    [Obsolete] Offset On Surface (v1.0)
    48 Posts 34 Posters 30.9k Views 34 Watching
      sigue2000
      Thank you! This is great work. 😍
      What?
      • E
        el.antuan
        Another guy saying: THANKS IN DEED!!!
        Fantastic!! Thanks a lot!!!
        Regards 😎 :
        Antonio.
        (PS: In spanish: ¡Cojonudo! ¡¡la pera limonera!! ¡la berza! ¡Este programa y esta web son la leche!!)
        "En las fiestas no te sientes jamás; puede sentarse a tu lado alguien que no te guste." Groucho Marx
        • O
          otb designworks
          Just beautiful!
          Thank you thank you!!
          Cheers, Chuck
          OTB Designworks is on Youtube
          • B
            Baker518
            I really like the possibilities and potential this script has. This is superb work.
            ...but, I have a question? When I pull the off-set, the edges are contoured, so they don't have a discernible face to each side. Is this correct or am I doing something wrong?
            Let me know and thanks again, this is a gem for sure
            Mike
            Don't worry about things you have no control over. Worry is a lack of Faith!
              Razor681
              Fredo, this thing is AWESOME!!!!!
              Your plugin ROCKS!
              • fredo6F
                Mike
                Mike,
                I suspect this is related to the question of edge style but I am afraid I would need a picture or a SKP sample to see what is the problem, and if this is a problem that can be solved. Thanks to post it.
                • B
                  Baker518
                  Here you go Fred
                  Offset test.skp
                  • fredo6F
                    I think I understand now.
                    When you offset, the new contour is generated as a curve (you can change this by toggling F9).
                    Then, a Joint Push Pull will consider that because the contour is a curve, the edges have to be generated as Soft and Smooth. This behavior actually is natural in most situations where you push pull a curved surface (for instance generated from Sand Box).
                    Of course, it is possible to introduce options for all these behaviors, as it would anyway difficult for the script to decide by itself!
                      juanjo06
                      thanks guys.... in the plugins crai web this script is not working... maybe this realy does 🎉
                      • E
                        Einstein
                        Hi!
                        I know, it's a dusted thread but maybe someone will make me know.
                        Is it possible that Offset on Surface would treat separately several neighbouring surfaces selected at one time? I mean, instead of creating one big offset from selection border, it would make several offsets, each out of one surface separately.
                        • fredo6F
                          @einstein said:
                          Hi!
                          Not sure I understand. Could you be more precise or give a concrete example.
                          PS: you can use the Thread of ToolsOnSurface, or start a new discussion thread for this subject.
                          • 3 / 3
