    Importing .stl files
    30 Posts 12 Posters 11.1k Views 12 Watching
    • Didier BurD
      Didier Bur
      An importer could be quite easy to write (I remember an old Autolisp routine of mine some years ago...). The problem could be the exact format of the STL input: there are binary and ascii formats and within these two kinds of files, sometimes keywords may vary, and scientific notations as well. I used some of these for rapid prototyping and this was (sometimes) a nightmare...
      Please post an sample STL file so I can take a look at it. πŸŽ‰
      DB
      • GaieusG
        Post it zippedas the forum may (not may but does) notallow that format.
        • Didier BurD
          Didier Bur
          I have published an import STL script here:
          http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=8081
          It's added to the previous su2stl.rb script.
          Plugins menu -> Export STL file / Import STL file
          There are 2 samples for tests in the zip archive.
          Supported format is the most common STL ascii format.
          Regards,
          DB
          • W
            watkins
            Dear Didier,
            Thank you so much for all your hard work. I am always amazed by how quickly a request becomes a reality. I will let you know how I get on with the new script.
            Once again, many thanks,
            Bob
            • W
              watkins
              Dear Didier,
              Just a quick follow up on my previous post.
              I created a Sketchup model of simple machined/punched shapes (see the attached file), exported the model as a .stl file, then imported back into Sketchup using your new import option. Apart from some minor cleaning up it worked very well. I used the Delete Coplanar Edges script to remove a lot of the redundant lines and then the erase tool to remove the remaining lines. Interestingly, the through circular hole needed re-cutting, while the elliptical hole was just fine. Ah! The mysteries of life!
              Once again, thanks.
              Regards,
              Bob
              Test_piece.skp
              • Didier BurD
                Didier Bur
                Hi Watkins,
                Redundant lines you mention are due to the STL format which only contains triangles (as you probably know) and the re-cutting on some holes are sometimes due to decimal precision (10 e-14 in SU) and in some cases that is not even sufficient. I've encountered from time to time an error message from SU: "Points are not planar" when reconstructing a model from a STL file with this script. Go figure... This is rather stupid because 3 points are always coplanar.
                Regards,
                DB
                • W
                  watkins
                  Dear Didier,
                  Yes, I knew about the redundant lines issue, but the glich with precision was new. I'm sure this will become a very useful script. I have asked a colleague of mine to create a 3D model in AutoCAD's Mechanical Desktop, and then to export to as a .stl file. I will let you know the results.
                  Thanks again,
                  Bob
                  • C
                    cdubea
                    In any event, thank you for providing this. Hopefully it's better than the method I was using to get SolidWorks models into Sketchup. I'll test is later today and report back.
                    chris
                    http://www.dubea.org/chris_small.jpg
                    • W
                      watkins
                      Dear Chris,
                      Let me know how you get on. I use Inventor myself, and would really like an .iges export option for Sketchup. I like to mass model in Sketchup because it is so quick and easy (creative juices and all that).
                      I recently tried importing a Swagelok coupling as a .dwf file (downloaded from the web) and it sort of worked (needed a lot of cleaning up, and the remaking of faces).
                      Regards,
                      Bob
                      • C
                        cdubea
                        @watkins said:
                        Dear Chris,
                        Regards,
                        Bob
                        I really didn't have much success. Attached is a zip file with a 3d pdf of the part I exported from SolidWorks, the .stl file and the resulting Sketchup file.
                        You can see the results leave something to be desired.
                        chris
                        RMH.zip
                        • W
                          watkins
                          Dear Chris,
                          As you say, disappointing.
                          Did you see the link to SpaceClaim posted a few days ago?
                          Invalid URL
                          (www.spaceclaim.com)
                          Regards,
                          Bob
                          • C
                            cdubea
                            @watkins said:
                            Dear Chris,
                            Invalid URL
                            Regards,
                            Bob
                            I'm familiar with SpaceClaim. Michael Payne was one of the architects of SolidWorks many years ago and left when Dassault Systemes bought SolidWorks. I've been involved with SolidWorks since '96.
                            The pricing on the LT version is very reasonable. If I'm not mistaken, the pro version is done on a perpetual lease basis. It's a nominal fee up front with an annual fee to use the software.
                            • W
                              watkins
                              Dear Chris,
                              Thanks for the additional information. I will request a quote for the LT version and consider using it as a mechanical design alternative to Sketchup. I will check to see if SpaceClaim LT will export .sat, .stp and .igs formatted files.
                              Regards,
                              Bob
                              • Didier BurD
                                Didier Bur
                                Hi cdubea,
                                with rmh.skp, I got the following message in the console:
                                Error: #<ArgumentError: Not enough points - at least 3 required>
                                If you open the stl file in a text editor, you'll see that coordinates are given in scientific notation (vertex 4.613638e+000 2.150841e+000 7.951958e-002 for instance). That doesn't disturb Ruby, but values are very small, this may be the problem (with SU autosnap feature I guess).
                                An intersting test would be to scale your original model by 1000 or 10000, re-export the stl and see what's happening then when importing in SU.
                                Regards,
                                DB
                                • C
                                  cdubea
                                  @didier bur said:
                                  Hi cdubea,
                                  An interesting test would be to scale your original model by 1000 or 10000, re-export the stl and see what's happening then when importing in SU.
                                  Regards,
                                  No problem. I'll give it a try and report back.
                                  chris
                                  • C
                                    cdubea
                                    @didier bur said:
                                    Hi cdubea,
                                    Regards,
                                    Looks much better.
                                    Thanks for making this available.
                                    Wire Mold.zip
                                      sorgesu
                                      Didier,
                                      I was so happy to find this script for IMPORTING STL and provide it to one of my students who was desperate. She told me I was a "Goddess". I confer it back on to you, you are a God.
                                      However, I lost my status fast. The script worked as a far as asking for a unit of measure, and then it proceeded to do nothing. It didn't even seem to try and provided no error message.
                                      I've attached the files which she sent to me.
                                      Can you help?
                                      Many thanks.
                                      PowerPlant-AllParts.zip
                                      PowerPlant-ExteriorComponents.zip
                                      Susan Sorger
                                      Former Seller Hand Rendered Entourage
                                      Former Canadian Authorized Training Centre, SketchUp
                                      • Didier BurD
                                        Didier Bur
                                        Hi Susan,
                                        Your STL files are BINARY, and su2stl can only read ASCII.
                                        Get an ascii version of these files and it will work !
                                        Almost all exporters that I know (Autocad, etc) can export ascii stl files.
                                        I've translated your binaries into ascii with stl_util which can be downloaded here:
                                        http://www.ptcuser.org/rugs/U52/downloads/index.html (works also on XP,Vista...)
                                        See attached ZIP
                                        Regards (and don't loose your status πŸ˜‰ )
                                        P.S. Reading ascii files can be long. I've updated the script so it now displays the number of triangles processed and the total number to convert.
                                        In the Zip you'll find the 2 ascii versions of your STL and the 2 corresponding SKP
                                        Replaces old version. Put it in Plugins folder.
                                        DB
                                          sorgesu
                                          You are not just a God, you are top God. Zeus or something like that.
                                          Thanks Didier!!!!!
                                          Susan Sorger
                                          • L
                                            lgm
                                            Keep your eyes peeled for the CADspan plugin, I think the beta release will be out this fall. This plugin will offer several tools for 3D printing from Sketchup, including a very robust STL importer/exporter, a resurfacer, visualization tool, an I think a couple more features.
                                            I'll post again when I find out more information on this plugin.
