    [Plugin] Unhide ALL (Edges) - Inside Groups / Components ???
    28 Posts 17 Posters 39.9k Views 17 Watching
    • T
      tomasz
      Hello Howard,
      I am glad I am the first who has come with rescue (there are plenty of experienced Ruby masters over here 😄 ).
      Here is my small script. I have tested it and it works fine. It un-hides all drawing elements (not only edges but also faces, groups and components).
      Cheers
      Tomasz
      [mod=:3o6q02wn]Please get the latest version from the PluginStore[/mod:3o6q02wn]http://sketchucation.com/pluginstore?pln=unhide_all
      Un-hides all model entities...
      Superseded - get latest version from the PluginStore...
      • H
        Howard leslie
        Tomasz,
        Thank you so much for producing this script.
        For the task I am currently working on, it works really well.
        May I suggest a refinement to make this script much more useful (V 1.1) ?
        If a user has some geometry selected eg just a few groups and components - then the script will only "unhide all" from the users selection. (ie "unhides all" from the groups / components selected).
        Otherwise, if no selection is made (default mode) - then the script "unhides all" from the whole model (as now).
        Thanks once again for producing this wonderful script
        Regards
        Howard Leslie
        • GaieusG
          I'm sure Tomasz could do that - the kerky exporter works the same way if geometry is selected... 😒
          • tbdT
            tbd
            here ya go unhide from groups/components on selection or all if no selection
            http://plugins.ro
            • T
              tomasz
              Thanks TBD,
              'Case' looks much nicer 😄
              Tomasz
              • JClementsJ
                JClements
                Try using the last posted script on this file.
                UnHide test.skp
                • H
                  Howard leslie
                  Tomasz / TBD,
                  I've noticed some strange results with the last script that was posted (TBD)
                  Or maybe its just my misunderstanding of how GROUPS work ???
                  See attached file
                  All Geometry are Groups - NO Components.
                  See what happens when 1 group is copied several times eg the blue cube.
                  When selected and the script is run - ALL instances of that group are edited. (edges are unhidden)
                  I might expect this to happen with Components but not Groups.
                  Is it possible to get the script to run on selected geometry only ???
                  Regards
                  Howard L'
                  UnHide Test 2.skp
                    azuby
                    I've written an extension, unfortunately my web provider had a problem and my website has old content 😞 (I'll fix this).
                    azuby
                    HideEdges - Hides/Unhides edges of selected elements
                    *error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
                    Bad English? PM me, correct me. :smile:**
                    • tbdT
                      tbd
                      azuby: unfortunately it suffers from the same problem - somehow duplicated groups have the same entities as in a component
                      http://plugins.ro
                        I wrote this 'group_miner' script some time ago. It mines down through into any groups and makes sure that all groups are unique... Put it into your Plugins folder and it auto-runs at start up to ensure that the model is initially 'fixed'. You can invoke it in any script (remember to 'require' it if needed BUT it's a short bit of code to copy/paste inside any script anyway)... OR just type 'group_miner(Sketchup.active_model.entities)' to repeat the process 'live'...
                        ~group_glitch_fixer.rb
                        • tbdT
                          tbd
                          and here is the fix (thanks TIG) - works with both .skp from JClements & Howard L' (for the cube in JClements .skp you need to triple click to select all connected as it is not a group)
                          unhide_all.rb
                          http://plugins.ro
                          • JClementsJ
                            JClements
                            Thank you TBD and TIG.
                            This will be useful.
                            • H
                              Howard leslie
                              Tomasz / TBD / TIG,
                              Thanks to all of you for working on this script.
                              Now works really well.
                              Regards
                              Howard L'
                                Jim
                                Is the fix posted in this thread still needed for the latest SketchUp versions?
                                • P
                                  Pout
                                  i just did the test, and yes it is still needed
                                    Currently the failure to ensure that copies of a group become single instances of a definition is not fixed - group.make_unique still reports as being deprecated, but it is needed - it is possible to have several copies made of a group definition where they act like component instances, and so changing one instance changes the lot - it's what Components are supposed to do BUT that's NOT what groups are supposed to do... When you copy a group it should automatically become a single instance of its definition - there should never be the equivalent of group.definition.instances[1]. It doesn't currently work properly - either manually or scripted... 😒
                                    • H
                                      hygicell
                                      yesterday and today sketchup 2013 completely froze when using the unhide plugin (which I have used many times before witout problems)
                                      the only difference I can see is that I twice had the outliner and components windows open, which I didn't before
                                      both these windows were on a second monitor which I didn't have before either
                                      anybody else had this experience?
                                      Frank
                                      • mitcorbM
                                        mitcorb
                                        I have seen it discussed before, quite a while back, that Outliner especially, and Component windows can cause issues with your work when they are fully open. If you click on the top bar of each, they will "roll up". This, I have read, will reduce the problem.
                                        Hope this helps.
                                          michaelhund
                                          Alas, I too have found this plugin freezes in Sketchup 2013. I tried closing all dialogs, particularly the outliner, scenes and layers, and no luck. Pity.
                                            AirWindSolar
                                            No freeze here, just doesn't appear to do anything at all. Won't even unhide elements within the currently open component, even after view>hidden and Ctrl-A.
                                            Will fiddle with it a bit more when I have time.
