    [Plugin] Zorro
    53 Posts 34 Posters 69.8k Views 34 Watching
      kwistenbiebel
      I tried Zorro on a higher poly model (the naked man I posted earlier) but Sketchup crashes .
      It's not the ruby's fault (great coding whaat !) ...it's just sketchup I guess 😢
        Jim
        I get this error:
        C;/Program Files/Google/Google SketchUp 6/Plugins/Zorro.rb;26;in `activate'
        C;/Program Files/Google/Google SketchUp 6/Plugins/Zorro.rb;220;in `select_tool'
        C;/Program Files/Google/Google SketchUp 6/Plugins/Zorro.rb;220;in `zorrotool'
        C;/Program Files/Google/Google SketchUp 6/Plugins/Zorro.rb;226
        C;/Program Files/Google/Google SketchUp 6/Plugins/Zorro.rb;226;in `call'
        Error; #<NoMethodError; undefined method `GetString' for nil;NilClass>
        C;/Program Files/Google/Google SketchUp 6/Plugins/Zorro.rb;74;in `onLButtonDown'
        • W Offline
          Whaat
          @jim said:
          I get this error:
          That's what happens when you cut and paste from the example scripts! Try deleting '$exStrings.GetString' from the two offending lines of code (line 74 and 163)
          Let me know if that does the trick.
            kwistenbiebel
            I don't know zip about coding....but I like this line for some reason 😄.
            Freud is always around when you need him ...
            • W Offline
              Whaat
              @pixero said:
              Edit: After a quick test it seem to cut "all the way" so my next question is: Whould it be possible to limit it to only cut on faces visible in the viewport or facing the camera?
              I can think of many cases when I would want it to work like that.
              I think the best workaround for this, is to first group the geometry that you wish to cut, then use the tool. Only geometry within the active context will be cut. After you have done your cuts, you can explode the group if you wish to return to the previous condition.
                linea
                I love this tool! Thanks for improving my game!
                • H Offline
                  huyvuvn
                  when I install this script into my desktop (Pentium 4 2,4Ghz, 512Mb RAM, Radeon 9600) , it works good.
                  but when I install into my laptop (Dell XPS M1710), it can not work and have bug. I've tried the simple rectangle and "zorro" it but it "booooom" and sketchup out ! 😕 😲
                  help me resolve this problem ! I'm very interested in this script "zorro" but now I can not use it with my laptop. 😞
                  many thanks 😛
                  happiness on the way, not in the destination.
                  • N Offline
                    NORTH_FROST
                    Amazing ❗
                    This will come in use 👍
                    http://www.northfrost.se
                    • Mike LuceyM Offline
                      Mike Lucey
                      I'm 'telling' Bryce on you guys!!!!
                      Great work Whaat, cheers 😉
                      Mike
                      • david_hD Offline
                        david_h
                        Gracias Senor Zorro. . .the people of my village will be forever Grateful.
                        • Y Offline
                          yuwoang
                          thank you !!!!!
                            Dn1
                            Thank you whaat...you are the best!! 😍 😍 😍
                            Kind regards
                            D@n!
                              justry
                              Cool!! 😍
                              But it doesn't work in parallel projection!!??? 😞
                              • wzfwzfwzfW Offline
                                wzfwzfwzf
                                If can use the arc, was better。呵呵
                                • free agentF Offline
                                  free agent
                                  hey just wanted to know if this tools is going to be updated, this tool and knife in subdivide and smooth will always crash my drawing without fail, it seems to not like like anything thats bigger than a fresh drawing.
                                  http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                                    davereap
                                    Ive had this script working ok ..then all it does is splat out..
                                    However its a fault with your model somewhere. Try grouping your model and locking it.
                                    zorrro will now work on any new bits you make...As an exercise it would be worth grouping and locking in sections to find what is causing the splat.Hopefully when youve grouped the problem area zorro will get working again...
                                    ........ Dave Reap
                                      mbntex
                                      I am new to this tool, but it seems great! Can you use Zorro on parts that are in different visible components at once, or do you need to explode them to cut them together?
                                      • W Offline
                                        Whaat
                                        you need to explode them. Only the faces inside the component you are currently editing will be cut.
                                        • F Offline
                                          flyashy
                                          A beautiful, extremely useful and aptly titled script, Whaat.
                                          Thank You.
                                          Since you mentioned that you're not going to be working on this anymore, just wanted to inquire if anyone was doing anything with it to resolve the parallel projection usability. That would increase the usability of this tenfold or more.
                                          I wouldn't mind doing it but I don't know anything about rb, except to use them 😄
                                          Ta,
                                          Ashy
                                          • W Offline
                                            wheay
                                            pls help me. i need this tool badly. it wont work for me. how do you install this. i just put it in to the plugins folder just like the others. but this dont work. pls. help this is what i need. thanks.
                                            "i try to learn everyday"
                                            http://designerslandmark.blogspot.com/
                                            • 2 / 3
