    [Plugin] Unhide ALL (Edges) - Inside Groups / Components ???
    28 Posts 17 Posters 36.7k Views 17 Watching
    • H Offline
      Howard leslie
      Does anybody know of a ruby that will mine down into all groups / components and then Unhide ALL - (especially edges) ???
      See attached file - a VERY small sample from a huge file.
      As you can see, all the edges are hidden.
      All geometry is inside groups / components - some groups / components are nested.
      (although not in this small sample).
      What I would like to do is Unhide ALL edges - without having to edit each group / component manually one by one.
      Any help much appreciated
      Regards
      Howard L'
      unhide_edges.skp
        tomasz
        Hello Howard,
        I am glad I am the first who has come with rescue (there are plenty of experienced Ruby masters over here 😄 ).
        Here is my small script. I have tested it and it works fine. It un-hides all drawing elements (not only edges but also faces, groups and components).
        Cheers
        Tomasz
        [mod=:3o6q02wn]Please get the latest version from the PluginStore[/mod:3o6q02wn]http://sketchucation.com/pluginstore?pln=unhide_all
        Un-hides all model entities...
        Superseded - get latest version from the PluginStore...
        Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
        • H Offline
          Howard leslie
          Tomasz,
          Thank you so much for producing this script.
          For the task I am currently working on, it works really well.
          May I suggest a refinement to make this script much more useful (V 1.1) ?
          If a user has some geometry selected eg just a few groups and components - then the script will only "unhide all" from the users selection. (ie "unhides all" from the groups / components selected).
          Otherwise, if no selection is made (default mode) - then the script "unhides all" from the whole model (as now).
          Thanks once again for producing this wonderful script
          Regards
          Howard Leslie
            I'm sure Tomasz could do that - the kerky exporter works the same way if geometry is selected... 😒
            • tbdT Offline
              tbd
              here ya go unhide from groups/components on selection or all if no selection
              SketchUp Ruby Consultant | Podium 1.x developer
              http://plugins.ro
                tomasz
                Thanks TBD,
                'Case' looks much nicer 😄
                Tomasz
                • JClementsJ Offline
                  JClements
                  Try using the last posted script on this file.
                  UnHide test.skp
                  • H Offline
                    Howard leslie
                    Tomasz / TBD,
                    I've noticed some strange results with the last script that was posted (TBD)
                    Or maybe its just my misunderstanding of how GROUPS work ???
                    See attached file
                    All Geometry are Groups - NO Components.
                    See what happens when 1 group is copied several times eg the blue cube.
                    When selected and the script is run - ALL instances of that group are edited. (edges are unhidden)
                    I might expect this to happen with Components but not Groups.
                    Is it possible to get the script to run on selected geometry only ???
                    Regards
                    Howard L'
                    UnHide Test 2.skp
                      azuby
                      I've written an extension, unfortunately my web provider had a problem and my website has old content 😞 (I'll fix this).
                      azuby
                      HideEdges - Hides/Unhides edges of selected elements
                      • tbdT Offline
                        tbd
                        azuby: unfortunately it suffers from the same problem - somehow duplicated groups have the same entities as in a component
                        http://plugins.ro
                          I wrote this 'group_miner' script some time ago. It mines down through into any groups and makes sure that all groups are unique... Put it into your Plugins folder and it auto-runs at start up to ensure that the model is initially 'fixed'. You can invoke it in any script (remember to 'require' it if needed BUT it's a short bit of code to copy/paste inside any script anyway)... OR just type 'group_miner(Sketchup.active_model.entities)' to repeat the process 'live'...
                          ~group_glitch_fixer.rb
                          • tbdT Offline
                            tbd
                            and here is the fix (thanks TIG) - works with both .skp from JClements & Howard L' (for the cube in JClements .skp you need to triple click to select all connected as it is not a group)
                            unhide_all.rb
                            http://plugins.ro
                              JClements
                              Thank you TBD and TIG.
                              This will be useful.
                              • H Offline
                                Howard leslie
                                Tomasz / TBD / TIG,
                                Thanks to all of you for working on this script.
                                Now works really well.
                                Regards
                                Howard L'
                                  Jim
                                  Is the fix posted in this thread still needed for the latest SketchUp versions?
                                  • P Offline
                                    Pout
                                    i just did the test, and yes it is still needed
                                      Currently the failure to ensure that copies of a group become single instances of a definition is not fixed - group.make_unique still reports as being deprecated, but it is needed - it is possible to have several copies made of a group definition where they act like component instances, and so changing one instance changes the lot - it's what Components are supposed to do BUT that's NOT what groups are supposed to do... When you copy a group it should automatically become a single instance of its definition - there should never be the equivalent of group.definition.instances[1]. It doesn't currently work properly - either manually or scripted... 😒
                                      • H Offline
                                        hygicell
                                        yesterday and today sketchup 2013 completely froze when using the unhide plugin (which I have used many times before witout problems)
                                        the only difference I can see is that I twice had the outliner and components windows open, which I didn't before
                                        both these windows were on a second monitor which I didn't have before either
                                        anybody else had this experience?
                                        Frank
                                        • mitcorbM Offline
                                          mitcorb
                                          I have seen it discussed before, quite a while back, that Outliner especially, and Component windows can cause issues with your work when they are fully open. If you click on the top bar of each, they will "roll up". This, I have read, will reduce the problem.
                                          Hope this helps.
                                            michaelhund
                                            Alas, I too have found this plugin freezes in Sketchup 2013. I tried closing all dialogs, particularly the outliner, scenes and layers, and no luck. Pity.
                                            • 1 / 2
