    [Plugin] Zorro
    53 Posts 34 Posters 67.9k Views 34 Watching
      1. binding Red, Blue, Green works when you are in view Top, Front...
      Funny script indeed ☀
      Whaat you see is whaat you get 😉
        rv1974
        It shines Whaat!
        But a few things MUST be repaired\added:
        1. Work in ortho projection, axis following (mentioned above)
        2. Problems with snapping.
          remus
          Another big thanks from me, and if it hasnt been said enough i cant wait for subdivide+smooth.
            kwistenbiebel
            I tried Zorro on a higher poly model (the naked man I posted earlier) but Sketchup crashes .
            It's not the ruby's fault (great coding whaat !) ...it's just sketchup I guess 😢
              Jim
              I get this error:
              C;/Program Files/Google/Google SketchUp 6/Plugins/Zorro.rb;26;in `activate'
              C;/Program Files/Google/Google SketchUp 6/Plugins/Zorro.rb;220;in `select_tool'
              C;/Program Files/Google/Google SketchUp 6/Plugins/Zorro.rb;220;in `zorrotool'
              C;/Program Files/Google/Google SketchUp 6/Plugins/Zorro.rb;226
              C;/Program Files/Google/Google SketchUp 6/Plugins/Zorro.rb;226;in `call'
              Error; #<NoMethodError; undefined method `GetString' for nil;NilClass>
              C;/Program Files/Google/Google SketchUp 6/Plugins/Zorro.rb;74;in `onLButtonDown'
              • W Offline
                Whaat
                @jim said:
                I get this error:
                That's what happens when you cut and paste from the example scripts! Try deleting '$exStrings.GetString' from the two offending lines of code (line 74 and 163)
                Let me know if that does the trick.
                  kwistenbiebel
                  I don't know zip about coding....but I like this line for some reason 😄.
                  Freud is always around when you need him ...
                  • W Offline
                    Whaat
                    @pixero said:
                    Edit: After a quick test it seem to cut "all the way" so my next question is: Whould it be possible to limit it to only cut on faces visible in the viewport or facing the camera?
                    I can think of many cases when I would want it to work like that.
                    I think the best workaround for this, is to first group the geometry that you wish to cut, then use the tool. Only geometry within the active context will be cut. After you have done your cuts, you can explode the group if you wish to return to the previous condition.
                      linea
                      I love this tool! Thanks for improving my game!
                      • H Offline
                        huyvuvn
                        when I install this script into my desktop (Pentium 4 2,4Ghz, 512Mb RAM, Radeon 9600) , it works good.
                        but when I install into my laptop (Dell XPS M1710), it can not work and have bug. I've tried the simple rectangle and "zorro" it but it "booooom" and sketchup out ! 😕 😲
                        help me resolve this problem ! I'm very interested in this script "zorro" but now I can not use it with my laptop. 😞
                        many thanks 😛
                        happiness on the way, not in the destination.
                        • N Offline
                          NORTH_FROST
                          Amazing ❗
                          This will come in use 👍
                          http://www.northfrost.se
                          • Mike LuceyM Offline
                            Mike Lucey
                            I'm 'telling' Bryce on you guys!!!!
                            Great work Whaat, cheers 😉
                            Mike
                            • david_hD Offline
                              david_h
                              Gracias Senor Zorro. . .the people of my village will be forever Grateful.
                              • Y Offline
                                yuwoang
                                thank you !!!!!
                                  Dn1
                                  Thank you whaat...you are the best!! 😍 😍 😍
                                  Kind regards
                                  D@n!
                                    justry
                                    Cool!! 😍
                                    But it doesn't work in parallel projection!!??? 😞
                                    • wzfwzfwzfW Offline
                                      wzfwzfwzf
                                      If can use the arc, was better。呵呵
                                      • free agentF Offline
                                        free agent
                                        hey just wanted to know if this tools is going to be updated, this tool and knife in subdivide and smooth will always crash my drawing without fail, it seems to not like like anything thats bigger than a fresh drawing.
                                          davereap
                                          Ive had this script working ok ..then all it does is splat out..
                                          However its a fault with your model somewhere. Try grouping your model and locking it.
                                          zorrro will now work on any new bits you make...As an exercise it would be worth grouping and locking in sections to find what is causing the splat.Hopefully when youve grouped the problem area zorro will get working again...
                                          ........ Dave Reap
                                            mbntex
                                            I am new to this tool, but it seems great! Can you use Zorro on parts that are in different visible components at once, or do you need to explode them to cut them together?
                                            • 2 / 3
