    [Plugin] Round Edge - v1.0 (by Bezier)
    166 Posts 83 Posters 180.8k Views 83 Watching
      ar_angle
      Nice! Thanks!
        @thomthom said:
        If I undo right after the operation it only undo each drawing operation the script did. I'd have to press undo many times to restore the mesh.
        Do you mean that each Undo will cancel a call to the Round Edge script, or that you need several Undos for a single Round Edge operation ? (in this latter case, this is strange, because I don't have the problem).
        Thanks to advise
        It was the latest V-Ray for SketchUp 1.00.74 that interfered with the undo. Using the original VfSU the Round Edge operation could be undone as expected. With the latest VfSU undoing would undo each step of the script operations one by one.
          Pico
          SOrry for interupting but can this be done with this ruby from Fredo?
          I see only that corner problem (cube) thats stays sharp, has this been done?
          • free agentF Offline
            free agent
            this has been an issue for me using this script too, the corners are sharp and not rounded
            http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
              Pico
              Then its still not fixed?
              One question more, can you control number of faces that will be created, like e.g. if you want to fillet an edge between 2 surfaces, can you control how many faces (3 or 4 or 5 or 10...) will make that new "smooth" egde.
                free agent
                yes
                  Pico
                  Is Fredo maybe working on this "sharp corner" issue?
                    remus
                    Id imagine so, along with all the other stuff he's currently doing.
                      Pico
                      Any clue when will it be finished?
                      • CadFatherC Offline
                        CadFather
                        i made icon and cursors for my version of this plugin - here they are if anyone likes them too
                        RDE_Dir.zip
                        • boofredlayB Offline
                          boofredlay
                          Thanks for the icon!
                            Daniel S
                            Great Icons!
                            A crazy ask: It is possible to make the plugin work in a future version with a variable radius along the edge? πŸ˜’
                            Daniel S
                            Variable RoundEdge Video.zip
                            • fredo6F Offline
                              Daniel S
                              The question is indeed crazy. πŸ˜’
                              Need to think about it.
                              Actually I was more thinking of having the offset different for the upper and side faces. Variable curvature is going to be tough in the general case, actually because of the limited flexibility you have in Sketchup to do interactive inputs.
                                payam2000
                                Hey guys!
                                I was sooooooooooooo excited when I saw a solution and your plugin for round edges. I install it as noted, get the icon and everything, but then as soon as I highlight the edges and click on the icon, the windows for distance and etc comes up, as soon as I click on the icon, the whole scketchup window closes and I get the ScketchUp Error report (bug Splat) window... I have version 6.4.112
                                Any suggestions?
                                  CadFather
                                  when i get these bugs i usually empty the plugins folder and try the ruby on its own - if it works then i know it is a conflict somewhere. then i try again, each time adding back small groups of the other scripts.. of course one needs to close/open sketchup everytime.
                                    Or just type in
                                    load 'rubyfilename.rb'
                                    in the ruby console.
                                      BorgMan
                                      Gonna bump this one up again. Fredo, have you made any progress on the script? Or is it likely that it will stay like this for some time. I'm going to install it in 7 right now, so I'm keeping my fingers crossed! ^_^
                                      More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
                                      You've gotta love Slivers.
                                      • MarianM Offline
                                        Marian
                                        I'm pretty sure it's not improved in anyway....
                                        • Y Offline
                                          Yanman
                                          Wow thank You very much.
                                          • fredo6F Offline
                                            With the holdiays, I am just resuming some work on my scripts. Indeed, I will try to fix issues with Round Edge (and maybe develop the spheric / elliptic option).
                                            PS: For the bug splats, it may come from the geometry itself. I never got any myself, but I don't work on complex model either. As a general rule, be careful if you work on the geometry of a component instance whose definition is also used in other instances with transformation such as rotation.
                                            • 4 / 9
