    [Obsolete] Offset On Surface (v1.0)
    48 Posts 34 Posters 29.1k Views 34 Watching
    • E Offline
      el.antuan
      Another guy saying: THANKS IN DEED!!!
      Fantastic!! Thanks a lot!!!
      Regards 😎 :
      Antonio.
      (PS: In spanish: ¡Cojonudo! ¡¡la pera limonera!! ¡la berza! ¡Este programa y esta web son la leche!!)
      "En las fiestas no te sientes jamás; puede sentarse a tu lado alguien que no te guste." Groucho Marx
      • O Offline
        otb designworks
        Just beautiful!
        Thank you thank you!!
        Cheers, Chuck
        OTB Designworks is on Youtube
          Baker518
          I really like the possibilities and potential this script has. This is superb work.
          ...but, I have a question? When I pull the off-set, the edges are contoured, so they don't have a discernible face to each side. Is this correct or am I doing something wrong?
          Let me know and thanks again, this is a gem for sure
          Mike
          Don't worry about things you have no control over. Worry is a lack of Faith!
            Razor681
            Fredo, this thing is AWESOME!!!!!
            Your plugin ROCKS!
            • fredo6F Offline
              Mike
              Mike,
              I suspect this is related to the question of edge style but I am afraid I would need a picture or a SKP sample to see what is the problem, and if this is a problem that can be solved. Thanks to post it.
                Baker518
                Here you go Fred
                Offset test.skp
                • fredo6F Offline
                  I think I understand now.
                  When you offset, the new contour is generated as a curve (you can change this by toggling F9).
                  Then, a Joint Push Pull will consider that because the contour is a curve, the edges have to be generated as Soft and Smooth. This behavior actually is natural in most situations where you push pull a curved surface (for instance generated from Sand Box).
                  Of course, it is possible to introduce options for all these behaviors, as it would anyway difficult for the script to decide by itself!
                    juanjo06
                    thanks guys.... in the plugins crai web this script is not working... maybe this realy does 🎉
                    • E Offline
                      Einstein
                      Hi!
                      I know, it's a dusted thread but maybe someone will make me know.
                      Is it possible that Offset on Surface would treat separately several neighbouring surfaces selected at one time? I mean, instead of creating one big offset from selection border, it would make several offsets, each out of one surface separately.
                      • fredo6F Offline
                        @einstein said:
                        Hi!
                        Not sure I understand. Could you be more precise or give a concrete example.
                        PS: you can use the Thread of ToolsOnSurface, or start a new discussion thread for this subject.
                        • 3 / 3
