    [Obsolete] Tools On Surface - v1.1
    92 Posts 49 Posters 34.6k Views 49 Watching
    • H Offline
      HFM
      You are saving lives and time here, thanks a bunch πŸ‘
      • soloS Offline
        Just gave me another toy, I mean tool. πŸ‘
        3 minutes to make.
        http://img174.imageshack.us/img174/9439/crackedupyc4.jpg
        • erikBE Offline
          erikB
          fredo,this is unbelievable, but drawing lines on surfaces is just the tool I needed !!!!
          What can I say, thanks veryyyyyyyy much. 😍
          erikB
            remus
            always nice to come home to another plugin, especially a surprise one. Cheers fred, keep up the good work.
              Daniel S
              Awesome like always!!! 😍 😍 😍
              Thank You!!!
              Daniel S
                remus
                http://farm4.static.flickr.com/3151/2486502204_190c833716_o.jpg
                if you squint a lot it almost looks like the great wall fo china πŸ‘
                Anywya, it was 5 mins and made entirely using ferd06 plugins.
                p.s. i reckon theres reasonable call for having a seperate menu in SU called fred06 πŸ˜„
                  remus
                  Wheres the file macs?
                    Macs
                    ops, I've lost the attachment on previous post.. now it's there
                      Macs
                      Hi Fredo! Your tools are fantastic! πŸ‘
                      I think i found a problem while I was playing with the line tool:
                      I've attcached this simple model
                      draw a plane line with your tool from the lower vertex of the segment
                      up in vertical. The result line will be connected to the upper circle
                      and not to the starting vertex.
                      The same does not happen with the costruction line.
                      cylinder.skp
                      • I Offline
                        ilay7k
                        Wonderful magic of tools, thank you!!!
                        • fredo6F Offline
                          I am not totally clear on what happened to you.
                          What is sure is that when the surfaces contains planes which are perpendicular, the interpretation of a path on the surface is always ambiguous.
                          • MALAISEM Offline
                            MALAISE
                            😍 Ausgezeichnet, excellent, great what y've done.
                            MALAISE
                            La Connaissance n'a de valeur que partagΓ©e
                            • fredo6F Offline
                              3 minutes to make.
                              Solo,
                              very nice illustration of what you can do by combining JPP and the Tools on Surface.
                              Would you mind if I take the picture and put it in the documentation?
                                Macs
                                Here 2 images of what I'm tring
                                first one select plane tool and tring to draw a verical line, before mouse click
                                second one is what i get after the mouse click
                                • fredo6F Offline
                                  Macs,
                                  I understand. This is due to a problem in Sketchup when you create a curve made of edges on an existing edge (you can check this is the case when you generate in a group and then explode). I'll try to fix it.
                                  By default, the script generates curves for each line drawn. If you deactivate this option (key F9), it works correctly.
                                  • soloS Offline
                                    Absolutely fred.
                                      mateo soletic
                                      Fred, Thanks a lot, great tool.πŸ‘
                                      Concept Illustrations
                                      • MarianM Offline
                                        Marian
                                        😍 REALLY COOOL TOOL
                                        • boofredlayB Offline
                                          boofredlay
                                          Dang, I am having a hard time keeping up with all the new toys.
                                          Coolness πŸ€“
                                            glenn
                                            Thank you!!!!!
                                            Glenn
                                            • 1 / 5
