    [Plugin] Double line
    91 Posts 38 Posters 70.7k Views 38 Watching
    • H
      Hazza
      Do you know how easy this tool makes it to create pieces of wood for my models!!!! Hit D, enter 2 of the dimensions, click click, done.
      That is awesome, thank you...
      See all of my SketchUp models here.
      • Didier BurD
        Didier Bur
        I can't get 'C' to work closing the loop - I have a short cur for circle that's 'c' so it dumps into that. Perhaps having something like shift+enter to close might do it ?
        I noticed that also at the office on a standard install of SU, at home my PC doesn't have the "c" shortcut...
        BTW, how to detect the Shift+enter keys pressed ?
        I was thinking of a "x" shortcut instead but Shift+enter is more intuitive.
        @honolulu: no, no additionnal files required. Maybe a glitch with the pushpull if you are on Mac ?
        @Pilou: want always more, hey ? i'll try to do it...
        DB
          mike d
          thanks
          The grass is always GREENER on the roof.
          • daikuD
            daiku
            This is fantastic, Didier. I have one suggestion (for now πŸ˜„ 😞 Each time the user hits the enter key to draw the walls so far, commit the operation so the wall sections can be undone one at a time. Thanks again, this is really useful. CB.
            Clark Bremer
            http://www.northernlightstimberframing.com
              With some arcs now? πŸ’š
              • Didier BurD
                Didier Bur
                With some arcs now?
                No no no. Ask TIG! 🀣
                BTW, you can draw walls that include arcs with the "line2wall*.rb" scripts.
                DB
                  Didier
                  Excellent idea - I was working on something similar, mine was called 'mline' - you beat me to it ! Well done.
                  I can't get 'C' to work closing the loop - I have a short cut for circle that's 'c' so it dumps into that. Perhaps having something like shift+enter to close might do it ?
                    @didier bur said:
                    The code is basically "if key1== enter AND key2== shift then..." For example
                    def onKeyDown(key,repeat,flags,view)
                      @key="shift" if key==CONSTRAIN_MODIFIER_KEY
                    end#def
                    • Didier BurD
                      Didier Bur
                      Patch published today. Shortcut for "close" changed to "x" instead of "c".
                      DB
                        Damned I have x for X-Ray πŸ’š
                        So my previous trick will work fine again πŸ˜„
                        Just write any number like 1
                        then backspace for erase it
                        then write x
                        then Enter
                        It's like Glen Gould but works πŸ’š
                          Didier
                          Using "X" is a good choice: x is usually reserved for copying - e.g. x3 to make copies within other commands and isn't a shortcut... If like Pilou you want to use 'X' as a shortcut for something like X-ray you need to remember to use 3x for copies rather than x3, as the latter will invoke X-ray rather than make copies ! Persoanlly I use Alt+X for X-ray mode...
                            cool little trick πŸ€“
                            • FletchF
                              Fletch
                              Great work, Didier! Thanks so much for sharing!
                              a couple little things:
                              when I choose "show axis"... it does not show... whether or not I have it pop the wall up.
                              After drawing a wall, I exit the tool, then I want to draw a double line vertically on a face, so I choose to use the tool again... set width to 12", no face, no close. I draw a vertical line from top edge to bottom edge of the wall face. I hit enter for it to draw the double line. I get this.
                              Fletch
                              • B
                                Ben Ritter
                                Thank you very much Didier.
                                • L
                                  lapx
                                  Thanks D! I'll have to try it out sometime.
                                  • Didier BurD
                                    Didier Bur
                                    Axis is drawn with guide lines (construction lines). Do you have them visible ?
                                    Remember axis will only be visible if justification is "Center".
                                    Oh yes, I noticed that here too. The part of line up the wall is always exactly half the width of the wall 😲
                                    As a matter of fact, this is normal: for the script to work in 3D, I had to compute the geometric plane on which the first two segments are drawn. Thus if you click only one segment, two points aren't enough to define the plane of the base. In this case the script considers that the plane is the red-green plane. And your points have the same projection on the red-green plane. So an error occurs. Hope I'm clear, hem,hem...
                                    But I'll try to fix that if I can.
                                    DB
                                      rv1974
                                      Hi!
                                      c=circle
                                      x=explode.
                                      Generally the letters are bad idea.
                                      Could it be just cntl click for for close?
                                      • CadFatherC
                                        CadFather
                                        i second that
                                        • Didier BurD
                                          Didier Bur
                                          Everybody will agree now, I hope. I finally got the double-click detection to work, so a double-clic will close a shape.
                                          Another small enhancement: when you draw only one segment on an existing face, it takes the face as the base geometric plane (to solve Fletch's issue).
                                          Download it at the top of topic.
                                          Regards,
                                          DB
                                            Users presure πŸ˜„ πŸ‘
                                            • 2 / 5
