    [Plugin] Double line
    91 Posts 38 Posters 70.7k Views 38 Watching
      rv1974
      Hi!
      c=circle
      x=explode.
      Generally the letters are bad idea.
      Could it be just cntl click for for close?
      • CadFatherC
        CadFather
        i second that
        • Didier BurD
          Didier Bur
          Everybody will agree now, I hope. I finally got the double-click detection to work, so a double-clic will close a shape.
          Another small enhancement: when you draw only one segment on an existing face, it takes the face as the base geometric plane (to solve Fletch's issue).
          Download it at the top of topic.
          Regards,
          DB
            Users presure πŸ˜„ πŸ‘
            • CadFatherC
              CadFather
              Thank you Master Didier!
              • daikuD
                daiku
                Well, that last fix broke it for me. 😞 I like doing one wall at a time, and it now lays them down flat instead of upright. I'm adding walls to an existing framework, so there are planes adjacent to where I'm adding the wall. PS: if I could undo one wall at a time, that would be great - if I make a mistake and undo, I lose all the work I've done with the tool so far. Thanks, CB.
                Clark Bremer
                http://www.northernlightstimberframing.com
                • Didier BurD
                  Didier Bur
                  Done. Download it again... πŸŽ‰
                  DB
                  • EarthMoverE
                    EarthMover
                    Didier,
                    Thanks for the plugin, it's great! Any plans to incorporate a double line function for an arc type tool as well?
                    Content Creator at Skapeup
                    • Didier BurD
                      Didier Bur
                      Why not...
                      DB
                      • Mike LuceyM
                        Mike Lucey
                        Thanks Didier πŸ‘
                          rv1974
                          Didier many thanks for your efforts!
                          Double click for close is neat idea though I couldn't manage to get good result- it's a bit messy.
                            it's a bit messy
                            ? Very clear! β˜€
                            A little trick if you find this difficult πŸ˜‰
                            Draw your lines without the plug, group it, then redraw with the plug over them! πŸ˜’
                            Erase the group
                              rv1974
                              Now I understood: it closes wall in a newpoint not at the first one. I'm spoiled with CAD background )
                              @Pilou: With pre-drowed lines extrude lines.rb is better choise imho
                                You have not the drawing of the dashed axis line πŸ˜‰
                                And you have a thickness with extrude simple lines ❓ And a wall ❓
                                it closes wall in a new point not at the first one
                                Yes Didier is some original ! πŸ’š
                                It's some pertubating but after some try we are in the move! β˜€
                                  rv1974
                                  Pardon, I meant extrude along path .rb (of TIG i beleive).
                                  I'm afraid the wink about dashed line I didn't understand. What do you mean?
                                    Just this πŸ˜‰
                                    • G
                                      gogo2suf
                                      Thank You vary much D. Bur ,
                                      Thank you!!!!!!!!!!!!
                                      GOGO
                                        agrazdi
                                        Is it possible to add a png icon into the tool bars for the double line function ?
                                        agrazdi
                                        • FletchF
                                          Fletch
                                          Didier! You are wonderful... but you already knew this. Thank you for sharing this wonderful update.
                                          Since you love bug-hunting... here's what I get now... it does draw the wall but in the opposite direction from expected... I drew vertically on the 'inside' of this wall... I think it's picking the 'positive' direction of the green axis... perhaps - just a guess.
                                          my axis lines show up now. πŸ˜„
                                          So, this guy goes to the doctor...
                                          man: "Doc, my arm hurts when I move it like this."
                                          doctor: "Well, don't move it like that."
                                          Fletch
                                          • G
                                            gamore
                                            some errors
                                            what should i do?
                                            • 2 / 5
