    [Plugin] Round Edge - v1.0 (by Bezier)
    166 Posts 83 Posters 180.8k Views 83 Watching
      marne
      Wow! Thanks for this great plugin! This is a true little helper. πŸ˜„
      • I Offline
        ilay7k
        how many editions of sketchup 7 are...one of is Fredo6Up πŸ˜‰
        Thank you for this Tool!
        • I Offline
          Iglesias
          Thanks a lot Fredo
            alphaonerecon
            Hello
            I'm new to SketchUp and just installed the bezier plug-in.
            I am having drastically different results from everyone here so I
            am clearly doing something wrong.
            I followed the instructions, which are pretty straightforward, correctly but seem to be
            missing something.
            I have enclosed before and after pics of a simple box I attempted to round the corners
            on.
            When I applied the tool, this is what happened as a result.
            I'm assuming it may have something to do with the pref' box that pops up once the tool is used?
            Is the rounding automatic? Do I have to input data for it to work?
            Please help this newbie!
            Thanks! 😳
            before
            after
              alphaonerecon
              Issue solved.
                remus
                Could i ask what the problem was?
                • Alan FraserA Offline
                  Alan Fraser
                  It looks like the dims for the round edge may have been much bigger than the actual object.
                  3D Figures
                  • JClementsJ Offline
                    JClements
                    I love the "intuitiveness" of your tools. Thank you.
                    So far my experimentation has only turned up the following: It seems the "left-over" vertical edges from the rounded corner are left remaining. However, at least in simple models, they are easy enough to erase.
                    John
                    See the red-colored vertical edges
                    • fredo6F Offline
                      John
                      In this version 1.0, I preferred to keep a non-destructive approach, because the few investigations I had made showed me that the clean up must be handle with subtle care in order to avoid messing up the model. In simples cases, it is anyway relatively easy to do the cleanup by hand.
                      So this should be for a further version.
                        mikaztro
                        Thanks for this plugin Fredo! πŸ˜„
                        • FletchF Offline
                          Fletch
                          Thank you, Fredo! You hard work is very much appreciated!!!
                          Fletch
                          • ely862meE Offline
                            ely862me
                            in about 1 minute
                            boat on a lake using round edge
                            Elisei (sketchupper)
                            Come and See EliseiDesign
                            • plot-parisP Offline
                              plot-paris
                              After spending two days at the Google office in Boulder last week and then seeing your remark, I can't help but chuckle softly. πŸ˜’
                              first Csaba let slip one of those ambiguous remarks; and now you. seems that something is coming up soon... 😲
                                What I let slip is already published by Google actually. But yes, I am also hopeful for a cool, new version.
                                  JClements
                                  Understood, Fredo.
                                  Oh, and I would like to commend you on how you name your zip-file downloads. Makes management of updates MUCH EASIER!
                                    dolphus
                                    Thanx for the ruby much appreciated i will use it a great deal in my drawings 😍
                                      BorgMan
                                      Allright, I have this BIG model (6.79mb per half) on which I want to unleash the tool. Will the filesize (and thus the controlability) suffer under it when I do so? Attached is a screencap of the model. Note that it's only half of it, and that the bridge and nacelles are addad after I'm done, which would mean a further increase in filesize. Next to that, it's probable that I will be deleting some of it's interior (yeah, it's got interior, I went completely nuts with it) to tone down the filesize.
                                      So, people have been saying that adding a bevel to the model would be wise. But would it be in this case? Or would the model become uncontrolable? Some advice would be appreciated πŸ˜„
                                      More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
                                      You've gotta love Slivers.
                                        remus
                                        Depends more on the face count of the thing really.
                                        My suggestion would to be quite select on your use of the bevel tool, using it only where its needed to add to the realism of the model.
                                        Its also possible to control the number of segments the tool uses in the bevel, so i suppose if your careful with that you could go pretty wild with it.
                                        Bottom line: bevel everything and it will become very unwieldy, try and go half way between beveling and no beveling.
                                          PRSS
                                          Fantastic Fredo! The script is great - straight away started using it.
                                          It'll become my most used script.
                                          Thank you for the script
                                          With best regards
                                          PRSS
                                            javy
                                            wowo~~ this is just what i want!
                                            thanks! 😍
                                            • 2 / 9
