    [Plugin] Round Edge - v1.0 (by Bezier)
    166 Posts 83 Posters 181.4k Views 83 Watching
    • CadFatherC Offline
      CadFather
      i made icon and cursors for my version of this plugin - here they are if anyone likes them too
      RDE_Dir.zip
      • boofredlayB Offline
        boofredlay
        Thanks for the icon!
          Daniel S
          Great Icons!
          A crazy ask: It is possible to make the plugin work in a future version with a variable radius along the edge? πŸ˜’
          Daniel S
          Variable RoundEdge Video.zip
          • fredo6F Offline
            Daniel S
            The question is indeed crazy. πŸ˜’
            Need to think about it.
            Actually I was more thinking of having the offset different for the upper and side faces. Variable curvature is going to be tough in the general case, actually because of the limited flexibility you have in Sketchup to do interactive inputs.
              payam2000
              Hey guys!
              I was sooooooooooooo excited when I saw a solution and your plugin for round edges. I install it as noted, get the icon and everything, but then as soon as I highlight the edges and click on the icon, the windows for distance and etc comes up, as soon as I click on the icon, the whole scketchup window closes and I get the ScketchUp Error report (bug Splat) window... I have version 6.4.112
              Any suggestions?
                CadFather
                when i get these bugs i usually empty the plugins folder and try the ruby on its own - if it works then i know it is a conflict somewhere. then i try again, each time adding back small groups of the other scripts.. of course one needs to close/open sketchup everytime.
                  Or just type in
                  load 'rubyfilename.rb'
                  in the ruby console.
                    BorgMan
                    Gonna bump this one up again. Fredo, have you made any progress on the script? Or is it likely that it will stay like this for some time. I'm going to install it in 7 right now, so I'm keeping my fingers crossed! ^_^
                    More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
                    You've gotta love Slivers.
                    • MarianM Offline
                      Marian
                      I'm pretty sure it's not improved in anyway....
                      • Y Offline
                        Yanman
                        Wow thank You very much.
                        • fredo6F Offline
                          With the holdiays, I am just resuming some work on my scripts. Indeed, I will try to fix issues with Round Edge (and maybe develop the spheric / elliptic option).
                          PS: For the bug splats, it may come from the geometry itself. I never got any myself, but I don't work on complex model either. As a general rule, be careful if you work on the geometry of a component instance whose definition is also used in other instances with transformation such as rotation.
                          • I Offline
                            Iglesias
                            Thank you Fredo, I wish you a happy New Year.
                            • olisheaO Offline
                              olishea
                              oh my god how much time will this save!! thank you sooooo much.
                              oli
                              • E Offline
                                Efrado
                                THANNNNKSSS A LOOOOT for another magnificent Gift from your Kidness
                                • 3 Offline
                                  3DModellers
                                  hey.. could anybody help. I tried this plugin today on skp 7. I made a cube and tried the round edge option. All it did was it placed two lines on either side of the ONE lone edge of the cube. There wasnt anything else.
                                  am I using outdated version?
                                  Does it work with skp 7 ?
                                  I downloaded it from the first page of this thread. Any idea where can I find the latest version?
                                  regards
                                  Pritam
                                  • fredo6F Offline
                                    RoundEdge normally works with SU7. I did not get any probleme before before yours.
                                    Could you open the Ruby Console and advise on what you see.
                                    Also, could you post the skp model if there is anything specific that could help to understand more.
                                    • 3 Offline
                                      3DModellers
                                      Hi Fredo,
                                      I got it.. I got it to work.
                                      Few days ago I had problems running podium renderer in sketchup. Somebody suggested that that removing 'matchbox' plugin might solve the problem. And it had worked.
                                      i did the same this time. I removed matchbox again and then 'round edge' worked perfectly.
                                      It means that the problem is with 'matchbox' plugin. Or it could be that I am using some earlier version of matchbox which was not compatible with other plugins.
                                      anyways , thanks.
                                      iam also thankful for all the wonderful work that you and Whatt are doing. I realised that I saved 2 hours of work yesterday simply thru round edge plugin.
                                      Do you have any blog where all your plugins listed?
                                      Pritam
                                        Daniel S
                                        Fredo, When you say to develop the spheric / elliptic option do you mean something like the attachment image?
                                        That would be a huge improvement πŸ˜„
                                        Thank you again for this amazing must-have tool...
                                        Daniel S
                                        • free agentF Offline
                                          free agent
                                          +100 this would be amazing
                                          http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                                            +101!
                                            It's a cool plugin already now (although has some limitations like the Follow me can also have with concave curves) but a rounded corner (preferably an "option" vs the pointy one) would indeed be a great improvement!
                                            • 5 / 9
