    ⚠️ Important | Libfredo 15.6a introduces important bugfixes for Fredo's Extensions Update
    [Plugin] Double line
    91 Posts 38 Posters 57.0k Views 38 Watching
    • arqpadaoA Offline
      arqpadao
      Hi Didier
      thanks, this is great.
      fernando padão
      arquiteto
      porto alegre - brasil
      http://arqpadao.blogspot.com
      • free agentF Offline
        free agent
        very handy, thanx!
        • Didier BurD Offline
          Didier Bur
          Some enhancemments added today. See top of post.
          DB
            @ Tig Same problem but ...
            Just enter any number then backspace for erase it then write c then Enter 😉
            And you can keep your C shortcut 😄
            • honoluludesktopH Offline
              honoluludesktop
              Are any other script.rb required to be installed in the plugin folder?
                Matt666
                Hi Didier !!
                One question : Is it possible to add an "undo" key inside the command ?
                Thank you !
                Frenglish at its best !
                My scripts
                • H Offline
                  Hazza
                  Do you know how easy this tool makes it to create pieces of wood for my models!!!! Hit D, enter 2 of the dimensions, click click, done.
                  That is awesome, thank you...
                  See all of my SketchUp models here.
                    Didier Bur
                    I can't get 'C' to work closing the loop - I have a short cur for circle that's 'c' so it dumps into that. Perhaps having something like shift+enter to close might do it ?
                    I noticed that also at the office on a standard install of SU, at home my PC doesn't have the "c" shortcut...
                    BTW, how to detect the Shift+enter keys pressed ?
                    I was thinking of a "x" shortcut instead but Shift+enter is more intuitive.
                    @honolulu: no, no additionnal files required. Maybe a glitch with the pushpull if you are on Mac ?
                    @Pilou: want always more, hey ? i'll try to do it...
                    DB
                      mike d
                      thanks
                      The grass is always GREENER on the roof.
                      • daikuD Offline
                        daiku
                        This is fantastic, Didier. I have one suggestion (for now 😄 😞 Each time the user hits the enter key to draw the walls so far, commit the operation so the wall sections can be undone one at a time. Thanks again, this is really useful. CB.
                        Clark Bremer
                        http://www.northernlightstimberframing.com
                          With some arcs now? 💚
                            Didier Bur
                            With some arcs now?
                            No no no. Ask TIG! 🤣
                            BTW, you can draw walls that include arcs with the "line2wall*.rb" scripts.
                            DB
                              Didier
                              Excellent idea - I was working on something similar, mine was called 'mline' - you beat me to it ! Well done.
                              I can't get 'C' to work closing the loop - I have a short cut for circle that's 'c' so it dumps into that. Perhaps having something like shift+enter to close might do it ?
                                @didier bur said:
                                The code is basically "if key1== enter AND key2== shift then..." For example
                                def onKeyDown(key,repeat,flags,view)
                                  @key="shift" if key==CONSTRAIN_MODIFIER_KEY
                                end#def
                                  Didier Bur
                                  Patch published today. Shortcut for "close" changed to "x" instead of "c".
                                  DB
                                    Damned I have x for X-Ray 💚
                                    So my previous trick will work fine again 😄
                                    Just write any number like 1
                                    then write x
                                    then Enter
                                    It's like Glen Gould but works 💚
                                      Didier
                                      Using "X" is a good choice: x is usually reserved for copying - e.g. x3 to make copies within other commands and isn't a shortcut... If like Pilou you want to use 'X' as a shortcut for something like X-ray you need to remember to use 3x for copies rather than x3, as the latter will invoke X-ray rather than make copies ! Persoanlly I use Alt+X for X-ray mode...
                                        cool little trick 🤓
                                        • F Offline
                                          Fletch
                                          Great work, Didier! Thanks so much for sharing!
                                          a couple little things:
                                          when I choose "show axis"... it does not show... whether or not I have it pop the wall up.
                                          After drawing a wall, I exit the tool, then I want to draw a double line vertically on a face, so I choose to use the tool again... set width to 12", no face, no close. I draw a vertical line from top edge to bottom edge of the wall face. I hit enter for it to draw the double line. I get this.
                                          Fletch
                                          Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                                            Ben Ritter
                                            Thank you very much Didier.
                                            • 1 / 5
