[REQ] Displacement ruby
Your examples are highly convincing solo. I'm all support for a displacement ruby. It seems you already have it however.. how did you create those models?
I used a third party app, Vue 6 xstream and used the displacement feature, then baked it to polygons and exported it as .3ds.
The workflow is a little tedious and was hoping that if we could apply a texture to a given surface then select the surface and have an option to 'turn to mesh' which would then through the miracle coding of someone like Whaat become a 3d mesh with an option to reduce the polys if neccesary (already a ruby)Just thoughts .... dreams.
Another example.
getting the pixel (RGB) value from the texture at a given point. If anyone knows how do this, let me know.
some ideas:
convert texture to .raw and read it via ruby file commands (as I did it in 2004 Terolscript)
direct image parsing - too complicated (several formats, compression)
server based - image upload to server, converted to an Array and returned back to Ruby
solo, let me tell you, that your illustrations are impressive. it makes perfectly clear, what you want to achieve with that script and what the benefits are.
I would love to have such a ruby.
like you said:@solo said:
...but for other purposes like if you remember Silvershadows method of doing a cobble stone sidewalk, this would be a snap.
this would really help to push realism of SketchUp models much further (towards "Silvershadow-realism"...
OMG, I would SO pay for this, so long as it is not server based.
It's a nice idea.
However, I think current Sketchup will have difficulties with the polycount.I rather see some advanced uv-mapping tools to get displacement maps on complexer surfaces so we can render displacement with the photoreal render engine of choice.
But I can understand a displacement2mesh plugin could be useful to people that want to see the displacement in their default Sketchup output.
What about Didier's heightfield generator script here:- http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_geo_page.htm
The documentation is here:- http://www.crai.archi.fr/RubyLibraryDepot/Ruby/Heightfield_gen.pdfI tried it because I wanted to generate a rippled water plane, but couldn't get it to work at all. As they say however, "your mileage may vary".
I didn't know there was a ruby script like that.Thank you for the link Bigstick.
I just tried using Didiers script (heightfield.rb), but it doesn't do anything at all in my case.
I converted a greyscaled displacement .jpg texture to a Ascii .pgm pixel image in Xnview (as suggested in the tutorial) and tried to load it through the ruby. Maybe I am doing something wrong, but I couldn't get it to generate geometry out of it.As the ruby was created in 2004, maybe it isn't adapted to sketchup 6?
Didier, thank you
i have such problem with loading pgm(in skp 5):
i attach imagesFormat; P2 (PGM) Width; 828 x Height; 177 Greyscale; 256 levels. Number of points; 16 Empty mesh initialized. Mesh altitude range; 100.0 Patch Length X; 0.0476058993229746 Patch Width Y; 0.223693629205114 Altitude Step Z; 0.392156862745098 Create group; Yes Destination layer; Layer0 Error; #<NoMethodError; undefined method `*' for nil;NilClass> (eval);196;in `hf_create_points' (eval);193;in `upto' (eval);193;in `hf_create_points' (eval);181;in `upto' (eval);181;in `hf_create_points' (eval);28;in `hf_gen' (eval);324 (eval);324;in `call'
anybodies know any kind console convertor bmp2ansipgm or raw?
add: i use total commander addition - image lister by ivory
Irfanview can do it, and it's a free app.
it is not, you are right. But it could be (one line of code to change...)
I'm testing it right now. But it is sooooo sloooow !
This kind of feature requests a C++ prog IMHO.
Hi Ilayk,
The error comes from that the options providers have changed from SU5 to SU6.
If you decrypted the script, go to line 110:
u = opt[3][2]
and change it to:
u = opt[0][2]That's all, it will work after that,
strange
it's same(can't normally get size of mesh...)Format; P2 (PGM) Width; 1680 x Height; 1509 Greyscale; 256 levels. Number of points; 16 Empty mesh initialized. Mesh altitude range; 100.0 Patch Length X; 23.4485281358547 Patch Width Y; 26.1074792706233 Altitude Step Z; 0.392156862745098 Create group; Yes Destination layer; Layer0 Error; #<NoMethodError; undefined method `*' for nil;NilClass> D;/Program Files/gsu6/Plugins/heightfield_gen.rb;196;in `hf_create_points' D;/Program Files/gsu6/Plugins/heightfield_gen.rb;193;in `upto' D;/Program Files/gsu6/Plugins/heightfield_gen.rb;193;in `hf_create_points' D;/Program Files/gsu6/Plugins/heightfield_gen.rb;181;in `upto' D;/Program Files/gsu6/Plugins/heightfield_gen.rb;181;in `hf_create_points' D;/Program Files/gsu6/Plugins/heightfield_gen.rb;28;in `hf_gen' D;/Program Files/gsu6/Plugins/heightfield_gen.rb;324 D;/Program Files/gsu6/Plugins/heightfield_gen.rb;324;in `call' -
Ok I forgot this one, line 190:
def hf_create_points opt = Sketchup.active_model.options # u = opt[3][2] Version 5 u = opt[0][2] # Version 6 ...
again >>Empty mesh initialized. / when i load pgm
and errors in opened console(same)
i attach latest images
i modify as you wrote/but it doesn't work
Just checking to see if maybe the heightfield ruby got fixed so it works with SU6 now.
I saw some pieces of code in this thread.
Are we supposed to put those lines in the existing ruby file? ...and will it work? -
Didier, I'm happy to try to modify this script, but first I need to know how to decrypt it.
Could you possibly give me some more information and I'll try it.Pity TBD is somewhat occupied just now, else I'm sure he would look at it
I think, Didier can do it, so wait his solution
Wow have to keep my eye on this one! I'm all for poly over displacement - being a maxwell user I would rather manage my layers in SU than quadruple my render times using displacement!!!!
Looking forward to some news on this!
how should i convert a jpg into pgm?
e.g. with irfanview, i have to select "save as"?
