    [REQ] Displacement ruby
    32 Posts 14 Posters 5.9k Views 14 Watching
    • soloS Offline
      Ilay7k, for landscapes and terrains it would be an SU killer for sure, but for other purposes like if you remember Silvershadows method of doing a cobble stone sidewalk, this would be a snap.
      It can also be used for product modeling where only one or two surfaces needs a physical relief.
      How about this use?
      http://img413.imageshack.us/img413/5622/planeju8.jpg
      • soloS Offline
        As mentioned above, cobblestones or such mesh could be achieved using a simple bump image and if you have a seamles image like below then a small or low poly mesh can be generated which can be made into a component and tiled to form a cobble road as below without killing the model.
        The image:
        http://img214.imageshack.us/img214/6815/cobblebumpzg3.jpg
        The resulting mesh:
        http://img228.imageshack.us/img228/7590/cobbl1qpc3.jpg
        The mesh made into a component and tiled:
        http://img214.imageshack.us/img214/1857/cobbledisplacementkq5.jpg
          princedragoncok
          Your examples are highly convincing solo. I'm all support for a displacement ruby. It seems you already have it however.. how did you create those models?
          • soloS Offline
            I used a third party app, Vue 6 xstream and used the displacement feature, then baked it to polygons and exported it as .3ds.
            The workflow is a little tedious and was hoping that if we could apply a texture to a given surface then select the surface and have an option to 'turn to mesh' which would then through the miracle coding of someone like Whaat become a 3d mesh with an option to reduce the polys if neccesary (already a ruby)
            Just thoughts .... dreams.
            Another example.
            http://img296.imageshack.us/img296/6533/weavean9.jpg
            • tbdT Offline
              tbd
              getting the pixel (RGB) value from the texture at a given point. If anyone knows how do this, let me know.
              some ideas:
              1. convert texture to .raw and read it via ruby file commands (as I did it in 2004 Terolscript)
              2. direct image parsing - too complicated (several formats, compression)
              3. server based - image upload to server, converted to an Array and returned back to Ruby
              http://plugins.ro
              • plot-parisP Offline
                plot-paris
                solo, let me tell you, that your illustrations are impressive. it makes perfectly clear, what you want to achieve with that script and what the benefits are.
                I would love to have such a ruby.
                like you said:
                @solo said:
                ...but for other purposes like if you remember Silvershadows method of doing a cobble stone sidewalk, this would be a snap.
                this would really help to push realism of SketchUp models much further (towards "Silvershadow-realism"... 😄 )
                • jujuJ Offline
                  juju
                  OMG, I would SO pay for this, so long as it is not server based.
                    kwistenbiebel
                    It's a nice idea.
                    However, I think current Sketchup will have difficulties with the polycount.
                    I rather see some advanced uv-mapping tools to get displacement maps on complexer surfaces so we can render displacement with the photoreal render engine of choice.
                    But I can understand a displacement2mesh plugin could be useful to people that want to see the displacement in their default Sketchup output.
                    • bigstickB Offline
                      bigstick
                      What about Didier's heightfield generator script here:- http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_geo_page.htm
                      The documentation is here:- http://www.crai.archi.fr/RubyLibraryDepot/Ruby/Heightfield_gen.pdf
                      I tried it because I wanted to generate a rippled water plane, but couldn't get it to work at all. As they say however, "your mileage may vary".
                        kwistenbiebel
                        I didn't know there was a ruby script like that.Thank you for the link Bigstick.
                        I just tried using Didiers script (heightfield.rb), but it doesn't do anything at all in my case.
                        I converted a greyscaled displacement .jpg texture to a Ascii .pgm pixel image in Xnview (as suggested in the tutorial) and tried to load it through the ruby. Maybe I am doing something wrong, but I couldn't get it to generate geometry out of it.
                        As the ruby was created in 2004, maybe it isn't adapted to sketchup 6?
                        • I Offline
                          ilay7k
                          Didier, thank you
                          i have such problem with loading pgm(in skp 5):
                          i attach images
                          Format; P2 (PGM) Width; 828 x Height; 177 Greyscale; 256 levels.
                          Number of points; 16
                          Empty mesh initialized.
                          Mesh altitude range; 100.0
                          Patch Length X; 0.0476058993229746
                          Patch Width Y; 0.223693629205114
                          Altitude Step Z; 0.392156862745098
                          Create group; Yes
                          Destination layer; Layer0
                          Error; #<NoMethodError; undefined method `*' for nil;NilClass>
                          (eval);196;in `hf_create_points'
                          (eval);193;in `upto'
                          (eval);193;in `hf_create_points'
                          (eval);181;in `upto'
                          (eval);181;in `hf_create_points'
                          (eval);28;in `hf_gen'
                          (eval);324
                          (eval);324;in `call'
                          anybodies know any kind console convertor bmp2ansipgm or raw?
                          add: i use total commander addition - image lister by ivory
                          • soloS Offline
                            Irfanview can do it, and it's a free app.
                            IrfanView - Official Homepage - One of the Most Popular Viewers Worldwide
                            IrfanView ... one of the most popular viewers worldwide.
                            (www.irfanview.com)
                            • Didier BurD Offline
                              Didier Bur
                              it is not, you are right. But it could be (one line of code to change...)
                              I'm testing it right now. But it is sooooo sloooow !
                              This kind of feature requests a C++ prog IMHO.100x100 pixels -> 19600 faces, execution time: 2mn (!)
                              DB
                                Didier Bur
                                Hi Ilayk,
                                The error comes from that the options providers have changed from SU5 to SU6.
                                If you decrypted the script, go to line 110:
                                u = opt[3][2]
                                and change it to:
                                u = opt[0][2]
                                That's all, it will work after that,
                                DB
                                • I Offline
                                  ilay7k
                                  strange
                                  it's same(can't normally get size of mesh...)
                                  Format; P2 (PGM) Width; 1680 x Height; 1509 Greyscale; 256 levels.
                                  Patch Length X; 23.4485281358547
                                  Patch Width Y; 26.1074792706233
                                  Create group; Yes
                                  D;/Program Files/gsu6/Plugins/heightfield_gen.rb;196;in `hf_create_points'
                                  D;/Program Files/gsu6/Plugins/heightfield_gen.rb;193;in `upto'
                                  D;/Program Files/gsu6/Plugins/heightfield_gen.rb;193;in `hf_create_points'
                                  D;/Program Files/gsu6/Plugins/heightfield_gen.rb;181;in `upto'
                                  D;/Program Files/gsu6/Plugins/heightfield_gen.rb;181;in `hf_create_points'
                                  D;/Program Files/gsu6/Plugins/heightfield_gen.rb;28;in `hf_gen'
                                  D;/Program Files/gsu6/Plugins/heightfield_gen.rb;324
                                  D;/Program Files/gsu6/Plugins/heightfield_gen.rb;324;in `call'
                                    Didier Bur
                                    Ok I forgot this one, line 190:
                                    def hf_create_points
                                    opt = Sketchup.active_model.options
                                    # u = opt[3][2] Version 5
                                    u = opt[0][2] # Version 6
                                    DB
                                    • I Offline
                                      ilay7k
                                      again >>Empty mesh initialized. / when i load pgm
                                      and errors in opened console(same)
                                      i attach latest images
                                      i modify as you wrote/but it doesn't work
                                      Imagename1.rar
                                        kwistenbiebel
                                        Just checking to see if maybe the heightfield ruby got fixed so it works with SU6 now.
                                        I saw some pieces of code in this thread.
                                        Are we supposed to put those lines in the existing ruby file? ...and will it work?
                                        • bigstickB Offline
                                          bigstick
                                          Didier, I'm happy to try to modify this script, but first I need to know how to decrypt it.
                                          Could you possibly give me some more information and I'll try it.
                                          Pity TBD is somewhat occupied just now, else I'm sure he would look at it 😉
                                          • I Offline
                                            ilay7k
                                            I think, Didier can do it, so wait his solution
