but also an alpha map? As these do not render at all in Vray. Without an Alpha map it makes it that much harder.
                  Best regards,
                  Scott
                  Love the fact that some HATE my avatar.....
                    Stu
                    Al, After trying with a bend the angle slider reverts to zero when opened again.
                    [Im finding the angle and bending sliders work in conjunction]
                    • Al HartA
                      Al Hart
                      Al,
                      Best regards,
                      Scott
                      The PNG file contains an alpha channel. I am not sure what an alpha map is.
                      When you render other alpha channel images from SketchUp to they work, or do you have to do anything special to make an Alpha Map?
                      If you create an Alpha Map - do you store it in SketchUp, or apply it separately after you extract the alpha image from SketchUp?
                      Are you sure you don't have the same problem that the Podium users have - that you need to explode the alpha-transparent SketchUp image into a face with an alpha material? If that is what is needed, we can make that an option for SketchUp, and perhaps set the face not to cast a rectangular shadow.
                      Podium users - if I set the alpha transparent rectangular face not to cast a shadow in Sketchup - does it still cast a shadow in Podium?
                      Al Hart
                      • Al HartA
                        Al Hart
                        @gaieus said:
                        And the link to the WH:
                        The trees you are making do have the .ArPlant information, so go ahead and upload them.
                        If you use custom leaves or bark, we will want to upload them again after we make a new version next week which stores the custom images on the tree as well.
                        Al Hart
                        • EarthMoverE
                          EarthMover
                          Prior to rendering in Vray, I had to explode the Faceme component twice, then return it to a faceme component. I had to generate a transparency/alpha/clipmap (I use Deep Exploration)to plug into the transparency slot in Vray. This worked fine and the trees rendered well. The process is a bit of a pain, but who can complain about such nice trees for free!
                          http://img224.imageshack.us/img224/6563/fractaltreetestka3.th.jpg
                          http://img224.imageshack.us/images/thpix.gif
                          It would be nice to see an option added to put in a flower map. This would open up the possibility of doing and assortment of flowering shrubs and trees.
                          Content Creator at Skapeup
                          • Gus RG
                            Gus R
                            Al,
                            Thank you very much for this application. Works great and the trees and the options all work like a charm. Even tested it with other leaves as someone suggested -- having converted them to PNGs.
                            Thanks again.
                            Gus
                            www.instagram.com/gusrobatto/
                            www.facebook.com/gusrobatto
                              ScottPara
                              Al,
                              As earthmover stated we (vray users) will still need to generate a alpha/clipmap for these to work. I am not sure how much trouble it would be for the program to export out the associated clipmap at export but it would be a huge time saver.
                              Thanks again,
                              Scott
                              • K
                                kwistenbiebel
                                Hi Al,
                                Just wanted to get back on the 2D/3D subject.
                                As I understand, the treegenerator is actually 3D based by default right?
                                So what about the option to have the full 3D tree as output?
                                Would be great for us render headz. 👍
                                cheers,
                                Kwistenbiebel
                                  ScottPara
                                  I second (or third) the 3D request.
                                  Scott
                                    Third! (fourth?) 😎
                                    • Al HartA
                                      Al Hart
                                      Al,
                                      Thanks again,
                                      Scott
                                      Send me, or upload, a .SKP file or .PNG of a RpTreeMaker tree and a alpha/clipmap of the same tree so I will know what it is you need. Is the clipmap stored in SketchUp anywhere, or separately?
                                      We store all the old .PNG files in the RPS_TreeMaker_Images sub-folder of your temporary folder. If we can easily make a clipmap we could store it there as well.
                                      Al Hart
                                      • Al HartA
                                        Al Hart
                                        Got it working. It's a pretty neat tool. Can you change color? If so, how? This would be very important.
                                        Thanks,
                                        Huck
                                        To change color, you can take the raster images for the leaves or bark, change the color, and save them with a new name.
                                        These are stored in:
                                        C:\Program Files\Render Plus Systems\RpTreeMaker\Support\Plants
                                        in a Bark and a Leaves sub-folder.
                                        Here I took the standard leaf, made it yellow, saved it as a new leaf, and used it to render the tree.
                                        You can create your won bark and leaf images by altering the color of existing images.
                                        You will need a paint program which respects the Alpha Channel.
                                        (I don't have one, but there is a tool in RpTools which will convert the background color of an image to an alpha channel which I used.)
                                        Al Hart
                                        • Alan FraserA
                                          Alan Fraser
                                          There are methods of obtaining a clipmap from a png using any decent image editor. What you effectively end up with is an alpha-channel image. That is a separate image of the tree, exactly the same size as the png, in which every transparent pixel is represented as black and every opaque one as white.
                                          I'm assuming Rick has already worked this out in his image profile ruby in order to generate the path of the vector outlines....but that'll be the encrypted or server-side bit. 😉
                                          3D Figures
                                          • Al HartA
                                            Al Hart
                                            Scott
                                            I will try this out (creating full 3D plants) and see if it works and or is practical.
                                            However, this may effect the "Free" aspect of RpTreeMaker. I will have to discuss this with the developer, since he includes this product as a tool in his own rendering package (nXt) - which is not free.
                                            Al Hart
                                            • 3 / 8
