    Importing .stl files
    30 Posts 12 Posters 9.9k Views 12 Watching
      Post it zippedas the forum may (not may but does) notallow that format.
      • Didier BurD Offline
        Didier Bur
        I have published an import STL script here:
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=8081
        It's added to the previous su2stl.rb script.
        Plugins menu -> Export STL file / Import STL file
        There are 2 samples for tests in the zip archive.
        Supported format is the most common STL ascii format.
        Regards,
        DB
        • W Offline
          watkins
          Dear Didier,
          Thank you so much for all your hard work. I am always amazed by how quickly a request becomes a reality. I will let you know how I get on with the new script.
          Once again, many thanks,
          Bob
          • W Offline
            watkins
            Dear Didier,
            Just a quick follow up on my previous post.
            I created a Sketchup model of simple machined/punched shapes (see the attached file), exported the model as a .stl file, then imported back into Sketchup using your new import option. Apart from some minor cleaning up it worked very well. I used the Delete Coplanar Edges script to remove a lot of the redundant lines and then the erase tool to remove the remaining lines. Interestingly, the through circular hole needed re-cutting, while the elliptical hole was just fine. Ah! The mysteries of life!
            Once again, thanks.
            Regards,
            Bob
            Test_piece.skp
              Didier Bur
              Hi Watkins,
              Redundant lines you mention are due to the STL format which only contains triangles (as you probably know) and the re-cutting on some holes are sometimes due to decimal precision (10 e-14 in SU) and in some cases that is not even sufficient. I've encountered from time to time an error message from SU: "Points are not planar" when reconstructing a model from a STL file with this script. Go figure... This is rather stupid because 3 points are always coplanar.
              Regards,
              DB
              • W Offline
                watkins
                Dear Didier,
                Yes, I knew about the redundant lines issue, but the glich with precision was new. I'm sure this will become a very useful script. I have asked a colleague of mine to create a 3D model in AutoCAD's Mechanical Desktop, and then to export to as a .stl file. I will let you know the results.
                Thanks again,
                Bob
                  cdubea
                  In any event, thank you for providing this. Hopefully it's better than the method I was using to get SolidWorks models into Sketchup. I'll test is later today and report back.
                  chris
                  • W Offline
                    watkins
                    Dear Chris,
                    Let me know how you get on. I use Inventor myself, and would really like an .iges export option for Sketchup. I like to mass model in Sketchup because it is so quick and easy (creative juices and all that).
                    I recently tried importing a Swagelok coupling as a .dwf file (downloaded from the web) and it sort of worked (needed a lot of cleaning up, and the remaking of faces).
                    Regards,
                    Bob
                      cdubea
                      @watkins said:
                      Dear Chris,
                      Regards,
                      Bob
                      I really didn't have much success. Attached is a zip file with a 3d pdf of the part I exported from SolidWorks, the .stl file and the resulting Sketchup file.
                      You can see the results leave something to be desired.
                      chris
                      RMH.zip
                      • W Offline
                        watkins
                        Dear Chris,
                        As you say, disappointing.
                        Did you see the link to SpaceClaim posted a few days ago?
                        http://www.spaceclaim.com/
                        Regards,
                        Bob
                          cdubea
                          @watkins said:
                          Dear Chris,
                          Regards,
                          Bob
                          I'm familiar with SpaceClaim. Michael Payne was one of the architects of SolidWorks many years ago and left when Dassault Systemes bought SolidWorks. I've been involved with SolidWorks since '96.
                          The pricing on the LT version is very reasonable. If I'm not mistaken, the pro version is done on a perpetual lease basis. It's a nominal fee up front with an annual fee to use the software.
                          • W Offline
                            watkins
                            Dear Chris,
                            Thanks for the additional information. I will request a quote for the LT version and consider using it as a mechanical design alternative to Sketchup. I will check to see if SpaceClaim LT will export .sat, .stp and .igs formatted files.
                            Regards,
                            Bob
                              Didier Bur
                              Hi cdubea,
                              with rmh.skp, I got the following message in the console:
                              Error: #<ArgumentError: Not enough points - at least 3 required>
                              If you open the stl file in a text editor, you'll see that coordinates are given in scientific notation (vertex 4.613638e+000 2.150841e+000 7.951958e-002 for instance). That doesn't disturb Ruby, but values are very small, this may be the problem (with SU autosnap feature I guess).
                              An intersting test would be to scale your original model by 1000 or 10000, re-export the stl and see what's happening then when importing in SU.
                              Regards,
                              DB
                                cdubea
                                @didier bur said:
                                Hi cdubea,
                                An interesting test would be to scale your original model by 1000 or 10000, re-export the stl and see what's happening then when importing in SU.
                                Regards,
                                No problem. I'll give it a try and report back.
                                chris
                                  cdubea
                                  @didier bur said:
                                  Hi cdubea,
                                  Regards,
                                  Looks much better.
                                  Thanks for making this available.
                                  Wire Mold.zip
                                    sorgesu
                                    Didier,
                                    I was so happy to find this script for IMPORTING STL and provide it to one of my students who was desperate. She told me I was a "Goddess". I confer it back on to you, you are a God.
                                    However, I lost my status fast. The script worked as a far as asking for a unit of measure, and then it proceeded to do nothing. It didn't even seem to try and provided no error message.
                                    I've attached the files which she sent to me.
                                    Can you help?
                                    Many thanks.
                                    PowerPlant-AllParts.zip
                                    PowerPlant-ExteriorComponents.zip
                                    Susan Sorger
                                    Former Seller Hand Rendered Entourage
                                    Former Canadian Authorized Training Centre, SketchUp
                                      Didier Bur
                                      Hi Susan,
                                      Your STL files are BINARY, and su2stl can only read ASCII.
                                      Get an ascii version of these files and it will work !
                                      Almost all exporters that I know (Autocad, etc) can export ascii stl files.
                                      I've translated your binaries into ascii with stl_util which can be downloaded here:
                                      http://www.ptcuser.org/rugs/U52/downloads/index.html (works also on XP,Vista...)
                                      See attached ZIP
                                      Regards (and don't loose your status πŸ˜‰ )
                                      P.S. Reading ascii files can be long. I've updated the script so it now displays the number of triangles processed and the total number to convert.
                                      In the Zip you'll find the 2 ascii versions of your STL and the 2 corresponding SKP
                                      Replaces old version. Put it in Plugins folder.
                                      DB
                                        sorgesu
                                        You are not just a God, you are top God. Zeus or something like that.
                                        Thanks Didier!!!!!
                                        Susan Sorger
                                          lgm
                                          Keep your eyes peeled for the CADspan plugin, I think the beta release will be out this fall. This plugin will offer several tools for 3D printing from Sketchup, including a very robust STL importer/exporter, a resurfacer, visualization tool, an I think a couple more features.
                                          I'll post again when I find out more information on this plugin.
                                            mtraherne
                                            Regards,
                                            This link appears to have been removed. Is there another location?
