    Importing .stl files
    30 Posts 12 Posters 11.1k Views 12 Watching
    • C
      cdubea
      @watkins said:
      Dear Chris,
      Let me know how you get on. I use Inventor myself, and would really like an .iges export option for Sketchup. I like to mass model in Sketchup because it is so quick and easy (creative juices and all that).
      I recently tried importing a Swagelok coupling as a .dwf file (downloaded from the web) and it sort of worked (needed a lot of cleaning up, and the remaking of faces).
      Regards,
      Bob
      I really didn't have much success. Attached is a zip file with a 3d pdf of the part I exported from SolidWorks, the .stl file and the resulting Sketchup file.
      You can see the results leave something to be desired.
      chris
      RMH.zip
      http://www.dubea.org/chris_small.jpg
      • W
        watkins
        Dear Chris,
        As you say, disappointing.
        Did you see the link to SpaceClaim posted a few days ago?
        Invalid URL
        (www.spaceclaim.com)
        Regards,
        Bob
        • C
          cdubea
          @watkins said:
          Dear Chris,
          Invalid URL
          Regards,
          Bob
          I'm familiar with SpaceClaim. Michael Payne was one of the architects of SolidWorks many years ago and left when Dassault Systemes bought SolidWorks. I've been involved with SolidWorks since '96.
          The pricing on the LT version is very reasonable. If I'm not mistaken, the pro version is done on a perpetual lease basis. It's a nominal fee up front with an annual fee to use the software.
          • W
            watkins
            Dear Chris,
            Thanks for the additional information. I will request a quote for the LT version and consider using it as a mechanical design alternative to Sketchup. I will check to see if SpaceClaim LT will export .sat, .stp and .igs formatted files.
            Regards,
            Bob
            • Didier BurD
              Didier Bur
              Hi cdubea,
              with rmh.skp, I got the following message in the console:
              Error: #<ArgumentError: Not enough points - at least 3 required>
              If you open the stl file in a text editor, you'll see that coordinates are given in scientific notation (vertex 4.613638e+000 2.150841e+000 7.951958e-002 for instance). That doesn't disturb Ruby, but values are very small, this may be the problem (with SU autosnap feature I guess).
              An intersting test would be to scale your original model by 1000 or 10000, re-export the stl and see what's happening then when importing in SU.
              Regards,
              DB
              • C
                cdubea
                @didier bur said:
                Hi cdubea,
                An interesting test would be to scale your original model by 1000 or 10000, re-export the stl and see what's happening then when importing in SU.
                Regards,
                No problem. I'll give it a try and report back.
                chris
                • C
                  cdubea
                  @didier bur said:
                  Hi cdubea,
                  Regards,
                  Looks much better.
                  Thanks for making this available.
                  Wire Mold.zip
                    sorgesu
                    Didier,
                    I was so happy to find this script for IMPORTING STL and provide it to one of my students who was desperate. She told me I was a "Goddess". I confer it back on to you, you are a God.
                    However, I lost my status fast. The script worked as a far as asking for a unit of measure, and then it proceeded to do nothing. It didn't even seem to try and provided no error message.
                    I've attached the files which she sent to me.
                    Can you help?
                    Many thanks.
                    PowerPlant-AllParts.zip
                    PowerPlant-ExteriorComponents.zip
                    Susan Sorger
                    Former Seller Hand Rendered Entourage
                    Former Canadian Authorized Training Centre, SketchUp
                    • Didier BurD
                      Didier Bur
                      Hi Susan,
                      Your STL files are BINARY, and su2stl can only read ASCII.
                      Get an ascii version of these files and it will work !
                      Almost all exporters that I know (Autocad, etc) can export ascii stl files.
                      I've translated your binaries into ascii with stl_util which can be downloaded here:
                      http://www.ptcuser.org/rugs/U52/downloads/index.html (works also on XP,Vista...)
                      See attached ZIP
                      Regards (and don't loose your status ๐Ÿ˜‰ )
                      P.S. Reading ascii files can be long. I've updated the script so it now displays the number of triangles processed and the total number to convert.
                      In the Zip you'll find the 2 ascii versions of your STL and the 2 corresponding SKP
                      Replaces old version. Put it in Plugins folder.
                      DB
                        sorgesu
                        You are not just a God, you are top God. Zeus or something like that.
                        Thanks Didier!!!!!
                        Susan Sorger
                        • L
                          lgm
                          Keep your eyes peeled for the CADspan plugin, I think the beta release will be out this fall. This plugin will offer several tools for 3D printing from Sketchup, including a very robust STL importer/exporter, a resurfacer, visualization tool, an I think a couple more features.
                          I'll post again when I find out more information on this plugin.
                            mtraherne
                            @didier bur said:
                            I have published an import STL script here:
                            http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=8081
                            It's added to the previous su2stl.rb script.
                            Plugins menu -> Export STL file / Import STL file
                            There are 2 samples for tests in the zip archive.
                            Supported format is the most common STL ascii format.
                            Regards,
                            This link appears to have been removed. Is there another location?
                            • AnssiA
                              Anssi
                              Regards,
                              look for it in
                              http://www.crai.archi.fr/RubyLibraryDepot/Ruby/RUBY_Library_Depot.htm
                              Anssi
                                August
                                I'm resurrecting an old thread, but this seems the appropriate place to bring this up.
                                There is a SourceForge project for STL4SU that imports, exports, and recognizes and handles both binary and ASCII files.
                                http://sourceforge.net/projects/stl4su/files/
                                I have just downloaded it and will be trying it out over the next couple of days. It consists of a Readme.TXT file and the stl4su.rb file. There is also a DMG file for Mac folks that is 3+ times the size.
                                I'm going to be attempting to 3D-print the Universal Construction Kit (Free).
                                Site not found ยท DreamHost
                                The owner of this domain has not yet uploaded their website.
                                (fffff.at)
                                We will see how that goes. Someone, somewhere, mentioned that one of the parts in the kit got kicked out as not "manifold".
                                โ€œAn idea, like a ghost, must be spoken to a little before it will explain itself.โ€
                                [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                                  There are several tools to show and even try to fix non-manifold objects [e.g. SolidInspector, SolidSolver etc...]
                                    August
                                    IIRC, there is something along those lines among the "Solid" tools of SU 8 Pro, too.
                                    • 2 / 2
