    Array
    9 Posts 7 Posters 5.2k Views 7 Watching
    • S
      Scotty T
      Is there a array ruby out there anywhere?
      • P
        perk
        What exacly are you trying to array? You can array within SU. use the move/copy tool, copy item however far you want and then type in *10 or however many times you want the copy and it will array it. I know you can do the same with the rotate tool in a similar way but I have not done that yet.
        • S
          Scotty T
          Yeah been doing that but gets routine when you have several copies to make. Looking for array similar to Auto-Cads array tool.
          • boofredlayB
            boofredlay
            In what way Scotty? Maybe I can help.
            • N
              not registered yet
              Choose your item,
              choose rotate,
              hit ctrl to toggle on copy,
              choose the first point (the point you will rotate around),
              choose the second point (probably somewhere on the item),
              rotate the item (you can also type in a rotation angle at this point and hit enter) to the point you want it to be,
              click or hit enter,
              and then type in "10x" (or however many you want),
              hit enter,
              and it will array around the point you picked.
              Alternatively, you can type in "/10" or whatever number and it will evenly fill the distance with that number of items, same with move/copy.
              P: crojack
              • EdsonE
                Edson
                check this two wondeful tutorials on arrays, created by our member gidon.
                Array tut.skp
                Circular array tut.skp
                http://www.mahfuz.arq.br
                • S
                  Scotty T
                  Thats what I needed...Thanks!
                  • TIGT
                    As well as the in-built tools for linear and polar arrays, using Ctrl-key + Move and Rotate respectively, followed by xNumber to multiply or /Number to divide; there are several Ruby Plugins - e.g. my Matrix+Proximity does 2D and 3D arrays, with the added possibility of randomized offsets, rotations, scaling etc. There are also others out there if you need them [e.g. Grow.rb]...
                    • G
                      gksl4
                      There is a great ruby script from TIG - grow.rb - various arrays and more..
                      You can find it at Didier Bur's site
                      http://www.crai.archi.fr/RubyLibraryDepot/Ruby/RUBY_Library_Depot.htm
                      Regards,
                      George
