    [Obsolete] Offset On Surface (v1.0)
    48 Posts 34 Posters 29.6k Views 34 Watching
      Daniel S
      I was thinking about JPP and OOS and how you take out the SketchUp limitations.
      They are every-day use tools and replace the original ones.
      The idea of improving the drape tool or the smoove tool like they are talking on other topic is great and can change the way we are using SketchUp... in fact, with JPP and OOS you change the way I use it. Thank you!!!
      Just another idea... the follow me tool has limitationts too.. you can´t take a curved face and you can´t take more than one path to follow.
      Daniel S
      • G
        glenal
        Thanks a lot. this is just too good!
          sigue2000
          Thank you! This is great work. 😍
          What?
          • E
            el.antuan
            Another guy saying: THANKS IN DEED!!!
            Fantastic!! Thanks a lot!!!
            Regards 😎 :
            Antonio.
            (PS: In spanish: ¡Cojonudo! ¡¡la pera limonera!! ¡la berza! ¡Este programa y esta web son la leche!!)
            "En las fiestas no te sientes jamás; puede sentarse a tu lado alguien que no te guste." Groucho Marx
            • O
              otb designworks
              Just beautiful!
              Thank you thank you!!
              Cheers, Chuck
              OTB Designworks is on Youtube
              • B
                Baker518
                I really like the possibilities and potential this script has. This is superb work.
                ...but, I have a question? When I pull the off-set, the edges are contoured, so they don't have a discernible face to each side. Is this correct or am I doing something wrong?
                Let me know and thanks again, this is a gem for sure
                Mike
                Don't worry about things you have no control over. Worry is a lack of Faith!
                  Razor681
                  Fredo, this thing is AWESOME!!!!!
                  Your plugin ROCKS!
                  • fredo6F
                    Mike
                    Mike,
                    I suspect this is related to the question of edge style but I am afraid I would need a picture or a SKP sample to see what is the problem, and if this is a problem that can be solved. Thanks to post it.
                    • B
                      Baker518
                      Here you go Fred
                      Offset test.skp
                      • fredo6F
                        I think I understand now.
                        When you offset, the new contour is generated as a curve (you can change this by toggling F9).
                        Then, a Joint Push Pull will consider that because the contour is a curve, the edges have to be generated as Soft and Smooth. This behavior actually is natural in most situations where you push pull a curved surface (for instance generated from Sand Box).
                        Of course, it is possible to introduce options for all these behaviors, as it would anyway difficult for the script to decide by itself!
                          juanjo06
                          thanks guys.... in the plugins crai web this script is not working... maybe this realy does 🎉
                          • E
                            Einstein
                            Hi!
                            I know, it's a dusted thread but maybe someone will make me know.
                            Is it possible that Offset on Surface would treat separately several neighbouring surfaces selected at one time? I mean, instead of creating one big offset from selection border, it would make several offsets, each out of one surface separately.
                            • fredo6F
                              @einstein said:
                              Hi!
                              Not sure I understand. Could you be more precise or give a concrete example.
                              PS: you can use the Thread of ToolsOnSurface, or start a new discussion thread for this subject.
                              • 3 / 3
