    [Obsolete] Offset On Surface (v1.0)
    48 Posts 34 Posters 29.6k Views 34 Watching
      dylan
      Yeah I had that same feeling Eric when testing it and to think now there is the possibility of progressing this script even further with the drape tool is fantastic.
      http://dmdarchitecture.co.uk/
        Daniel S
        1. Inference of the Red Point:
          Perhaps this can be useful (i don´t know if I understand well this feature)
        2. Enter distance AFTER Offset operation:
          I think this is not necessary... and if it is complicated will be better to try other things to improve.. when the distance of the offset is big the surface changes his shape a little. But the current version gives really amazing results.
        Again thank you for this tool (and the other ones!). The Explicit / Implicit selection is a great idea, very useful and works very well.
        The DrapeOnSurface sounds great too!
        Thank you!!!
        Daniel S
        • chippwaltersC
          chippwalters
          Hi Fred. Just wanted to add my 2 cents and say 'much appreciated' for the fine work you've done on this and your other plugins. They truly make a difference in not only the ease-of-use of SU, but in whether or not one even choses SU to create models with. Thanks a bunch! 🎉
          Currently working with Cross-Reality technologies
          • ely862meE
            ely862me
            ok ok now is serious... 😍 .... u*re the man.... 👍
            Thx a lot!
            Elisei (sketchupper)
            Come and See EliseiDesign
            • MarianM
              Marian
              I've been waiting for this tool for years:P
              THANK YOU THANK YOU THANK YOU 😍
                Dan
                Just found out about this 😳
                Very useful idea and amazing new possibilities.
                What more can I say other than a big "Thank you!" ?
                • N
                  notareal
                  Thank you a lot.
                  • majidM
                    majid
                    all my thanx to you for this jewel 👍
                      Daniel S
                      I was thinking about JPP and OOS and how you take out the SketchUp limitations.
                      They are every-day use tools and replace the original ones.
                      The idea of improving the drape tool or the smoove tool like they are talking on other topic is great and can change the way we are using SketchUp... in fact, with JPP and OOS you change the way I use it. Thank you!!!
                      Just another idea... the follow me tool has limitationts too.. you can´t take a curved face and you can´t take more than one path to follow.
                      Daniel S
                      • G
                        glenal
                        Thanks a lot. this is just too good!
                          sigue2000
                          Thank you! This is great work. 😍
                          What?
                          • E
                            el.antuan
                            Another guy saying: THANKS IN DEED!!!
                            Fantastic!! Thanks a lot!!!
                            Regards 😎 :
                            Antonio.
                            (PS: In spanish: ¡Cojonudo! ¡¡la pera limonera!! ¡la berza! ¡Este programa y esta web son la leche!!)
                            "En las fiestas no te sientes jamás; puede sentarse a tu lado alguien que no te guste." Groucho Marx
                            • O
                              otb designworks
                              Just beautiful!
                              Thank you thank you!!
                              Cheers, Chuck
                              OTB Designworks is on Youtube
                              • B
                                Baker518
                                I really like the possibilities and potential this script has. This is superb work.
                                ...but, I have a question? When I pull the off-set, the edges are contoured, so they don't have a discernible face to each side. Is this correct or am I doing something wrong?
                                Let me know and thanks again, this is a gem for sure
                                Mike
                                Don't worry about things you have no control over. Worry is a lack of Faith!
                                  Razor681
                                  Fredo, this thing is AWESOME!!!!!
                                  Your plugin ROCKS!
                                  • fredo6F
                                    Mike
                                    Mike,
                                    I suspect this is related to the question of edge style but I am afraid I would need a picture or a SKP sample to see what is the problem, and if this is a problem that can be solved. Thanks to post it.
                                    • B
                                      Baker518
                                      Here you go Fred
                                      Offset test.skp
                                      • fredo6F
                                        I think I understand now.
                                        When you offset, the new contour is generated as a curve (you can change this by toggling F9).
                                        Then, a Joint Push Pull will consider that because the contour is a curve, the edges have to be generated as Soft and Smooth. This behavior actually is natural in most situations where you push pull a curved surface (for instance generated from Sand Box).
                                        Of course, it is possible to introduce options for all these behaviors, as it would anyway difficult for the script to decide by itself!
                                          juanjo06
                                          thanks guys.... in the plugins crai web this script is not working... maybe this realy does 🎉
                                          • E
                                            Einstein
                                            Hi!
                                            I know, it's a dusted thread but maybe someone will make me know.
                                            Is it possible that Offset on Surface would treat separately several neighbouring surfaces selected at one time? I mean, instead of creating one big offset from selection border, it would make several offsets, each out of one surface separately.
                                            • 2 / 3
