    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    [Plugin] Skin.rb
    237 Posts 66 Posters 159.1k Views 66 Watching
    • ToboboT Offline
      Tobobo
      Thanks Mate
      Toby
      Philippians 4:13
      • W Offline
        watkins
        Dear Darrel,
        I note that the new script adds something extra. Do you have a User Guide document to explain how best to use this script?
        Kind regards,
        Bob
          maxosmedia
          SU crash!!! ๐Ÿ˜ž Without tears and comments
          (SU 6.4.245, MacOS 10.4.11)
          Previous versions Skin.rb work perfect
            architectboy
            Skin.rb was originally designed to only "skin", or connect, the sides, but it became evident that it sometimes should "prep", or prepare the sides for skinning by splitting the edges. I came up with two methods for skinning the sides and two methods for preparing the sides. I used to have a button for each method, but now I have one skin button and the settings dialog sets what methods skin.rb uses. I hope that you can figure it out. If someone can explain it better than me, please do.
            • V Offline
              Voder Vocoder
              ...it became evident that it sometimes should "prep", or prepare the sides for skinning by splitting the edges.
              Darrel,
              It's not obvious to me what the benefit of prepping is. The granularity of the resulting shape is still determined by the original edges, is it not?
              Thanks,
              ~Voder
                architectboy
                Voder, prepping the edges creates the effect that the edges are connected, not just the vertices.Example1.jpgExample2.jpg
                  these icons have disapeared?
                  • ToboboT Offline
                    Tobobo
                    Darrel,
                    Thanks for the script but it crashed sketch up and i'm not sure what all the settings mean?
                    Toby
                    Philippians 4:13
                      Cool Darrel, works just fine with my machine. Thanks for coming back. A lot of us were indeed quite curious where you could be. ๐Ÿ˜‰
                      Nice options, too! ๐Ÿ‘
                      • kmeadK Offline
                        kmead
                        Good day.
                        I am a MacOS user and unfortunately, version 23 does not appear to work any longer. V22 does, so I don't know what the issue is. It doesn't crash SU but doesn't do anything beyond have the buttons toggle and change color. Nothing untoward happens just no change in state of the model.
                        Mac OSX v10.5.5 MacBook Pro 2.33, 3gb Ram, 256 ATI X1600
                        The earlier versions have worked fine until this point.
                        Many thanks.
                        Karl
                        I created Dilbertville, sorry about that...
                          architectboy
                          Pilou, thank you for the test case. I used it in debugging this version. Hopefully this fixes the problems you guys have been having. The test case still takes my computer several minutes to sort through those 61000 entities and to delete 9000 edges, I don't get how your computer could do it in three seconds ๐Ÿ˜• .
                          Version 2.4
                            3 seconds again for the function "Clean selection" with your new version 2.4 ๐Ÿ˜Ž
                            My comput has 5 years old so with up to date machine that will be instantaneous!
                            Of course I select all the model before launch the Clean Selection!
                            Only edges on "flat" faces are erased!
                            That is I suppose the normal use of the function "Clean Selection"?
                            Maybe I have not calculate tools like your "sort" on my comput processor?
                            That maybe explain the 3 seconds result?
                            (for other manipulations like move copy etc...my comput with this model is go down on its knees! ๐Ÿ˜‰
                            Model by Steph3D
                            PS Existing before 2 icones (rectangle with little red points) for divide in same numbers edges of facets : are they disapeared?
                              Seems your 23 works less than the 22! โ“
                              With the 22 "Clean Selection" (on my very old computer) works fine in 3 seconds โ˜€
                              With the 23 no result after one minute! ๐Ÿ˜ฎ
                              (select the all with triple click !
                              Model by Steph3D
                              test.zip
                                maxosmedia
                                Error Loading File skin.rb
                                undefined method `[]' for nil:NilClass
                                MacOSX 10.4 SU6.4.245
                                • kmeadK Offline
                                  kmead
                                  I am seeing the same error with the 2.4 version of the plugin under MacOSX 10.5.5
                                    architectboy
                                    Hmmm, it doesn't do that on my computer. Let's see if this fixes it.
                                    Version 2.5
                                    • plot-parisP Offline
                                      plot-paris
                                      weird. the plugin works for me, when I use the toolbar (buttons). but it doesn't react at all, if I try to launch the skin command from the tools-menu... its a pity, because I just assigned a shortcut for the old version. and now I can't use a keyboard shortcut anymore ๐Ÿ˜ž
                                      • F Offline
                                        fakircho
                                        Hi it is working for me fine. I am finding it a bit inconsistent when i give more than two
                                        profiles to "Skin". It usually gets it right at the end after asking "is the connection done right"? ๐Ÿ˜„
                                        but if i undo i notice that it does it in stages, two profiles at a time.
                                        That is ok but is it possible to have it do the whole "skin" as one operation if you have selected more than two profiles, instead of being asked to confirm each step? Please see attached. That would be great
                                        • O Offline
                                          otb designworks
                                          I, too, am getting this error on start up. Mac 10.5.5, also.
                                          Cheers, Chuck
                                          OTB Designworks is on Youtube
                                            BTM
                                            Using the Skin rb., running SU7 on Mac OSX 10.5.5, The plugin works almost not at all. The only action working is the one that cleans up the unnecessary edges. It will only work from the toolbar too. Also, I don't know if it's supposed to be like this, but there are no icons in the skin toolbar.
                                            • 11
                                            • 12
                                            • 8 / 12
