    [Plugin] Zorro
    53 Posts 34 Posters 70.2k Views 34 Watching
    • wzfwzfwzfW
      wzfwzfwzf
      If can use the arc, was better。呡呡
      • free agentF
        free agent
        hey just wanted to know if this tools is going to be updated, this tool and knife in subdivide and smooth will always crash my drawing without fail, it seems to not like like anything thats bigger than a fresh drawing.
        http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
          davereap
          Ive had this script working ok ..then all it does is splat out..
          However its a fault with your model somewhere. Try grouping your model and locking it.
          zorrro will now work on any new bits you make...As an exercise it would be worth grouping and locking in sections to find what is causing the splat.Hopefully when youve grouped the problem area zorro will get working again...
          ........ Dave Reap
            mbntex
            I am new to this tool, but it seems great! Can you use Zorro on parts that are in different visible components at once, or do you need to explode them to cut them together?
            • W
              Whaat
              you need to explode them. Only the faces inside the component you are currently editing will be cut.
              • F
                flyashy
                A beautiful, extremely useful and aptly titled script, Whaat.
                Thank You.
                Since you mentioned that you're not going to be working on this anymore, just wanted to inquire if anyone was doing anything with it to resolve the parallel projection usability. That would increase the usability of this tenfold or more.
                I wouldn't mind doing it but I don't know anything about rb, except to use them πŸ˜„
                Ta,
                Ashy
                • W
                  wheay
                  pls help me. i need this tool badly. it wont work for me. how do you install this. i just put it in to the plugins folder just like the others. but this dont work. pls. help this is what i need. thanks.
                  "i try to learn everyday"
                  http://designerslandmark.blogspot.com/
                  • W
                    Whaat
                    Did you check your 'tools' menu? πŸ˜„
                    • W
                      wheay
                      oppsssss! stupid me. 🀣
                      i thought it was on the view toolbar. sorry for that. thanks.
                      i love this one. 😍
                      • K
                        kjc
                        I'm happy to find this tool, realy nice! I have no idea how you create such impressive things, respect.
                        This tool could be even better if it could work in parallel projection. Are youstill working on it or not?
                        • W
                          Whaat
                          My commercial script 'Subdivide and Smooth' http://www.smustard.com/script/SubdivideAndSmooth
                          has a tool identical to Zorro but it also works in parallel projection mode (and it snaps to axis)
                          I hope to release an update to Zorro sometime in 2009 that works in parallel projection mode, but you might be waiting quite awhile.
                          Dale
                          • CadFatherC
                            CadFather
                            Hi Dale - that would be great!
                            • W
                              Whaat
                              Be on the lookout for an update to Zorro coming very soon...
                              It's gonna be good.... πŸ˜‰ πŸ˜„
                              • CadFatherC
                                CadFather
                                can't wait to see what diego de la vega has been up to...
                                cheers Whaat!
                                • E
                                  evrnaidu
                                  It's great! It will be more useful if the divided parts are grouped so that unwanted portion could be deleted easily. Of course it is difficult to make it as two parts when components are nested. If that is the case, grouping may be done within the components.
                                  • GaieusG
                                    Hi Evr (and welcome),
                                    Check out Zorro 2 then:
                                    http://forums.sketchucation.com/viewtopic.php?t=16038
                                    • It "resides" in the context (right click) menu of a section plane (so easy to set up)
                                    • It will actually cut through all nested groups/components
                                    • Finally it actually deletes what is behind (invisibly) the section plane.
                                      %(#BF0000)[So be extra careful to only use it
                                      on a copy of your model!]
                                    • E
                                      evrnaidu
                                      Thank you Mr. Gaius. It really works fantastically.
                                      • GaieusG
                                        Now combine it with SectionCutFace and you can fill in those ugly holes.
                                        http://forums.sketchucation.com/viewtopic.php?t=20564
                                          How do you use the section Cut face with this sort of inclined cut face?
                                          Cut first with Zorro2, then ?
                                          Pilou.skp
                                            magpie
                                            Thanks Dale, really like the plugin and for simple geometry no problem, but on a more complex model I use zorro2 and it either bugsplats or sketchup simply disappears from my screen πŸ˜•
                                            Any modelling errors I should be careful of? It's a model made in skp8 and exported to skp6...any help appreciated.
                                            • 2 / 3
