    [Plugin] Double line
    91 Posts 38 Posters 70.7k Views 38 Watching
      rv1974
      I was missing this tool. Many thanks indeed!
      Some minor problems:
      1/ Sometimes it refuses to make "walls" after tracing over existing lines.
      2/ Sometimes it it makes negative Z height.
      3/ Could the last parameters input be remembered?
      Could there be option to get vertical (along world z axis) not perpendicular "wall" to sloped face?...with sloped\terraced
      upper cap to keep average height? 😮
      • Didier BurD
        Didier Bur
        1/I know how to fix this. wait next release
        2/This happens when you draw a wall on an existing face. this is normal, the workaround is to ask for making a group in the dialog box, or create a group with the existing face you want to draw on.
        3/Yes. For now the tool only remembers prameters if you draw several walls without exiting it.
        P.S.: I guess a "close" option to come back to the very first point would be nice ?
        DB
          Matt666
          Hi Didier !
          Thank you for this another great plugin !!
          J'ai juste un petite question : Tu dois connaitre archicad ! L'outil de dessin de mur permet de modifier la justification du pan de mur que l'on va dessiner...
          I have a question for you : I suppose you know Archicad... In archicad, we have possibility of changing the justification while you are drawing the 2d wall...
          For example :
          Wall 1 = Justification "center"
          Wall 2 = Justification "Left"
          etc..
          In just one command !
          Is it possible to do that ?
          Frenglish at its best !
          My scripts
            marcosrodrigues
            Thank you, Didier!
            | menos é mais
              sepo
              Very useful...looking forward to next update. Thanks Didier.
              • arqpadaoA
                arqpadao
                Hi Didier
                thanks, this is great.
                fernando padão
                arquiteto
                porto alegre - brasil
                http://arqpadao.blogspot.com
                • free agentF
                  free agent
                  very handy, thanx!
                  http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                  • Didier BurD
                    Didier Bur
                    Some enhancemments added today. See top of post.
                    DB
                      @ Tig Same problem but ...
                      Just enter any number then backspace for erase it then write c then Enter 😉
                      And you can keep your C shortcut 😄
                      • honoluludesktopH
                        honoluludesktop
                        Are any other script.rb required to be installed in the plugin folder?
                          Matt666
                          Hi Didier !!
                          One question : Is it possible to add an "undo" key inside the command ?
                          Thank you !
                          My scripts
                          • H
                            Hazza
                            Do you know how easy this tool makes it to create pieces of wood for my models!!!! Hit D, enter 2 of the dimensions, click click, done.
                            That is awesome, thank you...
                            See all of my SketchUp models here.
                            • Didier BurD
                              Didier Bur
                              I can't get 'C' to work closing the loop - I have a short cur for circle that's 'c' so it dumps into that. Perhaps having something like shift+enter to close might do it ?
                              I noticed that also at the office on a standard install of SU, at home my PC doesn't have the "c" shortcut...
                              BTW, how to detect the Shift+enter keys pressed ?
                              I was thinking of a "x" shortcut instead but Shift+enter is more intuitive.
                              @honolulu: no, no additionnal files required. Maybe a glitch with the pushpull if you are on Mac ?
                              @Pilou: want always more, hey ? i'll try to do it...
                              DB
                                mike d
                                thanks
                                The grass is always GREENER on the roof.
                                • daikuD
                                  daiku
                                  This is fantastic, Didier. I have one suggestion (for now 😄 😞 Each time the user hits the enter key to draw the walls so far, commit the operation so the wall sections can be undone one at a time. Thanks again, this is really useful. CB.
                                  Clark Bremer
                                  http://www.northernlightstimberframing.com
                                    With some arcs now? 💚
                                    • Didier BurD
                                      Didier Bur
                                      With some arcs now?
                                      No no no. Ask TIG! 🤣
                                      BTW, you can draw walls that include arcs with the "line2wall*.rb" scripts.
                                      DB
                                        Didier
                                        Excellent idea - I was working on something similar, mine was called 'mline' - you beat me to it ! Well done.
                                        I can't get 'C' to work closing the loop - I have a short cut for circle that's 'c' so it dumps into that. Perhaps having something like shift+enter to close might do it ?
                                          @didier bur said:
                                          The code is basically "if key1== enter AND key2== shift then..." For example
                                          def onKeyDown(key,repeat,flags,view)
                                            @key="shift" if key==CONSTRAIN_MODIFIER_KEY
                                          end#def
                                          • Didier BurD
                                            Didier Bur
                                            Patch published today. Shortcut for "close" changed to "x" instead of "c".
                                            DB
                                            • 1 / 5
