    Making a spoon?
    16 Posts 10 Posters 5.1k Views 10 Watching
    • P
      Poke
      Hello, I'm new to the forums here and I'm wondering how do I make a spoon. I'm also a newbie at sketchup. (well not so much) πŸ˜„
      • P
        Poke
        😞 Someone help please? 😧 I can't seem to find it anywhere on the web. I can get the models from the warehouse, but I want to know how they did it rather then use what they did.
        • boofredlayB
          boofredlay
          Sorry you have not gotten any replies so far. Most of the Moderators are busy moving content to the new board.
          A spoon can be a complicated shape therefore a complicated explanation as well. My suggestion is that you look over the video tutorials and get familiar with the way SU works.
          Here are the tut's provided by GSU:
          http://sketchup.google.com/vtutorials.html
          Look over the SU5 tut's first. #18 covers some of the sandbox tools which might help with your spoon.
          Get a start and post your progress, then others will have something tangible to help you with.
          Cheers.
          • G
            Gidon Yuval
            Hi Poke,
            Your post got me thinking about how it might be done so I tried to make a spoon.
            http://www.sketchucation.com/forums/scf/sas/Newbie/spoonexperiment.jpg
            It didn't come out very good. I design and plan furniture so that this sort of thing is way outside my comfort zone. I used the soap skin ruby and the follow me tool and the intersect tool and a bunch of others. All in all this took me about 20 minutes.
            I'm sure someone out there will come up with a simple and ellegent solution to modeling spoons and the like.
            spoon experiment.skp
            If you don't know where you're going, you're never going to get there.
            • Jean LemireJ
              Jean Lemire
              Hi Poke, hi folks.
              See attached SU file for ideas.
              There are 20 Scenes in total. Use the small arrows at the top right to access them all.
              Spoon.skp
              • soloS
                solo
                Nice spoons guys, and great tutorial jean.
                Spooning with SU...who would've guessed.
                http://www.solos-art.com
                • S
                  SchreiberBike
                  Jean,
                  Excellent tutorial which applies to spoons and many other things. When you do it, it's simple.
                  • P
                    Poke
                    Thanks! That tutorial really helped πŸ˜„
                    • G
                      Gidon Yuval
                      Nice one, Jean!
                      • A
                        alan wood
                        Hi Jean
                        Thanks for that
                        cheers
                        Alan
                        • boofredlayB
                          boofredlay
                          That is why Jean is the master.
                          πŸ€“
                          • C
                            ciscosystem
                            @jean lemire said:
                            Hi Poke, hi folks.
                            Spoon.skp
                            Hello Jean,
                            I am a new member and searching exactly a solution to this topic but unfortunately your link could not be activate.
                            Could it be kindly on line?
                            Best Regards
                            Hello,
                            Could some one answer: I try to make a spoon with the sand box tool.
                            Thanks a lot if someone could answer to a new member…
                            Cisco
                            • C
                              ciscosystem
                              Hello,
                              Sorry to bother you with this question again but I find no active tuto on this forum to model the hollow part of a table spoon (with tool sandbox for example?).
                              Thank you for your help!
                              Cisco
                              • ely862meE
                                ely862me
                                Draw a sphere and use the scale tool to elongate it on one side(horizontal), then intersect the sphere with a plane placed on the horizontal direction. Place the plane as high as you would like the spoon to be, then intersect both and delete the unwanted geometry.
                                Elisei (sketchupper)
                                Come and See EliseiDesign
                                • Jean LemireJ
                                  Jean Lemire
                                  Hi folks.
                                  Here you go.
                                  Spoon.skp
