    [Plugin] Round Edge - v1.0 (by Bezier)
    166 Posts 83 Posters 184.8k Views 83 Watching
    • boofredlayB
      boofredlay
      Thank you!
      • urgenU
        urgen
        ...CO-O-O-O-O-O-O-O-O-O-O-O-OL! πŸ‘ πŸŽ‰ πŸ˜„
        http://img181.imageshack.us/img181/2699/100lr0.jpg
        http://img181.imageshack.us/img181/3900/101vl6.jpg
        100.skp
        --pupil forever...------
          A cousin of TopMod? πŸ˜‰
          • urgenU
            urgen
            ...standart shape (components)+Round Edge - v1.0 ...delete some faces πŸ˜‰ πŸ˜„
            • StinkieS
              Stinkie
              Thank you! Very cool.
              • B
                breezmisha
                (= all try not wait! thanks great! 😍
                • B
                  Ben Ritter
                  Fredo,
                  Thank you very much.
                  • C
                    cnicolapc
                    Thank You very much.
                    • fredo6F
                      @kmead said:
                      I do have a quibble which may or may not be shared by all:
                      The intersection of the rounded edges should meet in a semi-spherical intersection when three arcs meet at a corner, versus the hipped or groined intersection that is now occurring.
                      I think it would be manageable to make a 'polished, round' join for 3 edges, whatever is their orientation. It's probably a geometrical headache, but the method would be mathematically exact, and imply no surface intersection.
                      This is simply based on the remark that if the 3 edges are mutually orthogonal, as in a cube, you can draw a spherical join. Then, because you can always transform geometrically 3 edges with any orientations into orthogonal axes (via 3 plane shear transformations), you could deform the join as well with these transformations. This would give a junction with no groined intersection. This would work for 2 edges too.
                      For 4 edges or more, I am not sure there is a geometrical shear transformation, preserving parallels, that could allow to transform them into a regular topology. But maybe I am wrong!
                      Anyway, this is just for future work, but it's an interesting idea to explore.
                        ScottPara
                        I tried the ruby and I am impressed just in the time savings involved. My question is why is it still making hard corners? The far cube is from the script the closest one is using the longer method of rounding the profile the extruding and then rounding the top and bottom flats. Am I missing something, as I thought this is what the result I would have got fromt he script.
                        Scott
                        Love the fact that some HATE my avatar.....
                        • fredo6F
                          As said in my previous post, I need to check if it's manageable when edges have any orientation (I think it is), and also confirm that it only works for intersection of 2 or 3 edges only, not more.
                          Note also that the 'true' rounding generate much more faces at the corners.
                          The initial version was more a trial and is closer to the spirit of a FollowMe. The interest, in my mind, is that it should be capable to handle custom profiles, allowing to decorate edges with profiled shapes. It also helped me to check how Sketchup handles surface intersections (which you can see is not always perfect, due to precision problems).
                          So, don't worry, I keep the request in my list.
                            ScottPara
                            Thanks Fredo!
                              marne
                              Wow! Thanks for this great plugin! This is a true little helper. πŸ˜„
                              • I
                                ilay7k
                                how many editions of sketchup 7 are...one of is Fredo6Up πŸ˜‰
                                Thank you for this Tool!
                                • I
                                  Iglesias
                                  Thanks a lot Fredo
                                    alphaonerecon
                                    Hello
                                    I'm new to SketchUp and just installed the bezier plug-in.
                                    I am having drastically different results from everyone here so I
                                    am clearly doing something wrong.
                                    I followed the instructions, which are pretty straightforward, correctly but seem to be
                                    missing something.
                                    I have enclosed before and after pics of a simple box I attempted to round the corners
                                    on.
                                    When I applied the tool, this is what happened as a result.
                                    I'm assuming it may have something to do with the pref' box that pops up once the tool is used?
                                    Is the rounding automatic? Do I have to input data for it to work?
                                    Please help this newbie!
                                    Thanks! 😳
                                    before
                                    after
                                      alphaonerecon
                                      Issue solved.
                                        remus
                                        Could i ask what the problem was?
                                        • Alan FraserA
                                          Alan Fraser
                                          It looks like the dims for the round edge may have been much bigger than the actual object.
                                          3D Figures
                                          • JClementsJ
                                            JClements
                                            I love the "intuitiveness" of your tools. Thank you.
                                            So far my experimentation has only turned up the following: It seems the "left-over" vertical edges from the rounded corner are left remaining. However, at least in simple models, they are easy enough to erase.
                                            John
                                            See the red-colored vertical edges
                                            • 2 / 9
