    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.9m Views 202 Watching
    • CadFatherC
      CadFather
      ..it would be great to have _16, _24 naming convention like TOS - but all in your own time of course πŸ˜‰
      • fredo6F
        CadFather,
        For easier access to your set of icons and cursors, I edited the first message of this thread and attached the archive file.
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11212&st=0&sk=t&sd=a#p76625
        Fred
        • F
          FkY
          Hello all, it's my first message here...
          Thanks to Fredo6 for this awesome plugin, it's very useful.
          I've just seen a little bug in the arc display. When you move an arc created with this plugin, the center point (displayed by a cross) doesn't move.
          It would be nice to have the tangent constraint when you create an arc after an other or a line to have a continuity.
          FkY_
          PS : sorry for my "garbage english", I do my best but...
          • fredo6F
            Not really a bug actually. the script just create a construction point for the arc center for convenience (as it should maybe in native Sketchup!). But the construction point is not really part of the arc and does not keep any connection with it afterward.
            Yes, that would be nice. On a Surface, it is however a little bit tricky, though probably feasible.
            • CadFatherC
              CadFather
              CadFather,
              Fred
              oh..i'm honoured to have my name next to it! πŸ˜„
              • Z
                zhuangsuph
                Thank youThank youThank you
                • T
                  theolwakachangchang
                  for some reason i cannot get the toolbar to show up???
                  i only get this:
                  • CadFatherC
                    CadFather
                    make sure you have al the files in 'plugins'
                    ZLoader__OnSurface.rb
                    and the folder TOS_Dir_13 which contains the scripts and the toolbar icons
                    • FrederikF
                      Frederik
                      Isn't this because the script needs to be activated from the Extensions..?? πŸ˜•
                      From the menu-bar click Window > Preferences, which will open the System Preferences window...
                      Select Extensions and make sure the Tools on Surface is ticked... πŸ˜‰
                      Now you shold be able to see the toolbar - that is if you've extracted the zip-file to the correct folder... πŸ˜‰
                      Cheers
                      Kim Frederik
                      • CadFatherC
                        CadFather
                        oh yes indeed that is the first thing πŸ˜›
                        • T
                          theolwakachangchang
                          I believe I have all the necessary files. I have the ZLoader__OnSurface.rb and then in the TOS_Dir_13 folder I have 73 *.png files, 9 *.rb files, 1 *.def file and 2 manuals.... I have activated the script from extensions. I get all the options from the Tools on Surface section in the Tools pulldown, its just a pain not having a toolbar
                          Pretty sure I have installed and followed all the instructions correctly?
                          • fredo6F
                            By chance, can you check in the menu View>Toolbar if you have a toolbar named "Surface Operations" and if it is checked.
                            • T
                              theolwakachangchang
                              Yep, I have that checked.. that little 'dash thing' that shows up (as shown earlier in the image with the arrow) is what shows up when I have 'Surface Operations' checked
                              • CadFatherC
                                CadFather
                                in these cases i move all the plugins to another folder and keep only the troubling one.
                                give it a try if you still have a problem, redownload the plugin and re-try. if still no good you can try re-installing SU - wouldn't kow what else..
                                • T
                                  theolwakachangchang
                                  πŸ˜† πŸ˜†
                                  hmmmm turns out I found the problem... For some reason I had extracted the files into the tools directory instead of the plugins directory
                                  • CadFatherC
                                    CadFather
                                    πŸ˜’ πŸ˜‰
                                      renyiandhan
                                      Amazing!!! Thanks!!!
                                        agrazdi
                                        Any news about the double line you mentioned for V1.4 ?
                                        agrazdi
                                        • fredo6F
                                          This will come, but not before end of Sep (actually, it should do more than double, and on any contour). I did not spend a lot of time recently on Rubys, but should try to resume soon, with some work on Web dialogs as well.
                                          I also solved the question of generating faces when drawing lines on surfaces.
                                          • B
                                            BorgMan
                                            Well that's strange, I'm using the tool right now to offset from a shape on a curved face. However, for some reason it thinks that the object is part of the face too, and thus is offsetting over that face. That's (obviously) not what I want...
                                            More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
                                            You've gotta love Slivers.
                                            • 31
                                            • 32
                                            • 6 / 32
