    [Plugin] Round Edge - v1.0 (by Bezier)
    166 Posts 83 Posters 181.4k Views 83 Watching
      CeBe
      That's great! Thank you Sir! πŸ˜„
        ar_angle
        Nice! Thanks!
          @thomthom said:
          If I undo right after the operation it only undo each drawing operation the script did. I'd have to press undo many times to restore the mesh.
          Do you mean that each Undo will cancel a call to the Round Edge script, or that you need several Undos for a single Round Edge operation ? (in this latter case, this is strange, because I don't have the problem).
          Thanks to advise
          It was the latest V-Ray for SketchUp 1.00.74 that interfered with the undo. Using the original VfSU the Round Edge operation could be undone as expected. With the latest VfSU undoing would undo each step of the script operations one by one.
            Pico
            SOrry for interupting but can this be done with this ruby from Fredo?
            I see only that corner problem (cube) thats stays sharp, has this been done?
            • free agentF Offline
              free agent
              this has been an issue for me using this script too, the corners are sharp and not rounded
              http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                Pico
                Then its still not fixed?
                One question more, can you control number of faces that will be created, like e.g. if you want to fillet an edge between 2 surfaces, can you control how many faces (3 or 4 or 5 or 10...) will make that new "smooth" egde.
                  free agent
                  yes
                    Pico
                    Is Fredo maybe working on this "sharp corner" issue?
                      remus
                      Id imagine so, along with all the other stuff he's currently doing.
                        Pico
                        Any clue when will it be finished?
                        • CadFatherC Offline
                          CadFather
                          i made icon and cursors for my version of this plugin - here they are if anyone likes them too
                          RDE_Dir.zip
                          • boofredlayB Offline
                            boofredlay
                            Thanks for the icon!
                              Daniel S
                              Great Icons!
                              A crazy ask: It is possible to make the plugin work in a future version with a variable radius along the edge? πŸ˜’
                              Daniel S
                              Variable RoundEdge Video.zip
                              • fredo6F Offline
                                Daniel S
                                The question is indeed crazy. πŸ˜’
                                Need to think about it.
                                Actually I was more thinking of having the offset different for the upper and side faces. Variable curvature is going to be tough in the general case, actually because of the limited flexibility you have in Sketchup to do interactive inputs.
                                  payam2000
                                  Hey guys!
                                  I was sooooooooooooo excited when I saw a solution and your plugin for round edges. I install it as noted, get the icon and everything, but then as soon as I highlight the edges and click on the icon, the windows for distance and etc comes up, as soon as I click on the icon, the whole scketchup window closes and I get the ScketchUp Error report (bug Splat) window... I have version 6.4.112
                                  Any suggestions?
                                    CadFather
                                    when i get these bugs i usually empty the plugins folder and try the ruby on its own - if it works then i know it is a conflict somewhere. then i try again, each time adding back small groups of the other scripts.. of course one needs to close/open sketchup everytime.
                                      Or just type in
                                      load 'rubyfilename.rb'
                                      in the ruby console.
                                        BorgMan
                                        Gonna bump this one up again. Fredo, have you made any progress on the script? Or is it likely that it will stay like this for some time. I'm going to install it in 7 right now, so I'm keeping my fingers crossed! ^_^
                                        More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
                                        You've gotta love Slivers.
                                        • MarianM Offline
                                          Marian
                                          I'm pretty sure it's not improved in anyway....
                                          • Y Offline
                                            Yanman
                                            Wow thank You very much.
                                            • 4 / 9
