    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.8m Views 202 Watching
    • CadFatherC Offline
      CadFather
      Hi Fredo, i don't think this same 16/24 system applies to bezier as well - had a look at the scripts but cannot locate/attempt how to make the switch automatic..any pointers would be great..
      • F Offline
        fixzigma
        Thankss
        • fredo6F Offline
          No, Bezierspline is an old script now, but I plan to refresh it at some point in time.
          This being said, it would be relatively simple to make just the modification about icons. Let me think about it.
            CadFather
            ..it would be great to have _16, _24 naming convention like TOS - but all in your own time of course πŸ˜‰
            • fredo6F Offline
              CadFather,
              For easier access to your set of icons and cursors, I edited the first message of this thread and attached the archive file.
              http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11212&st=0&sk=t&sd=a#p76625
              Fred
              • F Offline
                FkY
                Hello all, it's my first message here...
                Thanks to Fredo6 for this awesome plugin, it's very useful.
                I've just seen a little bug in the arc display. When you move an arc created with this plugin, the center point (displayed by a cross) doesn't move.
                It would be nice to have the tangent constraint when you create an arc after an other or a line to have a continuity.
                FkY_
                PS : sorry for my "garbage english", I do my best but...
                • fredo6F Offline
                  Not really a bug actually. the script just create a construction point for the arc center for convenience (as it should maybe in native Sketchup!). But the construction point is not really part of the arc and does not keep any connection with it afterward.
                  Yes, that would be nice. On a Surface, it is however a little bit tricky, though probably feasible.
                    CadFather
                    CadFather,
                    Fred
                    oh..i'm honoured to have my name next to it! πŸ˜„
                    • Z Offline
                      zhuangsuph
                      Thank youThank youThank you
                        theolwakachangchang
                        for some reason i cannot get the toolbar to show up???
                        i only get this:
                          CadFather
                          make sure you have al the files in 'plugins'
                          ZLoader__OnSurface.rb
                          and the folder TOS_Dir_13 which contains the scripts and the toolbar icons
                          • FrederikF Offline
                            Frederik
                            Isn't this because the script needs to be activated from the Extensions..?? πŸ˜•
                            From the menu-bar click Window > Preferences, which will open the System Preferences window...
                            Select Extensions and make sure the Tools on Surface is ticked... πŸ˜‰
                            Now you shold be able to see the toolbar - that is if you've extracted the zip-file to the correct folder... πŸ˜‰
                            Cheers
                            Kim Frederik
                              CadFather
                              oh yes indeed that is the first thing πŸ˜›
                                theolwakachangchang
                                I believe I have all the necessary files. I have the ZLoader__OnSurface.rb and then in the TOS_Dir_13 folder I have 73 *.png files, 9 *.rb files, 1 *.def file and 2 manuals.... I have activated the script from extensions. I get all the options from the Tools on Surface section in the Tools pulldown, its just a pain not having a toolbar
                                Pretty sure I have installed and followed all the instructions correctly?
                                • fredo6F Offline
                                  By chance, can you check in the menu View>Toolbar if you have a toolbar named "Surface Operations" and if it is checked.
                                    theolwakachangchang
                                    Yep, I have that checked.. that little 'dash thing' that shows up (as shown earlier in the image with the arrow) is what shows up when I have 'Surface Operations' checked
                                      CadFather
                                      in these cases i move all the plugins to another folder and keep only the troubling one.
                                      give it a try if you still have a problem, redownload the plugin and re-try. if still no good you can try re-installing SU - wouldn't kow what else..
                                        theolwakachangchang
                                        πŸ˜† πŸ˜†
                                        hmmmm turns out I found the problem... For some reason I had extracted the files into the tools directory instead of the plugins directory
                                          CadFather
                                          πŸ˜’ πŸ˜‰
                                            renyiandhan
                                            Amazing!!! Thanks!!!
                                            • 31
                                            • 32
                                            • 6 / 32
