    [Plugin] Zorro
    53 Posts 34 Posters 65.4k Views 34 Watching
    • W Offline
      Whaat
      @pixero said:
      Edit: After a quick test it seem to cut "all the way" so my next question is: Whould it be possible to limit it to only cut on faces visible in the viewport or facing the camera?
      I can think of many cases when I would want it to work like that.
      I think the best workaround for this, is to first group the geometry that you wish to cut, then use the tool. Only geometry within the active context will be cut. After you have done your cuts, you can explode the group if you wish to return to the previous condition.
        linea
        I love this tool! Thanks for improving my game!
        • H Offline
          huyvuvn
          when I install this script into my desktop (Pentium 4 2,4Ghz, 512Mb RAM, Radeon 9600) , it works good.
          but when I install into my laptop (Dell XPS M1710), it can not work and have bug. I've tried the simple rectangle and "zorro" it but it "booooom" and sketchup out ! 😕 😲
          help me resolve this problem ! I'm very interested in this script "zorro" but now I can not use it with my laptop. 😞
          many thanks 😛
          happiness on the way, not in the destination.
          • N Offline
            NORTH_FROST
            Amazing ❗
            This will come in use 👍
            http://www.northfrost.se
            • Mike LuceyM Offline
              Mike Lucey
              I'm 'telling' Bryce on you guys!!!!
              Great work Whaat, cheers 😉
              Mike
              • david_hD Offline
                david_h
                Gracias Senor Zorro. . .the people of my village will be forever Grateful.
                • Y Offline
                  yuwoang
                  thank you !!!!!
                    Dn1
                    Thank you whaat...you are the best!! 😍 😍 😍
                    Kind regards
                    D@n!
                      justry
                      Cool!! 😍
                      But it doesn't work in parallel projection!!??? 😞
                      • wzfwzfwzfW Offline
                        wzfwzfwzf
                        If can use the arc, was better。呵呵
                        • free agentF Offline
                          free agent
                          hey just wanted to know if this tools is going to be updated, this tool and knife in subdivide and smooth will always crash my drawing without fail, it seems to not like like anything thats bigger than a fresh drawing.
                            davereap
                            Ive had this script working ok ..then all it does is splat out..
                            However its a fault with your model somewhere. Try grouping your model and locking it.
                            zorrro will now work on any new bits you make...As an exercise it would be worth grouping and locking in sections to find what is causing the splat.Hopefully when youve grouped the problem area zorro will get working again...
                            ........ Dave Reap
                              mbntex
                              I am new to this tool, but it seems great! Can you use Zorro on parts that are in different visible components at once, or do you need to explode them to cut them together?
                              • W Offline
                                Whaat
                                you need to explode them. Only the faces inside the component you are currently editing will be cut.
                                • F Offline
                                  flyashy
                                  A beautiful, extremely useful and aptly titled script, Whaat.
                                  Thank You.
                                  Since you mentioned that you're not going to be working on this anymore, just wanted to inquire if anyone was doing anything with it to resolve the parallel projection usability. That would increase the usability of this tenfold or more.
                                  I wouldn't mind doing it but I don't know anything about rb, except to use them 😄
                                  Ta,
                                  Ashy
                                  • W Offline
                                    wheay
                                    pls help me. i need this tool badly. it wont work for me. how do you install this. i just put it in to the plugins folder just like the others. but this dont work. pls. help this is what i need. thanks.
                                    "i try to learn everyday"
                                    http://designerslandmark.blogspot.com/
                                    • W Offline
                                      Whaat
                                      Did you check your 'tools' menu? 😄
                                      • W Offline
                                        wheay
                                        oppsssss! stupid me. 🤣
                                        i thought it was on the view toolbar. sorry for that. thanks.
                                        i love this one. 😍
                                          kjc
                                          I'm happy to find this tool, realy nice! I have no idea how you create such impressive things, respect.
                                          This tool could be even better if it could work in parallel projection. Are youstill working on it or not?
                                          • W Offline
                                            Whaat
                                            My commercial script 'Subdivide and Smooth' http://www.smustard.com/script/SubdivideAndSmooth
                                            has a tool identical to Zorro but it also works in parallel projection mode (and it snaps to axis)
                                            I hope to release an update to Zorro sometime in 2009 that works in parallel projection mode, but you might be waiting quite awhile.
                                            Dale
                                            • 2 / 3
