    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.7m Views 202 Watching
    • CadFatherC Offline
      CadFather
      CadFather,
      For easier access to your set of icons and cursors, I edited the first message of this thread and attached the archive file.
      http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11212&st=0&sk=t&sd=a#p76625
      Fred
      oh..i'm honoured to have my name next to it! πŸ˜„
      • Z Offline
        zhuangsuph
        Thank youThank youThank you
          theolwakachangchang
          for some reason i cannot get the toolbar to show up???
          i only get this:
            CadFather
            make sure you have al the files in 'plugins'
            ZLoader__OnSurface.rb
            and the folder TOS_Dir_13 which contains the scripts and the toolbar icons
            • FrederikF Offline
              Frederik
              Isn't this because the script needs to be activated from the Extensions..?? πŸ˜•
              From the menu-bar click Window > Preferences, which will open the System Preferences window...
              Select Extensions and make sure the Tools on Surface is ticked... πŸ˜‰
              Now you shold be able to see the toolbar - that is if you've extracted the zip-file to the correct folder... πŸ˜‰
              Cheers
              Kim Frederik
                CadFather
                oh yes indeed that is the first thing πŸ˜›
                  theolwakachangchang
                  I believe I have all the necessary files. I have the ZLoader__OnSurface.rb and then in the TOS_Dir_13 folder I have 73 *.png files, 9 *.rb files, 1 *.def file and 2 manuals.... I have activated the script from extensions. I get all the options from the Tools on Surface section in the Tools pulldown, its just a pain not having a toolbar
                  Pretty sure I have installed and followed all the instructions correctly?
                  • fredo6F Offline
                    By chance, can you check in the menu View>Toolbar if you have a toolbar named "Surface Operations" and if it is checked.
                      theolwakachangchang
                      Yep, I have that checked.. that little 'dash thing' that shows up (as shown earlier in the image with the arrow) is what shows up when I have 'Surface Operations' checked
                        CadFather
                        in these cases i move all the plugins to another folder and keep only the troubling one.
                        give it a try if you still have a problem, redownload the plugin and re-try. if still no good you can try re-installing SU - wouldn't kow what else..
                          theolwakachangchang
                          πŸ˜† πŸ˜†
                          hmmmm turns out I found the problem... For some reason I had extracted the files into the tools directory instead of the plugins directory
                            CadFather
                            πŸ˜’ πŸ˜‰
                              renyiandhan
                              Amazing!!! Thanks!!!
                                agrazdi
                                Any news about the double line you mentioned for V1.4 ?
                                agrazdi
                                • fredo6F Offline
                                  This will come, but not before end of Sep (actually, it should do more than double, and on any contour). I did not spend a lot of time recently on Rubys, but should try to resume soon, with some work on Web dialogs as well.
                                  I also solved the question of generating faces when drawing lines on surfaces.
                                    BorgMan
                                    Well that's strange, I'm using the tool right now to offset from a shape on a curved face. However, for some reason it thinks that the object is part of the face too, and thus is offsetting over that face. That's (obviously) not what I want...
                                    More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
                                    You've gotta love Slivers.
                                    • fredo6F Offline
                                      Not sure I understand the problem.
                                      Just in case, there is an option 'Isolate surface when extending' which is mapped on F7 and also available in the contextual menu. This allows ignoring the surrounding surface when you offset.
                                        BorgMan
                                        Thanks Fredo; I'll try that next.
                                        I'm getting this error too. Is there anything I forgot to extract?
                                        Error Loading File LibOnSurface.rb
                                        uninitialized constant SUToolsOnSurface::TOS_DIRError Loading File LoaderOnSurface.rb
                                        No such file to load -- /LibTraductor_20.rbError Loading File ShapeOnSurface.rb
                                        uninitialized constant SUToolsOnSurface::CODE_Rectangle
                                        [EDIT] Hmmm... didn't work. The problem is that in the last screenshot, you can see a blue line that comes through the object (default color). That's the face I want to offset. When I do so, it thinks that that object is the same as the cilinder on which I am trying to offset. This results in a few lines on the cilinder (the grey area), but then all of a sudden the lines makes a strange turn, goes over the object (the default color thing), and when it touches the grey area again, it goes back to the beginning. I want that blue lined face to extrude, not anything else 😐
                                          jds
                                          Wow been busy rendering in Su im so Surprise on whats going on in skechup world!!!
                                          i really need to catchUp!!!
                                          manymany thanks to you fredo!!! i dont know you but your plugin rocks!!! πŸ‘
                                          i know few guys here from podium but not all.. hope to be part of your team.
                                          thanks and regards
                                          jds
                                          www.santosjdportfolio.blogspot.com
                                            dirkkkk
                                            I like te tool a lot.. but when I try to use I get a bug splat Avery time...
                                            Is it ma by because I am using 64bit pc???
                                            Hope someone can help
                                            • 31
                                            • 32
                                            • 6 / 32
