    Making a spoon?
    16 Posts 10 Posters 5.1k Views 10 Watching
    • soloS
      Nice spoons guys, and great tutorial jean.
      Spooning with SU...who would've guessed.
        SchreiberBike
        Jean,
        Excellent tutorial which applies to spoons and many other things. When you do it, it's simple.
        • P
          Poke
          Thanks! That tutorial really helped 😄
          • G
            Gidon Yuval
            Nice one, Jean!
            If you don't know where you're going, you're never going to get there.
              alan wood
              Hi Jean
              Thanks for that
              cheers
              Alan
              • boofredlayB
                boofredlay
                That is why Jean is the master.
                • C
                  ciscosystem
                  @jean lemire said:
                  Hi Poke, hi folks.
                  See attached SU file for ideas.
                  There are 20 Scenes in total. Use the small arrows at the top right to access them all.
                  Spoon.skp
                  Hello Jean,
                  I am a new member and searching exactly a solution to this topic but unfortunately your link could not be activate.
                  Could it be kindly on line?
                  Best Regards
                  Hello,
                  Could some one answer: I try to make a spoon with the sand box tool.
                  Thanks a lot if someone could answer to a new member…
                  Cisco
                  • C
                    ciscosystem
                    Hello,
                    Sorry to bother you with this question again but I find no active tuto on this forum to model the hollow part of a table spoon (with tool sandbox for example?).
                    Thank you for your help!
                    Cisco
                    • ely862meE
                      ely862me
                      Draw a sphere and use the scale tool to elongate it on one side(horizontal), then intersect the sphere with a plane placed on the horizontal direction. Place the plane as high as you would like the spoon to be, then intersect both and delete the unwanted geometry.
                      Elisei (sketchupper)
                      Come and See EliseiDesign
                      • Jean LemireJ
                        Jean Lemire
                        Hi folks.
                        Here you go.
                        Spoon.skp
