[Obsolete] Offset On Surface (v1.0)
I really like the possibilities and potential this script has. This is superb work.
...but, I have a question? When I pull the off-set, the edges are contoured, so they don't have a discernible face to each side. Is this correct or am I doing something wrong?
Let me know and thanks again, this is a gem for sure
Mike -
Fredo, this thing is AWESOME!!!!!
Your plugin ROCKS!
MikeMike,
I suspect this is related to the question of edge style but I am afraid I would need a picture or a SKP sample to see what is the problem, and if this is a problem that can be solved. Thanks to post it.
I think I understand now.
When you offset, the new contour is generated as a curve (you can change this by toggling F9).
Then, a Joint Push Pull will consider that because the contour is a curve, the edges have to be generated as Soft and Smooth. This behavior actually is natural in most situations where you push pull a curved surface (for instance generated from Sand Box).Of course, it is possible to introduce options for all these behaviors, as it would anyway difficult for the script to decide by itself!
thanks guys.... in the plugins crai web this script is not working... maybe this realy does
Hi!
I know, it's a dusted thread but maybe someone will make me know.
Is it possible that Offset on Surface would treat separately several neighbouring surfaces selected at one time? I mean, instead of creating one big offset from selection border, it would make several offsets, each out of one surface separately.
@einstein said:
Hi!
Not sure I understand. Could you be more precise or give a concrete example.
PS: you can use the Thread of ToolsOnSurface, or start a new discussion thread for this subject.
With your input, this post could be even better ๐
