    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] Skin.rb
    237 Posts 66 Posters 159.4k Views 66 Watching
    • V Offline
      Voder Vocoder
      ...it became evident that it sometimes should "prep", or prepare the sides for skinning by splitting the edges.
      Darrel,
      It's not obvious to me what the benefit of prepping is. The granularity of the resulting shape is still determined by the original edges, is it not?
      Thanks,
      ~Voder
        architectboy
        Voder, prepping the edges creates the effect that the edges are connected, not just the vertices.Example1.jpgExample2.jpg
          these icons have disapeared?
          • ToboboT Offline
            Tobobo
            Darrel,
            Thanks for the script but it crashed sketch up and i'm not sure what all the settings mean?
            Toby
            Philippians 4:13
              Cool Darrel, works just fine with my machine. Thanks for coming back. A lot of us were indeed quite curious where you could be. ๐Ÿ˜‰
              Nice options, too! ๐Ÿ‘
              • kmeadK Offline
                kmead
                Good day.
                I am a MacOS user and unfortunately, version 23 does not appear to work any longer. V22 does, so I don't know what the issue is. It doesn't crash SU but doesn't do anything beyond have the buttons toggle and change color. Nothing untoward happens just no change in state of the model.
                Mac OSX v10.5.5 MacBook Pro 2.33, 3gb Ram, 256 ATI X1600
                The earlier versions have worked fine until this point.
                Many thanks.
                Karl
                I created Dilbertville, sorry about that...
                  architectboy
                  Pilou, thank you for the test case. I used it in debugging this version. Hopefully this fixes the problems you guys have been having. The test case still takes my computer several minutes to sort through those 61000 entities and to delete 9000 edges, I don't get how your computer could do it in three seconds ๐Ÿ˜• .
                  Version 2.4
                    3 seconds again for the function "Clean selection" with your new version 2.4 ๐Ÿ˜Ž
                    My comput has 5 years old so with up to date machine that will be instantaneous!
                    Of course I select all the model before launch the Clean Selection!
                    Only edges on "flat" faces are erased!
                    That is I suppose the normal use of the function "Clean Selection"?
                    Maybe I have not calculate tools like your "sort" on my comput processor?
                    That maybe explain the 3 seconds result?
                    (for other manipulations like move copy etc...my comput with this model is go down on its knees! ๐Ÿ˜‰
                    Model by Steph3D
                    PS Existing before 2 icones (rectangle with little red points) for divide in same numbers edges of facets : are they disapeared?
                      Seems your 23 works less than the 22! โ“
                      With the 22 "Clean Selection" (on my very old computer) works fine in 3 seconds โ˜€
                      With the 23 no result after one minute! ๐Ÿ˜ฎ
                      (select the all with triple click !
                      Model by Steph3D
                      test.zip
                        maxosmedia
                        Error Loading File skin.rb
                        undefined method `[]' for nil:NilClass
                        MacOSX 10.4 SU6.4.245
                        • kmeadK Offline
                          kmead
                          I am seeing the same error with the 2.4 version of the plugin under MacOSX 10.5.5
                            architectboy
                            Hmmm, it doesn't do that on my computer. Let's see if this fixes it.
                            Version 2.5
                            • plot-parisP Offline
                              plot-paris
                              weird. the plugin works for me, when I use the toolbar (buttons). but it doesn't react at all, if I try to launch the skin command from the tools-menu... its a pity, because I just assigned a shortcut for the old version. and now I can't use a keyboard shortcut anymore ๐Ÿ˜ž
                              • F Offline
                                fakircho
                                Hi it is working for me fine. I am finding it a bit inconsistent when i give more than two
                                profiles to "Skin". It usually gets it right at the end after asking "is the connection done right"? ๐Ÿ˜„
                                but if i undo i notice that it does it in stages, two profiles at a time.
                                That is ok but is it possible to have it do the whole "skin" as one operation if you have selected more than two profiles, instead of being asked to confirm each step? Please see attached. That would be great
                                • O Offline
                                  otb designworks
                                  I, too, am getting this error on start up. Mac 10.5.5, also.
                                  Cheers, Chuck
                                  OTB Designworks is on Youtube
                                    BTM
                                    Using the Skin rb., running SU7 on Mac OSX 10.5.5, The plugin works almost not at all. The only action working is the one that cleans up the unnecessary edges. It will only work from the toolbar too. Also, I don't know if it's supposed to be like this, but there are no icons in the skin toolbar.
                                    • olisheaO Offline
                                      olishea
                                      this is exactly the ruby ive been looking for. thank you so much. I've been wanting to 'skin' between faces for a long time.
                                      oli
                                        AcesHigh
                                        I think the problem with this plugin, in the way that it DOES NOT achieves the same result as true loft commands in other software, is that the Skin plugin SEEMS to try to achieve the transformation directly... from one shape to the other... maybe there is ONE partial step in the middle.
                                        Analize visually the image below... watch as it seems there is a VERY GRADUAL MORPHING between one shape and the other. Its like if the LOFT command created some 10 intermediate profiles between each ORIGINAL profile. Then, after creating lots of intermediate profiles, it does "sking" the model.
                                        When seeing the pictures of the SKIN plugin in this thread, I guess (but I cant be sure) that one ONE intermediate is create, half the way between the two original profiles.
                                        I wonder if the author agrees with me, and if he thinks its POSSIBLE to better simulate a LOFT command, by making Sketchup draw a number of intermediate profiles, who morph in shape between the two original profiles (the number of intermediate profiles maybe could be selected in a dialog box?)
                                        Easier said than done ๐Ÿ˜„
                                          AcesHigh
                                          hmmm... btw, the plugin is not working at all here at my PC... ive just downloaded 2.5... last time I used the plugin was a long time ago (many versions ago)...
                                          • F Offline
                                            fakircho
                                            Thank you AcesHigh, i have been moaning about this for years ๐Ÿ˜‰
                                            We need a proper Loft tool full stop. I did start a thread a while ago but nothing so far.
                                            http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13272&p=98352&hilit=loft&sid=bcc844a9806886b037dad1618e96f9ad#p98352
                                            I see you use C4D ๐Ÿ˜„
                                            • 11
                                            • 12
                                            • 7 / 12
