    [Plugin] Double line
    91 Posts 38 Posters 63.3k Views 38 Watching
    • Didier BurD Offline
      Didier Bur
      1/ Sometimes it refuses to make "walls" after tracing over existing lines.
      2/ Sometimes it it makes negative Z height.
      3/ Could the last parameters input be remembered?
      1/I know how to fix this. wait next release
      2/This happens when you draw a wall on an existing face. this is normal, the workaround is to ask for making a group in the dialog box, or create a group with the existing face you want to draw on.
      3/Yes. For now the tool only remembers prameters if you draw several walls without exiting it.
      P.S.: I guess a "close" option to come back to the very first point would be nice ?
      DB
        Matt666
        Hi Didier !
        Thank you for this another great plugin !!
        J'ai juste un petite question : Tu dois connaitre archicad ! L'outil de dessin de mur permet de modifier la justification du pan de mur que l'on va dessiner...
        I have a question for you : I suppose you know Archicad... In archicad, we have possibility of changing the justification while you are drawing the 2d wall...
        For example :
        Wall 1 = Justification "center"
        Wall 2 = Justification "Left"
        etc..
        In just one command !
        Is it possible to do that ?
        Frenglish at its best !
        My scripts
          marcosrodrigues
          Thank you, Didier!
          | menos é mais
            sepo
            Very useful...looking forward to next update. Thanks Didier.
            • arqpadaoA Offline
              arqpadao
              Hi Didier
              thanks, this is great.
              fernando padão
              arquiteto
              porto alegre - brasil
              http://arqpadao.blogspot.com
              • free agentF Offline
                free agent
                very handy, thanx!
                  Didier Bur
                  Some enhancemments added today. See top of post.
                  DB
                    @ Tig Same problem but ...
                    Just enter any number then backspace for erase it then write c then Enter 😉
                    And you can keep your C shortcut 😄
                    • honoluludesktopH Offline
                      honoluludesktop
                      Are any other script.rb required to be installed in the plugin folder?
                        Matt666
                        Hi Didier !!
                        One question : Is it possible to add an "undo" key inside the command ?
                        Thank you !
                        My scripts
                        • H Offline
                          Hazza
                          Do you know how easy this tool makes it to create pieces of wood for my models!!!! Hit D, enter 2 of the dimensions, click click, done.
                          That is awesome, thank you...
                          See all of my SketchUp models here.
                            Didier Bur
                            I can't get 'C' to work closing the loop - I have a short cur for circle that's 'c' so it dumps into that. Perhaps having something like shift+enter to close might do it ?
                            I noticed that also at the office on a standard install of SU, at home my PC doesn't have the "c" shortcut...
                            BTW, how to detect the Shift+enter keys pressed ?
                            I was thinking of a "x" shortcut instead but Shift+enter is more intuitive.
                            @honolulu: no, no additionnal files required. Maybe a glitch with the pushpull if you are on Mac ?
                            @Pilou: want always more, hey ? i'll try to do it...
                            DB
                              mike d
                              thanks
                              The grass is always GREENER on the roof.
                              • daikuD Offline
                                daiku
                                This is fantastic, Didier. I have one suggestion (for now 😄 😞 Each time the user hits the enter key to draw the walls so far, commit the operation so the wall sections can be undone one at a time. Thanks again, this is really useful. CB.
                                Clark Bremer
                                http://www.northernlightstimberframing.com
                                  With some arcs now? 💚
                                    Didier Bur
                                    With some arcs now?
                                    No no no. Ask TIG! 🤣
                                    BTW, you can draw walls that include arcs with the "line2wall*.rb" scripts.
                                    DB
                                      Didier
                                      Excellent idea - I was working on something similar, mine was called 'mline' - you beat me to it ! Well done.
                                      I can't get 'C' to work closing the loop - I have a short cut for circle that's 'c' so it dumps into that. Perhaps having something like shift+enter to close might do it ?
                                        @didier bur said:
                                        The code is basically "if key1== enter AND key2== shift then..." For example
                                        def onKeyDown(key,repeat,flags,view)
                                          @key="shift" if key==CONSTRAIN_MODIFIER_KEY
                                        end#def
                                          Didier Bur
                                          Patch published today. Shortcut for "close" changed to "x" instead of "c".
                                          DB
                                            Damned I have x for X-Ray 💚
                                            So my previous trick will work fine again 😄
                                            Just write any number like 1
                                            then write x
                                            then Enter
                                            It's like Glen Gould but works 💚
                                            • 1 / 5
