    SketchUp RUBY API Wishlist [way of coding wishes, please]
    107 Posts 46 Posters 59.0k Views 46 Watching
    • T
      tomasz
      New method for a texture, very useful for exporters.
      texture.alpha_channel? -> (true or false)
      • W
        Whaat
        Ooohhh..that reminds me:
        How about a method that samples the texture color on a face?
        face.color_at(u,v)->returns a SketchUp::Color object.
        Could be used for displacement mapping inside SketchUp for example.
          Jim
          @david. said:
          Jim,
          Nice idea. Also, I'm curious if you mixed in the Singleton module to implement your singletons? I've found that I can't require a library module like Singleton unless I point directly to my Ruby installation directories. I realize that this isn't required to implement singletons, but it seems the most simple and consistent.
          Hi David,
          Yes, I used the singleton class from Ruby. I copied singleton.rb from the Ruby language installation to a 'ruby' folder in my Sketchup/Plugins folder. The Ruby singleton is very easy to use, and was simply the best and fastest solution. I think there are a few other files from the installed Ruby files that I needed also.
            morisdov
            Hello
            Inside SketchUp it works fine but when creating an AVI file with Export -> Animation
            the - Sketchup::Pages.add_frame_change_observer - is not firing between frames.
            Is there anything i should change or another observer i can use between frames in Export Animation ?
            404 Not Found
            (www.sketchucation.com)
              Jim
              One of the more important things that could be done using the Ruby API, and which would benefit nearly all users is a unified API for menus and toolbars. I don't mean being able to lock toolbars; I mean the possibility to provide menu and toolbar customization using a "Menu & Toolbar Editor" within SketchUp.
              The need is apparent in CadFather's Toolbar plugins; where he creates a collection of scripts and adds toolbar buttons for them. Although these are nice toolbars, they are going to prove difficult to maintain as scripts are updated and obsoleted.
              Really, there would need to be some registry that would:
              • "install" a plugin so that is is not located in the Plugins folder, and so not automatically loaded.
              • allow un-modified plugins to continue to function.
              • allow new/modified plugins to create new, or be added to, existing menus, submenus, and toolbars.
              • handle the creation of menus and toolbars at startup.
              The possibilities are fantastic, if you let your mind run wild:
              • allow menu/toolbars "sets" to be created.
              • allow plugins to be downloaded as-needed, or used online. (zero install: net_require "progrsssbar.rb")
              • check new versions of plugins online, and upgrade.
              Of course, I do not mean to remove the ability for developers to create their own menu or toolbars. But even if it's just for the numerous scripts that are single-menu, or single-button plugins, this would be an improvement.
              (related post)
                Matt666
                Hi guys !
                I wish one day, we would have access to print parameters via ruby... One day... πŸ˜„
                Frenglish at its best !
                My scripts
                • T
                  tomasz
                  An important wish for ALL exporters, I believe:
                  • a method to read a cropped region in 2point perspective view.
                    As far as I am aware, currently there is no way to read it!
                  Please!
                  • T
                    tomasz
                    A Ruby method that will give us a real UVW coordinates of a projected texture, so exporters could use a single, original texture, instead of say 200 small textures of a photo mapped terrain.
                    • chrisglasierC
                      chrisglasier
                      A switch (if it does not exist) to activate a ruby on selection of an entity or entities to allow interaction with a webdialog.
                      See:
                      http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=14299
                        See:
                        Search v7..............
                        • N
                          notareal
                          πŸ‘ Agree!
                          • C
                            confitex architure
                            Hi ScottLininger.
                            Not realy a ruby way of coding, but almost...
                            I mentionned it in an another post: It would be so nice to retrieve a variable from a model into a dynamic component's attribute instead of the opposit (right now, if I understand well, it is only possible to "export" and to make a code to fill the DC's attribute).
                            By the way, I would be very glad if we could learn from your famous animated "sprite" code πŸ˜„
                            Thanks!!!
                              MarcioAB
                              Access to Model.open ( open method of Model class ) as presented in this topic1 and this topic2.
                              Thank you
                                jessejames
                                hello Scott,
                                Thanks for your interest in helping out. That game you made was pretty cool.
                                I would like to see some convience methods like in the Blender API. This may not be appealing to Gurus but might be quite helpful to the new rubyist. Something like...
                                obj.LocX --> (0,0,0)
                                obj.LocX += 20
                                obj.LocX --> (20,0,0)
                                obj.loc = 0,0,0 #set loc
                                obj.getMatrix()
                                i am also wondering why there is no way to do simple and dirty animations, like...
                                Loop
                                    obj.LocX += 10
                                    sleep(.02)
                                    SU.Redraw()
                                I really like most of the SU API's layout compared to Blender, except the Transformation module, it seems a little clumsy. But i might be missing something important. I am not an engineer, just a real brave lad, thats all.
                                So if you want to enlighten me, feel free πŸ˜„
                                Always sleep with a loaded gun under your pillow!
                                • daikuD
                                  daiku
                                  I'd like to be able to specify the font size for text objects.
                                  Clark Bremer
                                  http://www.northernlightstimberframing.com
                                  • T
                                    tomot
                                    I would like to see a GUI added to the Ruby API. This has been sadly lacking from when the Ruby API was first added to be the scripting language for SU. Please add this to your SU8 wish list. Failing that, perhaps an easier task maybe to add a Python API with GUI to SU. I see no reason why SU can't function with 2 scripting languages.
                                    my plugins
                                    tomot
                                      A GUI to the API what do you mean? As oppose to Webdialogs?
                                        jessejames
                                        I think what tomot wants is a GUI toolkit built-in for SU scripting. Web dialogs are quite lacking. Scriptwriters need widgets!
                                        Text, Listbox, Entry, Button, Frame, Toplevel, Spinbox, Label, Scrollbar, Dialogs, RadioButton, CheckButton, Menu, Scale, LabelFrame, Canvas, OptionMenu, PanedWindow, Image Support
                                        Python has all this built-in to the language as Tkinter(Tk widgets) An easy to use GUI builder with every thing a script writer/SUupper needs, amoung others.
                                        I will also volunteer to do most of the dirty work to grow a Python API(and i could get others to help also -- SU DEV would not have to do much).
                                        One of the best things about Python as compared to Ruby is the tons and tons of great documentation. This would be very appealing to those who wish to script but cannot find good docs for Ruby. And the built-in GUI is just icing on the cake!
                                        • T
                                          tomot
                                          Yes that's exactly what I meant. Here is a Google definition of Webdialogs:
                                          By using powerful cross-browser Javascript and CSS, WebDialog renders dialogs, windows and even modal dialogs inside the browser window. It avoids the problems caused by restrictive popup blockers and gives you greater flexibility when designing your web application's user interface.
                                          That's not going to help my scripting endeavors without now also having to learn Javascript and CSS.
                                          JJ you put a generous offer of the table, I would like to contribute where ever possible. Lets hope we can get ScottLininger on board? Because without some support from Google I can't see this going very far.
                                          my plugins
                                          tomot
                                            Coming from a webdesign background I forgot that HTML, CSS and JS is also a thing to be learnt. I see your point. I was just confused because you allready have most of the controls JJ mentioned. But as you say, it a new set of languages to learn.
                                            As for the lacking set of widgets, there are many frameworks that can easily be added on to extend the widget collection.
                                            But I'm puzzled by another thing, tomot; you would be willing to learn Python to make a GUI, but not CSS+JS?
                                            • 2 / 6
