    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.8m Views 202 Watching
      Some more easy and confortable now 😎
      • CadFatherC
        CadFather
        Hi Fredo, i don't think this same 16/24 system applies to bezier as well - had a look at the scripts but cannot locate/attempt how to make the switch automatic..any pointers would be great..
        • F
          fixzigma
          Thankss
          • fredo6F
            No, Bezierspline is an old script now, but I plan to refresh it at some point in time.
            This being said, it would be relatively simple to make just the modification about icons. Let me think about it.
            • CadFatherC
              CadFather
              ..it would be great to have _16, _24 naming convention like TOS - but all in your own time of course πŸ˜‰
              • fredo6F
                CadFather,
                For easier access to your set of icons and cursors, I edited the first message of this thread and attached the archive file.
                http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11212&st=0&sk=t&sd=a#p76625
                Fred
                • F
                  FkY
                  Hello all, it's my first message here...
                  Thanks to Fredo6 for this awesome plugin, it's very useful.
                  I've just seen a little bug in the arc display. When you move an arc created with this plugin, the center point (displayed by a cross) doesn't move.
                  It would be nice to have the tangent constraint when you create an arc after an other or a line to have a continuity.
                  FkY_
                  PS : sorry for my "garbage english", I do my best but...
                  • fredo6F
                    Not really a bug actually. the script just create a construction point for the arc center for convenience (as it should maybe in native Sketchup!). But the construction point is not really part of the arc and does not keep any connection with it afterward.
                    Yes, that would be nice. On a Surface, it is however a little bit tricky, though probably feasible.
                    • CadFatherC
                      CadFather
                      CadFather,
                      Fred
                      oh..i'm honoured to have my name next to it! πŸ˜„
                      • Z
                        zhuangsuph
                        Thank youThank youThank you
                        • T
                          theolwakachangchang
                          for some reason i cannot get the toolbar to show up???
                          i only get this:
                          • CadFatherC
                            CadFather
                            make sure you have al the files in 'plugins'
                            ZLoader__OnSurface.rb
                            and the folder TOS_Dir_13 which contains the scripts and the toolbar icons
                            • FrederikF
                              Frederik
                              Isn't this because the script needs to be activated from the Extensions..?? πŸ˜•
                              From the menu-bar click Window > Preferences, which will open the System Preferences window...
                              Select Extensions and make sure the Tools on Surface is ticked... πŸ˜‰
                              Now you shold be able to see the toolbar - that is if you've extracted the zip-file to the correct folder... πŸ˜‰
                              Cheers
                              Kim Frederik
                              • CadFatherC
                                CadFather
                                oh yes indeed that is the first thing πŸ˜›
                                • T
                                  theolwakachangchang
                                  I believe I have all the necessary files. I have the ZLoader__OnSurface.rb and then in the TOS_Dir_13 folder I have 73 *.png files, 9 *.rb files, 1 *.def file and 2 manuals.... I have activated the script from extensions. I get all the options from the Tools on Surface section in the Tools pulldown, its just a pain not having a toolbar
                                  Pretty sure I have installed and followed all the instructions correctly?
                                  • fredo6F
                                    By chance, can you check in the menu View>Toolbar if you have a toolbar named "Surface Operations" and if it is checked.
                                    • T
                                      theolwakachangchang
                                      Yep, I have that checked.. that little 'dash thing' that shows up (as shown earlier in the image with the arrow) is what shows up when I have 'Surface Operations' checked
                                      • CadFatherC
                                        CadFather
                                        in these cases i move all the plugins to another folder and keep only the troubling one.
                                        give it a try if you still have a problem, redownload the plugin and re-try. if still no good you can try re-installing SU - wouldn't kow what else..
                                        • T
                                          theolwakachangchang
                                          πŸ˜† πŸ˜†
                                          hmmmm turns out I found the problem... For some reason I had extracted the files into the tools directory instead of the plugins directory
                                          • CadFatherC
                                            CadFather
                                            πŸ˜’ πŸ˜‰
                                            • 31
                                            • 32
                                            • 6 / 32
