    Fractal Tree Maker for SketchUp - Free add-on
    extensions
    158 Posts 44 Posters 61.4k Views 44 Watching
    • Al HartA Offline
      Al Hart
      @at3d said:
      I have loaded the link but once back in SketchUp 6(Pro) and selecting the plugin nothing is happening...any suggestions?
      See the next post )two posts down) where I offer some debugging ideas.
      404 Not Found
      (www.sketchucation.com)
      Al Hart
      IRender nXt from Render Plus
      • Mike LuceyM Offline
        Mike Lucey
        @al hart said:
        @bigstick said:
        I have downloaded this and it is an exe file, which means Windows only. Any chance of a Mac version too Al?
        The Fractal tree software is Windows only, and I just can't seem to get the developer interested in MAC version.
        Firstly a BIG thanks Al. This is very generous of you and just
        further demonstrates the ethos of the SketchUp Community. I'm a
        Mac user also BUT we do have BootCamp so should be able to use
        Fractal Tree Maker 👍 Hey! we can't always have the best of
        both Worlds 😉
        Mike
          kwistenbiebel
          Wow Al,
          That is an amazing gift to the SU community. Much appreciated!
          Any chance the tree maker would create the full 3D model as well (even though SU has trouble with polycount)?
          It would be great to be able to have full 3D for rendering.
          Thanks 👍
          • free agentF Offline
            free agent
            i second that request. 😄
            http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
            • EarthMoverE Offline
              EarthMover
              @gaieus said:
              Try again, Adam; it should work.
              Working now. Thanks Gaieus! Man, everyday is like Xmas around here!
              Content Creator at Skapeup
                bellwells
                Thank you very much, Al. This is a great tool!! I am continually flabbergasted by all the after-market superchargers.
                Ron
                • AnssiA Offline
                  Anssi
                  Thank you very much AL!
                  It seems to work as expected. A couple of remarks:
                  • For me the installer did not give any "install complete" message. Is it supposed to?
                  • What kind of render times do others get? For me it used almost 2 hrs for a "medium" image (yes, I have an old 2.8GHz P IV computer
                  Anssi
                  • soloS Offline
                    Anssi, that's waay too long.
                    I did about 6 so far all at high setting, the longest one took abot 3 minutes and this is in a dual core Vaio laptop.
                      Stu
                      Anssi
                      Anssi,I think the time is somewhat dependent on the branch complexity and leaf density......try playing with the sliders and numbers.
                      And , no, I dont remember an 'installation compete' notice.
                      And Pete...Palm trees? 😄
                      http://www.landesign.com.au
                      • soloS Offline
                        Stu, yup.
                        see image.
                        http://img385.imageshack.us/img385/7035/treeeditoryy2.jpg
                        However even with bend in editor the final image is straight.
                        http://img149.imageshack.us/img149/3105/200811231527121m12sve4.jpg
                          Stu
                          [quote="solo"]Stu, yup.
                          see image.
                          SLAP!!! .....I missed that option all together 😳
                          • Al HartA Offline
                            Al Hart
                            Oof - (bent trunks) - This must not be being written to the XML file properly. We'll trace it down.
                            See what happens the to the next tree you try to make after the bent one fails - does it start out straight or bent. (We reuse the last XML file for the next tree, so it should start with whatever settings you used for the last tree)
                            Al Hart
                              ScottPara
                              Al,
                              Thanks for this. Really nice of you. Just a couple notes or questions:
                              Can we get this to not only export a PNG but also an alpha map? As these do not render at all in Vray. Without an Alpha map it makes it that much harder.
                              Best regards,
                              Scott
                              Love the fact that some HATE my avatar.....
                                Stu
                                Al, After trying with a bend the angle slider reverts to zero when opened again.
                                [Im finding the angle and bending sliders work in conjunction]
                                • Al HartA Offline
                                  Al Hart
                                  Al,
                                  Best regards,
                                  Scott
                                  The PNG file contains an alpha channel. I am not sure what an alpha map is.
                                  When you render other alpha channel images from SketchUp to they work, or do you have to do anything special to make an Alpha Map?
                                  If you create an Alpha Map - do you store it in SketchUp, or apply it separately after you extract the alpha image from SketchUp?
                                  Are you sure you don't have the same problem that the Podium users have - that you need to explode the alpha-transparent SketchUp image into a face with an alpha material? If that is what is needed, we can make that an option for SketchUp, and perhaps set the face not to cast a rectangular shadow.
                                  Podium users - if I set the alpha transparent rectangular face not to cast a shadow in Sketchup - does it still cast a shadow in Podium?
                                  Al Hart
                                  • Al HartA Offline
                                    Al Hart
                                    @gaieus said:
                                    And the link to the WH:
                                    The trees you are making do have the .ArPlant information, so go ahead and upload them.
                                    If you use custom leaves or bark, we will want to upload them again after we make a new version next week which stores the custom images on the tree as well.
                                    Al Hart
                                      EarthMover
                                      Prior to rendering in Vray, I had to explode the Faceme component twice, then return it to a faceme component. I had to generate a transparency/alpha/clipmap (I use Deep Exploration)to plug into the transparency slot in Vray. This worked fine and the trees rendered well. The process is a bit of a pain, but who can complain about such nice trees for free!
                                      http://img224.imageshack.us/img224/6563/fractaltreetestka3.th.jpg
                                      http://img224.imageshack.us/images/thpix.gif
                                      It would be nice to see an option added to put in a flower map. This would open up the possibility of doing and assortment of flowering shrubs and trees.
                                      • Gus RG Offline
                                        Gus R
                                        Al,
                                        Thank you very much for this application. Works great and the trees and the options all work like a charm. Even tested it with other leaves as someone suggested -- having converted them to PNGs.
                                        Thanks again.
                                        Gus
                                        www.instagram.com/gusrobatto/
                                        www.facebook.com/gusrobatto
                                          ScottPara
                                          Al,
                                          As earthmover stated we (vray users) will still need to generate a alpha/clipmap for these to work. I am not sure how much trouble it would be for the program to export out the associated clipmap at export but it would be a huge time saver.
                                          Thanks again,
                                          Scott
                                            kwistenbiebel
                                            Hi Al,
                                            Just wanted to get back on the 2D/3D subject.
                                            As I understand, the treegenerator is actually 3D based by default right?
                                            So what about the option to have the full 3D tree as output?
                                            Would be great for us render headz. 👍
                                            cheers,
                                            Kwistenbiebel
                                            • 3 / 8
