    [Plugin] Round Edge - v1.0 (by Bezier)
    166 Posts 83 Posters 163.9k Views 83 Watching
      Ben Ritter
      Fredo,
      Thank you very much.
        cnicolapc
        Thank You very much.
        • fredo6F Offline
          @kmead said:
          I do have a quibble which may or may not be shared by all:
          The intersection of the rounded edges should meet in a semi-spherical intersection when three arcs meet at a corner, versus the hipped or groined intersection that is now occurring.
          I think it would be manageable to make a 'polished, round' join for 3 edges, whatever is their orientation. It's probably a geometrical headache, but the method would be mathematically exact, and imply no surface intersection.
          This is simply based on the remark that if the 3 edges are mutually orthogonal, as in a cube, you can draw a spherical join. Then, because you can always transform geometrically 3 edges with any orientations into orthogonal axes (via 3 plane shear transformations), you could deform the join as well with these transformations. This would give a junction with no groined intersection. This would work for 2 edges too.
          For 4 edges or more, I am not sure there is a geometrical shear transformation, preserving parallels, that could allow to transform them into a regular topology. But maybe I am wrong!
          Anyway, this is just for future work, but it's an interesting idea to explore.
            ScottPara
            I tried the ruby and I am impressed just in the time savings involved. My question is why is it still making hard corners? The far cube is from the script the closest one is using the longer method of rounding the profile the extruding and then rounding the top and bottom flats. Am I missing something, as I thought this is what the result I would have got fromt he script.
            Scott
            Love the fact that some HATE my avatar.....
            • fredo6F Offline
              As said in my previous post, I need to check if it's manageable when edges have any orientation (I think it is), and also confirm that it only works for intersection of 2 or 3 edges only, not more.
              Note also that the 'true' rounding generate much more faces at the corners.
              The initial version was more a trial and is closer to the spirit of a FollowMe. The interest, in my mind, is that it should be capable to handle custom profiles, allowing to decorate edges with profiled shapes. It also helped me to check how Sketchup handles surface intersections (which you can see is not always perfect, due to precision problems).
              So, don't worry, I keep the request in my list.
                ScottPara
                Thanks Fredo!
                  marne
                  Wow! Thanks for this great plugin! This is a true little helper. πŸ˜„
                  • I Offline
                    ilay7k
                    how many editions of sketchup 7 are...one of is Fredo6Up πŸ˜‰
                    Thank you for this Tool!
                    • I Offline
                      Iglesias
                      Thanks a lot Fredo
                        alphaonerecon
                        Hello
                        I'm new to SketchUp and just installed the bezier plug-in.
                        I am having drastically different results from everyone here so I
                        am clearly doing something wrong.
                        I followed the instructions, which are pretty straightforward, correctly but seem to be
                        missing something.
                        I have enclosed before and after pics of a simple box I attempted to round the corners
                        on.
                        When I applied the tool, this is what happened as a result.
                        I'm assuming it may have something to do with the pref' box that pops up once the tool is used?
                        Is the rounding automatic? Do I have to input data for it to work?
                        Please help this newbie!
                        Thanks! 😳
                        before
                        after
                          alphaonerecon
                          Issue solved.
                            remus
                            Could i ask what the problem was?
                            • Alan FraserA Offline
                              Alan Fraser
                              It looks like the dims for the round edge may have been much bigger than the actual object.
                              3D Figures
                              • JClementsJ Offline
                                JClements
                                I love the "intuitiveness" of your tools. Thank you.
                                So far my experimentation has only turned up the following: It seems the "left-over" vertical edges from the rounded corner are left remaining. However, at least in simple models, they are easy enough to erase.
                                John
                                See the red-colored vertical edges
                                • fredo6F Offline
                                  John
                                  In this version 1.0, I preferred to keep a non-destructive approach, because the few investigations I had made showed me that the clean up must be handle with subtle care in order to avoid messing up the model. In simples cases, it is anyway relatively easy to do the cleanup by hand.
                                  So this should be for a further version.
                                    mikaztro
                                    Thanks for this plugin Fredo! πŸ˜„
                                    • F Offline
                                      Fletch
                                      Thank you, Fredo! You hard work is very much appreciated!!!
                                      Fletch
                                      Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                                      • ely862meE Offline
                                        ely862me
                                        in about 1 minute
                                        boat on a lake using round edge
                                        Elisei (sketchupper)
                                        Come and See EliseiDesign
                                        • plot-parisP Offline
                                          plot-paris
                                          After spending two days at the Google office in Boulder last week and then seeing your remark, I can't help but chuckle softly. πŸ˜’
                                          first Csaba let slip one of those ambiguous remarks; and now you. seems that something is coming up soon... 😲
                                            What I let slip is already published by Google actually. But yes, I am also hopeful for a cool, new version.
                                            • 9 / 9
