    Join Tool?
    16 Posts 12 Posters 14.3k Views 12 Watching
    • W Offline
      wyatt
      Intersect w/ model. And then Hide or Erase the lines at the intersection.
      Wyatt
        Autokidd
        Ya but see the problem is there are quite a few interestions and we would like it to automatically fix the intersections like sketchup sometimes does when you put two faces together using a push and pull. To do them all would take days clicking each individual intersection
        • Chris FullmerC Offline
          Is it curvy? or is it pretty straight. It might be easier to remake it using components if the shapes are repetitive.
            Autokidd
            Just a flat wall with a lot of intersecting mullions that need a solution lol
              I think you remake it using components the fit together w/o showing a seam. I had made a tutorial right after your first post. I'll go ahead and post it in case its helpful. It starts by showing how to clean up the intersection manually, then shows how to make seamless components. It might be helpful. Check it out. The part on making the component starts around scene 5 I think.
              Or you know, Rick Wilson has a windowizer script available from Smustard.com you could probably check out. It might rebuild the wall in just a few seconds. The script is free.
              Also, if you could upload the model that would be helpful too. Good luck!
              cross cleanup.skp
              • plot-parisP Offline
                plot-paris
                another (very dirty) way is to select the whole geometry, right click > intersect selected
                now it is all one piece of geometry. the only thing you have to do is selecting the lot again, right click > soften/smooth edges.
                make sure to check the "soften coplanar" check box. put the slider between 20 or 30 and all the unwanted edges will be invisible (note, that they are not erased, but simply smoothed - therefore Chris' way with components is definitely the cleaner and more preferable one 😉 )
                  You could try Lattice-izer ruby script. You draw the centre-lines of the pattern required (lines and arcs on a coplanar face), group everything and run it - fill in the dialog. You'll get an open lattice or lattice with panes as chosen. If it's to fit inside a hole you need to apply an offset to the face first as all lattice members are centre-lined...
                  I've attached a 'tutorial' and a copy of Latticizer.rb...
                  Latticeizer.rb
                  LatticeExample.skp
                    rv1974
                    Hi TIG!
                    Unfortunatly lattisizer proceeds groups with multiple faces like a... "multiple offseter".
                    On single plane everything fine.
                      @rv1974 said:
                      Hi TIG!
                      Unfortunatly lattisizer processess groups with multiple faces like a... "multiple offseter".
                      With Latticeizer if you give the frame a zero depth and it does what you want...
                      • Jean LemireJ Offline
                        Jean Lemire
                        Hi Autokidd, hi folks.
                        Maybe you can do it in 2D. Then it is quick and easy to use Window select to delete inside lines after intersecting. Pull in 3D as the last step.
                        See attached SU file for ideas.
                        Cross with 2x4.skp
                        • boofredlayB Offline
                          boofredlay
                          I see nobody has mentioned the Windowizer:
                          http://members.cox.net/rick.wilson/
                          I know you are asking how to fix mullions that have already been placed but in the future this should prove invaluable for you. It has for me and many others.
                          • I Offline
                            ideas_arte
                            Thank you very, very, very much...!
                            • X Offline
                              xrok1
                              would it be possible to break latticizer into its own thread, its always so hard to find and point new users to?
                              • takesh hT Offline
                                takesh h
                                What about BoolTools by Whaat?
                                http://forums.sketchucation.com/viewtopic.php?f=180&t=15134&st=0&sk=t&sd=a&hilit=BoolTools
                                Without any pics, it's so easy to misunderstand what the original questioner wanted though.
                                What I figured is in the pic below.
                                Or use deletecoplanaredges.rb by J. Dolabany.
                                http://www.crai.archi.fr/RubyLibraryDepot/Ruby/en_edi_page.htm
                                Implement it from right click context menu.
                                  Ruturaj
                                  Thanks .................
                                  Thanks,
                                  RuturaJ
