    [Plugin] Zorro
    53 Posts 34 Posters 70.2k Views 34 Watching
    • W
      Whaat
      @jim said:
      I get this error:
      > C;/Program Files/Google/Google SketchUp 6/Plugins/Zorro.rb;26;in `activate'
      > C;/Program Files/Google/Google SketchUp 6/Plugins/Zorro.rb;220;in `select_tool'
      > C;/Program Files/Google/Google SketchUp 6/Plugins/Zorro.rb;220;in `zorrotool'
      > C;/Program Files/Google/Google SketchUp 6/Plugins/Zorro.rb;226
      > C;/Program Files/Google/Google SketchUp 6/Plugins/Zorro.rb;226;in `call'
      > Error; #<NoMethodError; undefined method `GetString' for nil;NilClass>
      > C;/Program Files/Google/Google SketchUp 6/Plugins/Zorro.rb;74;in `onLButtonDown'
      That's what happens when you cut and paste from the example scripts! Try deleting '$exStrings.GetString' from the two offending lines of code (line 74 and 163)
      Let me know if that does the trick.
      • K
        kwistenbiebel
        I don't know zip about coding....but I like this line for some reason πŸ˜„.
        Freud is always around when you need him ...
        • W
          Whaat
          @pixero said:
          Edit: After a quick test it seem to cut "all the way" so my next question is: Whould it be possible to limit it to only cut on faces visible in the viewport or facing the camera?
          I can think of many cases when I would want it to work like that.
          I think the best workaround for this, is to first group the geometry that you wish to cut, then use the tool. Only geometry within the active context will be cut. After you have done your cuts, you can explode the group if you wish to return to the previous condition.
          • L
            linea
            I love this tool! Thanks for improving my game!
            • H
              huyvuvn
              when I install this script into my desktop (Pentium 4 2,4Ghz, 512Mb RAM, Radeon 9600) , it works good.
              but when I install into my laptop (Dell XPS M1710), it can not work and have bug. I've tried the simple rectangle and "zorro" it but it "booooom" and sketchup out ! πŸ˜• 😲
              help me resolve this problem ! I'm very interested in this script "zorro" but now I can not use it with my laptop. 😞
              many thanks πŸ˜›
              happiness on the way, not in the destination.
              • N
                NORTH_FROST
                Amazing ❗
                This will come in use πŸ‘
                http://www.northfrost.se
                • Mike LuceyM
                  Mike Lucey
                  I'm 'telling' Bryce on you guys!!!!
                  Great work Whaat, cheers πŸ˜‰
                  Mike
                  • david_hD
                    david_h
                    Gracias Senor Zorro. . .the people of my village will be forever Grateful.
                    • Y
                      yuwoang
                      thank you !!!!!
                        Dn1
                        Thank you whaat...you are the best!! 😍 😍 😍
                        Kind regards
                        D@n!
                          justry
                          Cool!! 😍
                          But it doesn't work in parallel projection!!??? 😞
                          • wzfwzfwzfW
                            wzfwzfwzf
                            If can use the arc, was better。呡呡
                            • free agentF
                              free agent
                              hey just wanted to know if this tools is going to be updated, this tool and knife in subdivide and smooth will always crash my drawing without fail, it seems to not like like anything thats bigger than a fresh drawing.
                              http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                                davereap
                                Ive had this script working ok ..then all it does is splat out..
                                However its a fault with your model somewhere. Try grouping your model and locking it.
                                zorrro will now work on any new bits you make...As an exercise it would be worth grouping and locking in sections to find what is causing the splat.Hopefully when youve grouped the problem area zorro will get working again...
                                ........ Dave Reap
                                  mbntex
                                  I am new to this tool, but it seems great! Can you use Zorro on parts that are in different visible components at once, or do you need to explode them to cut them together?
                                  • W
                                    Whaat
                                    you need to explode them. Only the faces inside the component you are currently editing will be cut.
                                    • F
                                      flyashy
                                      A beautiful, extremely useful and aptly titled script, Whaat.
                                      Thank You.
                                      Since you mentioned that you're not going to be working on this anymore, just wanted to inquire if anyone was doing anything with it to resolve the parallel projection usability. That would increase the usability of this tenfold or more.
                                      I wouldn't mind doing it but I don't know anything about rb, except to use them πŸ˜„
                                      Ta,
                                      Ashy
                                      • W
                                        wheay
                                        pls help me. i need this tool badly. it wont work for me. how do you install this. i just put it in to the plugins folder just like the others. but this dont work. pls. help this is what i need. thanks.
                                        "i try to learn everyday"
                                        http://designerslandmark.blogspot.com/
                                        • W
                                          Whaat
                                          Did you check your 'tools' menu? πŸ˜„
                                          • W
                                            wheay
                                            oppsssss! stupid me. 🀣
                                            i thought it was on the view toolbar. sorry for that. thanks.
                                            i love this one. 😍
                                            • 2 / 3
